5 LUG TACO BUILD
Discussion in '2nd Gen. Builds (2005-2015)' started by 5LUGTACO, Feb 23, 2011.
  1. Sep 2, 2012 at 8:01 AM
    #161
    CAPABLE5LUG805
    CAPABLE5LUG805 Member
    central california
    taco w/ HOT sauce
    Drop in afe air filter, fat bobs strut spacer, plasti diped badges. Big ass snug top, bed slide, tinted winsheild and side windows
    Yea has anyone used it on their 5lug? And how do they like it?
  2. Sep 2, 2012 at 3:16 PM
    #162
    CAPABLE5LUG805
    central california
    taco w/ HOT sauce
    Also should i use the trd rear bilsteins or the 5100s that are available at shock wharehouse? I like the 5100s and ive heard they actually ride better that the blue and yellow 4600? I plan on ordering bisteins for the front shocks from them.
  3. Sep 2, 2012 at 3:52 PM
    #163
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    TRD shocks are not going to be compatible with the 5-lug.
    The leaf springs are the only interchangeable parts on the suspension.
  4. Sep 2, 2012 at 6:07 PM
    #164
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    the stock TRD bilsteins will also fit the rear. the front bilstein TRD shocks wont though.
    you may be talking about the bilsteins that are built for our truck though, just make sure you get the right part #.
    as far as rear 5100 i'm not sure if you would run into trouble with them since they are meant for lift on a 6 lug right? I think they would be too long unless you had like 3" of lift in the rear. My theory may be incorrect but it kind of sounds right? :notsure:
  5. Sep 2, 2012 at 10:43 PM
    #165
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    im using them on my 1st gen. ride real nice compared to a standard aal. and 5100s will work if they are stock replacement for a prerunner and not extended travel.
  6. Mar 12, 2014 at 3:00 PM
    #166
    Will922
    Will922 Well-Known Member
    How many inches does the Total Chaos kit lift your truck?
    Thanks - Will
  7. Oct 10, 2018 at 8:25 AM
    #167
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    so how do you like the American Motorsports lift spindles with TC UCA ?
  8. Sep 17, 2020 at 10:01 AM
    #168
    Base 07'Tacoma
    Base 07'Tacoma Active Member
    @5LUGTACO
    On the 31x10.50x15 on your 5 Lug (I have one too) did you have to do any spacers and or lift? Considering keeping my steelies and going w/ these tires and set up if I can replicate what you have. Please let me know - TIA
