5 lug wheel sizes
Discussion in '5 Lug' started by 808tacomas, Oct 3, 2014.
  1. Oct 3, 2014 at 7:14 PM
    808tacomas
    808tacomas [OP] Well-Known Member
    kingrob
    oahu
    2011 toyota tacoma 4door 4 cyl.
    working on it..need some advice
    Sup YOTA lovers. I know that the biggest tire for 15 with out any mods is 235/75
    But wats the biggest tire with no mods for 16"???
  2. Nov 1, 2014 at 2:41 PM
    justinh384
    justinh384 Active Member
    Justin
    Wrightsville, GA
    2017 White Toyota Tacoma SR
    You could probably get by with 235 70r16 if you went up to a 16 inch wheel.
  3. Nov 4, 2014 at 2:38 PM
    RustyBucket
    RustyBucket Well-Known Member
    I run 225/75R16 on mine and I still have a good 20mm+ clearance from the swaybar and other components. I removed the black boxes under the wheel well liners to install mudflaps so I have a little extra clearance at the rear of the wheel wells.
  4. Dec 11, 2014 at 8:53 AM
    Clearwater Bill
    Billy
    Largo Florida
    Play with this and find a 16" that's really close in total dia to the OE tire.
    You'll keep your speedo/odo accurate and not have clearance issues, assuming you pick a wheel with the correct width/offset.
  5. Dec 2, 2016 at 6:18 PM
    PapaCoop
    PapaCoop Member
    CC
    13 Tacoma Access CAb
    None
    Just the post I was looking for but not enough info. I m trying to go the same rote. 16 Allow wheels with a 235/75R16. Still unsure if this will work or not. Any thoughts?
  6. Dec 3, 2016 at 9:19 AM
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    To provide information to you - you need to provide better information. What is the rim offset/back-spacing. OEM is +45. What is the rim width .. 16x7, 16x8?
    At the very least, a fender-well black-box deletion will be necessary.
    This is a near 30" class tire at 29.9" .. it's going to have some impact on your gearing.. whether it's tolerable as-is to you.. is a judgement you will need to make.
    I run 225/75R16. They fit on even before lift/level .. and i still have my fender-well black-boxes .. but they also measure in at 29.3" in diameter. Stock manual 3.31 gearing is barely tolerable to me - not worth the expense to rectify... if i was at 29.9", that tune might change.
    Play with this site a bit, and and also read-read-read this 5-lug sub-forum... there are no easy answers unfortunately. Too many variables that need to be considered.
  7. Dec 4, 2016 at 5:21 PM
    PapaCoop
    PapaCoop Member
    CC
    None
    Stock/OEM Steel wheels. 15" Current tires are 215/70R15. Going to a 235/75R15. Same steel wheels. Finding 16" alloy has proven difficult. Is the 235/75R15 set-up at 28.88 inches and 9 1/4 inches wide ok as a replacement?
  8. Dec 4, 2016 at 5:31 PM
    HackD
    William
    Plenty of people run 235/75R15's on this sub-group - some on the OEM 15x6 rims, some have bought aftermarket stamped steel (ie cragers) or a variation of alloy. Some have stuck to the OEMish +45 offset that keeps the rims/tires well under the fender well lip... others have gone more aggressive to a lower positive offset, or entered into negative offset territory for a really aggressive appearance.
  9. Dec 4, 2016 at 6:35 PM
    PapaCoop
    PapaCoop Member
    CC
    None
    Please expand on the "+45 offset". I would like to alter the appearance a little. Any suggestions are appreciated.
  10. Dec 4, 2016 at 7:17 PM
    HackD
    William
    The offset of a wheel is the distance from the hub mounting surface to the center line of the wheel. The wheel offset is measured in millimeters and results in a positive, negative, or zero offset. Positive offset is when the hub mounting surface is toward the front or wheel side of the wheel.
    What is a wheel offset explained - TSW.com
    www.tsw.com/explore-tsw-custom-wheels/what-is-wheel-offset.php
    Plainly spoken - the 2wd 5-lug has a high positive offset rim, which sets the rim/wheel assembly into the wheel-well of the Tacoma - this is a part of the Tacoma 5-lugs scaled down suspension setup, using a different axle, suspension and running gear than the 6-lug tacomas.
    The 5-lug, as OEM, uses a high positive offset rim that is more often found with cars, light suv and minivan platforms. Some of the 5-lug guys messing with the rim/tire combinations, are also trying to mimic the appearance of the 6-lug in terms of the rim/tire assembly not appearing quite so tucked into the wheel-wells - they'd be looking at a rim with a positive offset figure in the neighborhood of +10. Those who really are looking to go to town with the 'stance' appearance.. they are eyeballing -18.
    The lower the offset - the further out the rims will sit on the 5-lug axle stub. The cost is increased wear on the axle bearings.
    The following needs to be gone through, and explains it so much better than i.
    https://www.tacomaworld.com/threads/wheel-backspacing-and-offset-info.102992/
