5 Lug Tire Size Question
Discussion in 'Wheels & Tires' started by LiL KaStOuT, Aug 5, 2011.
  1. Aug 5, 2011 at 8:04 PM
    LiL KaStOuT
    LiL KaStOuT [OP] My husband's TACO
    Sammi
    Maricopa, Az
    Silver 2016 SR 4x4 DC SB
    Whatever he wants, he gets!! I lied, whatever I approve, he gets!!
    Hi guys,
    I am wondering what the tallest tire is for the factory 14" wheels on a stock 1st gen 5 lug. Also, I am wondering what the tallest tire is for a 15" wheel?
  2. Aug 5, 2011 at 9:07 PM
    0uTkAsT
    0uTkAsT Gunslingin' Gearhead
    Josh
    Gilbert, AZ
    Rock Flinging Turd Gen
    Stuff that makes it easier to run over other stuff.
    Tagged for info! :D
    Also, we will be doing a 1.5" spacer lift up front and we'd like to get at least 1" more tire under it if possible.
    Thanks for the help.
  3. Aug 5, 2011 at 9:19 PM
    LiL KaStOuT
    Sammi
    Maricopa, Az
    Im not sure I want the spacer lift, I rather go with a spindle lift like we discussed before.. But we will see how it goes.
  4. Aug 6, 2011 at 11:33 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I'm not sure they make a spacer lift for the 1st gen 5 luggers. I looked long and hard and the only thing I found was spindles or new coils. On mine I had 235/75/15 tires on it before any lift. It worked but rubbed the wheel wells in the front if I hit big bumps or if I had 2 passengers with me in the cab it was enough weight to bring the front down slightly and it rubbed in turns. I have no idea about 14" wheels and yours is probably different because it's an early 1st gen but that's my experience. The 235s looked good to me without lift but after a 3" spindle they look a hair on the small side
  5. Aug 6, 2011 at 12:08 PM
    0uTkAsT
    Josh
    Gilbert, AZ
    Thanks for the input!
    We did find some coil spacers for the 5 lug, 1.5" lift by Daystar, $40 shipped. http://www.suspensionconnection.com/cgi-bin/suscon/KT09113TA.html
    Spacers obviously aren't the ideal way to go but options are extremely limited for these 5-lug trucks. She does want to lift the whole truck, but what she really needs right now is just enough lift in the front to clear larger wheels and tires. I'm hoping to clear a 29" or at the very least a 28" tire without rubbing. The 235/75-15s are a 29" tire, 215/75-15 is a 28" tire, and right now she has 215/70-14s which are 26" tires. With a 1.5" lift and 2-3" more tire under the truck, I think she'll be happy with the stance and it will be capable enough to take most forest roads for camping and such.
    These are the wheels she's buying, $48 Pro Comp Steel Wheels Pro Comp 52 Rock Crawler Series - Gloss Black Powder Wheels 52-5765 52-5765 Pro Comp Rock Crawler Steel Wheelshttp://www.4wheelparts.com/Wheels/5...s=209&t_pt=100021&t_pl=100347&t_pn=PCW52-5765 Pro Comp 52 Series in 15x7 with 3.75" backspacing.
    We're not sure which tires we're going with yet, but based on your recommendation we're considering these http://cgi.ebay.com/ebaymotors/4-23...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    These are the same ones in 215s http://cgi.ebay.com/ebaymotors/4-21...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
  6. Aug 8, 2011 at 12:41 AM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    general grabber at2 has a 27 or 28 for the stock wheel. not sure what will fit at full bump though. and as far as rubbing while turning the either tire should be ok. but really depends on wheel and backspacing too
  7. Aug 8, 2011 at 10:59 AM
    0uTkAsT
    Josh
    Gilbert, AZ
    Thanks man. We're set on the wheel, 15x7, 5 on 4.5 bolt, 3.75" backspacing.
    Where do you buy General tires at?
  8. Aug 8, 2011 at 7:10 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
  9. Aug 8, 2011 at 11:08 PM
    0uTkAsT
    Josh
    Gilbert, AZ
    Thanks for the link!
  10. Aug 9, 2011 at 4:28 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    anytime man! :D
  11. Aug 11, 2011 at 12:03 AM
    MowTaco
    Kansas
    I'd say the 235s will be perfect for what you've got. If you have any access to a similar wheel/tire combo to try out I'd recommend it. I had a godsend at our shop at school when my teacher sent me out to get a tire outside that needed a plug... it happened to be a stock 5 lug steelie with 235 mud tire on it off his buddy's 5 lug taco. I tried it on mine and it cleared turning but I didn't take into account the rubbing with the suspension cycling.
  12. Aug 11, 2011 at 12:06 AM
    0uTkAsT
    Josh
    Gilbert, AZ
    Awesome, thanks guys, we really appreciate your help. We'll give the 235s a shot. Hopefully the 1.5" spacer will help prevent any potential rubbing issues.
  13. Aug 11, 2011 at 6:22 PM
    MowTaco
    Kansas
    The rubbing on mine really didn't hurt anything it just scared the shit out of me whenever it hit. But hey if they do rub... i suppose your only choice is to go for those spindles you wanted in the first place :)
  14. Aug 11, 2011 at 8:07 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    the spacer will help at ride height not much but it will. but the front suspension on these trucks is soft so any bump and you rub on fenders and such
  15. Aug 11, 2011 at 10:30 PM
    0uTkAsT
    Josh
    Gilbert, AZ
    Thanks for the input guys. Money's tight so a spindle lift is out right now. If rub at full bump is all that we need to worry about then I think we're good. Or to be 100% safe, she might try the 215s. Those are still a full inch taller than her factory tire, but it's up to her. We'll check back in when she makes her decision.
