5 lug wheels
Discussion in 'Street Trucks' started by mason33x, Jan 21, 2021.
  1. Jan 21, 2021 at 9:19 AM
    mason33x
    mason33x [OP] Well-Known Member
    Mason
    2009 Tacoma 2.7 regular cab
    k&n filter , cherry bomb muffler , 2/3 drop
    And suggestions for wheels
    98TT2.4 likes this.
  2. Jan 21, 2021 at 2:29 PM
    98TT2.4
    98TT2.4 I was TUNED in Japan and now F A T here!!!
    Lazaro
    Florida
    98 Tacoma 2rz-fe 2wd extcab. SR5
    Mild lowered sport suspension, all greasable zerk points front and rear, rear 3.5" lower with 4wd springs,middle leaf pulled and 2wd overload leafs,kyb shocks, rear oem bumpstops and 4 wheel parts shackles and urethane bushings. Front lower 2" custom one off made 2" drop springs oem upper lower arms kyb shocks stock sway bar and urethane bushings, wheels18×9 square et24 Advan Racing RGD2 satin black color, Nitto 225 40 18 NT555g2 tires, ARP wheel studs front and rear, NRG real titanium wheel lugs, sport drilled and slot rotors with ceramic pads, red powdercoated oem calipers, stop tech brake lines front and rear, Motul 550 brake fluid, weight reduction all over, Stripped ext, stripped int, stripped engine bay, full carbon fiber back and black suede semi bucket seats with adjustable sliders, planted technology seat mounts, pioneer single din radio, pioneer speakers, exterior smooth radio antenna, AEM guages, 2.5l fire extinguisher with quick release bracket, blackcat custom instrument cluster guages, Nrg carbon fiber and perforated red stitch leather steering wheel, Nrg quick release for steering wheel, led interior lights,rear adjustable brake proportioning valve, 01 full cabon fiber VIS racing hood, aerocatch safety pins, window tint 35front windows 20 cab side and 15percent rear glass, single piece rear glass,led smoke red taillamps, clear red led third brake light, LCE longtube header, speed factory titanium header studs, magnaflow catalytic converter, custom stainless exhaust pipe, Borla proxs mid muffler going to rear custom notched bumper with an auxiliary vibrant real titanium 4" exit muffler, skunk2 muffler silence insert. K&N air filter, Injen air intake system, LCE throttle body spacer, egr delete, declutured engine bay, LCE fuel pressure gauge, K&N valve cover breather, LCE underdrive pulley, dual 12" electric cooling fans, Mishimoto fan controller and relay, LCE 180 degree thermostat, aftermarket black reflector headlamps with white halogen bulbs, matching corner lamps with amber led, 01 4wd fenders, 4wd modified grille, 2001 srunner front bumper, srunner front bodykit chin spoiler, clear lens amber led signal lamps, smooth tailgate handle relocation, locking gas cap, Ultra guage obd2 monitor. yellow silicone wiper blade, LCE black silicone coolant hoses, Brisk racing silver plugs, Denso ignition wires, Denso ignition coils, 7 pound lithium battery, the paint is oem original maroon color and that's why I have to paint the truck and do the bodywork. Having a nice ride takes alot of work and dedication. The only thing that's easy is to sleep and dream away.
    You lowered it some? I dont follow the 2nd gens alot. I personally like jdm wheel designs. But you have to decide what your style and taste is. I choose a very light wheel. I went from factory 14s to 18s and didn't gain any extra weight. Weight is my enemy,:duel:
  3. Jan 21, 2021 at 5:54 PM
    mason33x
    Mason
    I was thinking about some 17s
  4. Jan 21, 2021 at 5:54 PM
    mason33x
    Mason
    And yeah it’s lowered 2/3
  5. Jan 21, 2021 at 7:55 PM
    98TT2.4
    Lazaro
    Florida
    Sorry I was outside for a while, My truck looks great with 18s. The 2nd gen body is bigger than mine. I researched for a while to determine what size looked good and not oversized and had the right proportion to the truck. Depending on What you factory rolling diameter is you can calculate from there. My factory tire diameter is 25". So my 225 40 18s are exactly 25" Also. So my speedo calibration did not change and the rear gear ratio stayed the same and the truck did not get higher up. So you need to know what is your factory tire size. You can go 17s with a chunkier tire and it would look good. But the body on your is bigger, you can go to 18s or 19s easy and it would look even better with the correct tire. But as the rim size goes up the tire sidewall goes down. Let me try to post some pics of my wheels so you can see. Hope fully I can get the pics to load. My phone has issues.
  6. Jan 21, 2021 at 8:01 PM
    98TT2.4
    Lazaro
    Florida
    20190718_160857.jpg here the suspension is stock height front and rear20200311_094837.jpg here the rear is lowered 3.5" the front is stock height[, I have to drop the front next.ATTACH=full]4354696[/ATTACH] 18s the ride height here is stock!20200426_100809.jpgyes here's one close up 18× 9 et 24 225 40 18 Nitto nt555g2. Note the wheels and tires are dirty, the fender is pushed in thats why it looks funky. This angle is not the best but it shows you the design of the wheel. let me show you more pics so you can see you can go 18s easy with your truck.
    sorry I'm having issues loading pics. I was lucky the first one did.
  7. Jan 21, 2021 at 8:33 PM
    98TT2.4
    Lazaro
    Florida
    Are you on factory wheels now? what size are they? 17s would look a bit small on your truck. An 18" with a little more meat on the tire would look better. Here's the lowdown with tires and their different sizes. Everyone is different. Do you like a harsher ride or more refined and comfortable one. The lower the profile the smaller the sidewall is. One tire like a bridgesto potenza has a sidewall like a rock. They are gonna have amazing steering input and cornering but will torture you with no comfort. A softer sidewall is important if the comfort is important to you. The tires I have are summer performance tires and you can see they are pretty low, but even though they ride really amazing.Why because you can compress the sidewall with your fingers so they have a softer sidewall. They are very good hitting and soaking up bumps and the imperfections on the road.
    I posted the pictures so you can see how the 18s look on mine and how they look in proportion to my truck against the body. The second gen trucks like your are larger. The first gens like mine are mini. If I were to park next to you my truck world look like the baby Taco next to you. That means you can easily rock 18s with no issue or 19s if you want. But 17s look small even on mine to me at least they do. Some people have 17s. But I'm glad I got my 18s, no more or less.
  8. Jan 21, 2021 at 9:08 PM
    98TT2.4
    Lazaro
    Florida
    :101010:
    Looks good. nice!
  9. Jan 21, 2021 at 9:08 PM
    98TT2.4
    Lazaro
    Florida
    :burnrubber::yes:
    I'd go no less than 18s for sure.
  10. Jan 21, 2021 at 9:14 PM
    98TT2.4
    Lazaro
    Florida
    I love my Advan Racing wheels! Super happy with everything about them. Now I'm going to get your thread started off. Come on all you street Tacomas on TW. The OP asks your help and suggestions for his 2nd gen single cab. Are we not gonna help him? So come on!:help::typing:
  11. Jan 22, 2021 at 4:54 AM
    mason33x
    Mason
    I got 15s on my truck with a 215 75r 15 tire
  12. Jan 22, 2021 at 5:47 AM
    98TT2.4
    Lazaro
    Florida
    Ok. I checked the overall tire diameter for 215 75 15. And it is 27.6" total diameter. If your trucks original tires are 215 75 15 and you want to maintain the speedometer correct and the final drive ratio in your differential without issues then Your new wheel and tire combination has to be around 27.5- 27.6 or so. That means you now know what is the tallest tire you can get. Then you for instance say your looking for a 17" wheel you would have to determine all the usual details like how wide you want the wheels, what's the offset that will work on your truck. How wide do you want your tires to be. Everything is important to have wheels that fit right. The bolt pattern,the center hub bore diameter. and the tires you choose should not exceed 27.7 inches in diameter. I always use tirerack.com to find all the information for tires sizes and all that stuff there. Say you want an 18x10. youd have to make sure the wheel fits first. Then look for tires you like that fit the wheel and are that magic 27.6" inches tall or the closest you can get to it. for instance a 10" wide wheel can fit a 245 wide tire all the way to 295 and greater. That depends if you like to have the tires stretched on the rim or not. That's why you have to know these things about what you want. The wheels you want, how you like the tires to look. Do you want a street high performance tires, or do you occasionally hit the dirt roads? Those are all on you to decide. That is what I did. I did it once and had no fitment issues because I did my homework first on it. Remember at tire rack.com you can see different size tires and how big they are. Hope that helps you some.
  13. Jan 22, 2021 at 5:58 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    If you’re looking for 5 lug wheels, go with the Tundra faux bead locks, those look great. Best place to find them is FB marketplace.
  14. Jan 22, 2021 at 6:08 AM
    98TT2.4
    Lazaro
    Florida
    See you got others helping you now. Thanks Devir7...
    hyrule_trd likes this.
  15. Jan 22, 2021 at 6:10 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I seen a 2nd gen 5 lug with aome negative offset wheels earlier this week those wheels poked out very far. Some machined and black directional design. Looked good, but looked like the fronts would rub when turning.
  16. Jan 22, 2021 at 6:12 AM
    98TT2.4
    Lazaro
    Florida
    Hope this gets good!:fingerscrossed:
    :popcorn::101010:
  17. Jan 22, 2021 at 6:13 AM
    mason33x
    Mason
    I’m thinking about getting a 235 65r 17
  18. Jan 22, 2021 at 6:13 AM
    mason33x
    Mason
  19. Jan 22, 2021 at 6:18 AM
    98TT2.4
    Lazaro
    Florida
    I'm not going to sway you in any way, it's your choice just dont rush it and be sure. I will tell you with 17s is nothing. I went up 4 rim diameter sizes from 14" to 18". you going from 15 to 17". that's up two sizes.:pout:
  20. Jan 22, 2021 at 6:32 AM
    98TT2.4
    Lazaro
    Florida
    To select the tires also you should know what you need. what is the weather like where you drive. Do you need dry handling grip. etc there are many different types of tires for whatever you need to do. For example I choose high performance summer tires with good resistance to aguaplaning. I live in Florida where we get heavy rains and you need good rain tires here. and the summer aspect gives me grip when it's hot so I got the tires perfectly matched for my need.
