5 lugger bs thread
Discussion in '5 Lug' started by Joels98taco, Dec 9, 2011.
  1. Apr 12, 2012 at 11:00 AM
    #341
    Taquito401
    Taquito401 Member
    Dan
    RI
    '11 RC MGM
    Hey guys, figured I'd ask for input here if you're willing. So, I need 2-3" of lift,mostly for looks/little extra clearance, BUT I don't want to sacrifice ride quality much if at all.
    I was ready to get the FatBobs kit (and add some upgraded front shocks to smooth things out) but ive heard from some unhappy campers here with noticeably lower,sagging rear ends with the FB kit. I know one guy fixed the sag by ADDING air springs,but that's another $300 on top. Fatbobs suggested solution - a custom leaf pack, $500 plz
    I'm looking to keep the cost around $500 for parts. What are the pros/cons of the FabTech 3" spindle kit (3" spindles front,AAL rear,new shocks all around... $565)? What are you guys running,happy with,not-so-happy with?
    I got me a burnin yearnin to get some lift under my Taquito.... HELP
  2. Apr 12, 2012 at 11:28 AM
    #342
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    i dont think there are fabtech spindles for 2011 tacomas. as far as lift goes you basically have three options short of long travel.
    the options are Fat bobs/ readylift, Total Chaos Midtravel UCA with coilovers or wait for the american motorsports lift spindle but the TC UCA and American motorsports spindles are way out of the $500 budget
    there is also body lift but most people do not recommend that on here
  3. Apr 12, 2012 at 12:48 PM
    #343
    alexmxman185
    alexmxman185 Keepin' it dirty in Texas
    Alex
    Waco, Texas
    08 toyota tacoma 2.7 4 cly 5 lug
    Black grille guard with mounted kc road lights, 31x9.5x15 AT on stock rims. My future mod list: new white front bumper, Fat Bobs 2.75 spacer lift with rear AAL, american racing Flat Black Rims, 32x11.5x15 BFG A/T, satoshi grille with road lights mounted behind it, 8000k HID for all lights, 1'' Body Lift, new window tint, blacked out headlights and taillights, custom hood scoop, weather tech floor liners, LED dash cluster replacement, Front bilstein shocks, 40 series flowmaster, paint all my badges black.
    get the fat bobs kit. It doesnt take away that much ride quality. Your only other current options are Long Travel or Mid Travel, which in turn you can look at spending 2-3 grand easily.
  4. Apr 18, 2012 at 2:40 AM
    #344
    Joels98taco
    Joels98taco [OP] Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    try drilling out the center of the bolt and hammer something into it to back it out
  5. Apr 18, 2012 at 2:59 PM
    #345
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    those high grade bolts dulled three bits. I was able to weld a nut to them both and back them out. Shes back on the road again and ready to bonz. I'm really glad it didn't ruin these fabtech lift spindles. :cool:
    I used the highest grade bolt i could find at ace (10.9) and loctite and will be checking those bolts religiously but i think i may step up to f911 hardware or arp studs.
  6. Apr 19, 2012 at 5:29 PM
    #346
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    grade 8 would be plenty for that truck
  7. Apr 20, 2012 at 8:53 AM
    #347
    87xjmike
    Folsom
    98 5lug 2rz
    well my 8.8 snapped first then the 10.9 went as it was the only bolt left steering the truck.
    metric grades are slightly different; a class 8.8 bolt has a yield strength of ~92,000 PSI while a true grade 8 bolt has a yield strength of ~130,000 PSI.
    metric 8.8 is similar to a grade 5, and metric 10.9 is similar in strength to grade 8.
  8. Apr 20, 2012 at 9:02 AM
    #348
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    Yeah I know all about the strengths. Nothing is as reliable as toyota bolts though Haha I mean at least compared to all the autozone or parts store bolts
  9. Apr 20, 2012 at 9:10 AM
    #349
    87xjmike
    Folsom
    98 5lug 2rz
    yeah yota's got some tough ass bolts
    I've been finding some good shit at this fastenal by my house too.
    they pretty much have every type of hardware ever needed.
    http://www.fastenal.com/web/home.ex
  10. Apr 20, 2012 at 3:37 PM
    #350
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    i order from allens fastners. quick deliveries :D and they come from needles az
  11. Apr 20, 2012 at 9:27 PM
    #351
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    whoever is running lift spindles on their first gen make sure your brake lines arent touching the spindle. found mine halfway cut. just a heads up
  12. Apr 20, 2012 at 9:49 PM
    #352
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    how far are you from the cali boarder?
  13. Apr 20, 2012 at 9:51 PM
    #353
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    seems decent for a 10" 2.5
  14. Apr 20, 2012 at 10:53 PM
    #354
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    I think a 50 t is a bit overkill lol and stock location no. Look into the rear icons
  15. Apr 20, 2012 at 10:54 PM
    #355
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    If you rear lt get 12s or 14s and run them outside the frame in a hoop
  16. Apr 21, 2012 at 9:33 AM
    #356
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    Well you are in sd my suggestion would be go down to national spring and have them make you a custom pack. It won't be cheap but its better than spending the money on front and rear hangers and shackles plus fab work worry about shock placement later. Get a hoop made and your set
  17. May 22, 2012 at 9:31 AM
    #357
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Noted... I can't remember are yours fabtech? They came with a dumb little clip to hold the lines that I just threw out with the box... Maybe should've kept it...
  18. May 22, 2012 at 9:37 AM
    #358
    87xjmike
    Folsom
    98 5lug 2rz
    just ordered these to go over the frame with my longer leafs...http://giantmotorsports.com/content/view/82/67/ Also got my 4:56 geared 7.5" axle in w/ 2" wheel spacers and relocated the shock mounts. Should have it all done in time to shred at the yerrington Desert race this weekend...woot
  19. May 22, 2012 at 10:42 PM
    #359
    TRDChris
    TRDChris Well-Known Member
    La Puente
    5 lugger
    H.I.D 6000K, 5% tint all around, black on blacked out rims(sprayed stock rims), fog light mod, deckplate mod, plastidipped bumper and interior, self made eyelids, window visors, clear corners, Billet grille, trd grill emblem
    Mine didn't come with a clip :mad:
  20. May 22, 2012 at 11:47 PM
    #360
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    yeah they are fabtech. mine did come with those clips too. tossed them cuz i didnt notice a place to attach them to but all i did was grind the sharpness of the spindle off and put it back on
