5 lug suspension upgrade options
Discussion in '5 Lug' started by kcyota, Aug 13, 2017.
  1. Aug 13, 2017 at 11:29 AM
    kcyota
    kcyota [OP] New Member
    Stephen
    Kansas City
    '06 white tacoma 2WD
    none
    My little '06 super white tacoma would look sick if it had a decent lift. This 5 lug chasis i guess isnt cooperating with companies i have looked at for parts. Any adivice or direction would be great
  2. Aug 13, 2017 at 11:35 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    Sell it
    Firebird likes this.
  3. Aug 13, 2017 at 11:52 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Ready lift and fat bobs makes a lift kit for 5 lugs. There's also the eBay special. The max you'll be able to do easily is 3 inch in the font and a much as you want in the back (back is wayyyyyyyyy easier). Some 5 lugs are starting to add a 1 in body lift to help clear 33's.
    Welcome to forum :thumbsup:
    SamGoingHam likes this.
  4. Aug 13, 2017 at 11:52 AM
    kcyota
    Stephen
    Kansas City
    none
    Thought about it. Therr are things i dont like about it. The milage was good to pass up for the price. Would changing the hubs or something make the truck accept a upgrade
  5. Aug 13, 2017 at 12:02 PM
    kcyota
    Stephen
    Kansas City
    none
    Thanks you for some guidance on this lift issue. Im checking out thise brands now. This is my first truck. Fun as hell to drive. She just needs to be higher. :)
  6. Aug 13, 2017 at 12:13 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    They are really fun to drive with the lower center of gravity. Honestly for options I'd run the eBay special and save some money use it on something else. While you're lifting you may want to change out your shocks. (Well you will have to at least for the rear) For the rear with a 2 inch aal you can put in any 6 lug shocks you want that supports 0-1 inch lift. For the front I'd just run a set of bilstien hd 4600s. Check out the link in my sig and it'll show you how much each part affects lift.
  7. Aug 13, 2017 at 2:15 PM
    SamGoingHam
    SamGoingHam IG: SamGoingHam
    Sam
    Phoenix, Arizona
    2014 TACO 5LUG LOCKED
    33s or GTFO
    As Kenny has said, our options are Readylift and Fat Bob. I'm running the Readylift with a swapped 3in front spacer. Switched stock black struts and shocks for 4600s all around. Upgrading rears to 5100 in a week. Installed a 1in Body lift on my truck as well. Besides that, tire upsizing is the best option for ground clearance. Currently running 33s with a 4.56 Regear&Locker.
    These are just the cheaper options. Not many of us have pulled the plug on Mid and Long travel yet.
    EDIT: Forgot to say Welcome!:D
  8. Aug 13, 2017 at 3:40 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    In the next month or so Im switching out for a 3 in so I'll have a ready lift spacer for sale.
  9. Aug 17, 2017 at 10:53 AM
    AllTerrainMonster
    AllTerrainMonster Well-Known Member
    South Korea
    2006 2.7L Base 2WD
    I'm in the same boat, there is no intermediate or average lift. It is either a leveling kit or the long travel kit
  10. Oct 6, 2017 at 9:33 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Don't really want to lift other than slightly wider tires on 16" rims. Is there an upgrade to the stock front springs I can do when I upgrade to 4600's
  11. Oct 6, 2017 at 9:41 AM
    SamGoingHam
    Sam
    Phoenix, Arizona
    Friend of ours is selling a 5LUG TC Mid travels if anyone isn't ready to fully go LT yet.
    5 Lug Fury likes this.
  12. Oct 6, 2017 at 9:51 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    He's a good guy too :thumbsup:
  13. Oct 6, 2017 at 10:11 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    I read the entire suspension thread the other day but just now found you had asked the same question about a year ago. How has the ride improved just going to the 4600's? I have ~42000 on my stock shocks and it's too mushy, one onramp sets up a fore and aft resonance that I've never experienced in any other vehicle yet it seems to pass the rudimentary fender bounce test.
  14. Oct 6, 2017 at 11:26 AM
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    My experience with the Bilstein's vs OEM, is that it's an excellent update.
    The OEM shocks/struts are basically parts-bin sourced - this is a budget truck using common components from other Toyota products, not necessarily truck-based. As such, they are _just_ adequate to meeting light demands placed upon the truck.
    I had my OEM shocks on the truck when i first put the ARB front bumper on the truck - that much additional weight over the front spindles, was sufficient enough to blow the struts out within about two weeks. They were at the 64k km (~42k miles) point.
    4600's / 5100's are also used in the Prerunner's.
    The ride is stiffened up, it handles like a truck should. Yes, the occasional pothole might be jarring. There is no mushing in corners, body roll is much reduced. If you are going to do the lift - do the shocks/struts while things are apart.
    dwtacoma likes this.
  15. Oct 14, 2017 at 10:33 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Thanks, i guess that's the best I can do for now. Anyone know the skinny with the new bilstein 8112 coilover kit? It seems to be what everyone is looking for to get a moderate lift on 2nd gen 5-lugs.
    Tinytaco98 and HackD like this.
  16. Oct 14, 2017 at 10:50 AM
    HackD
    William
    I'm a little out of my element with this new product - i double-checked, and it does appear that it might work with ours, given that 4600 length struts will work with our trucks without a spacer lift already in place - however, they aren't specifically mentioning the 5-lug variation, which is always concerning. I'm unclear whether they would work with our Tacomas without a spacer in place - related to strut / coilover angle from the top mount. I'm not sure if the coilover would have clearances necessary. Someone is going to have to bite the biscuit and be the first to try them on for size, i'm thinking... and at $2100+ USD .. whew, that's a helluva gamble.
  17. Oct 14, 2017 at 11:00 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    What they do mention is the 2.7L base model separate from 4wd, pre runner, etc. I scanned a thread where they were brought up but mostly conjecture since they weren't out yet.
  18. Oct 14, 2017 at 11:13 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    L4 means(?) too much I still don't know about this stuff.
  19. Oct 14, 2017 at 11:15 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    L4 = inline 4 cyl ?
  20. Oct 14, 2017 at 11:16 AM
    HackD
    William
    Without seeing "2wd" base, yes - it's mostly conjecture, with a side-order of wishful thinking until someone gives it a shot and crawls under the front end of our truck.
    The 4x4 came as a base model, no SR5 or other trim upgrades. Same deal as with the Pre-Runner. A lot of manufacturers/retailers don't even see the 5-lug on their radar, in terms of product awareness. In this case, i'm seeing that they'll fit the 2wd Pre-runner version, or the 4x4 versions, trim level base to SR5. The 5-lug to me is noticeable in exclusion from the list only.
