5 lugger bs thread
Discussion in '5 Lug' started by Joels98taco, Dec 9, 2011.
  1. Nov 18, 2012 at 12:47 PM
    #421
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    Rears
  2. Nov 18, 2012 at 1:15 PM
    #422
    disc0monkey
    I'm just a little blown away how people are claiming the 4x4 shock work on 5lug rear and don't mention that the collapsed lengths are different and you will need to lower your bumpstops.
  3. Nov 18, 2012 at 3:21 PM
    #423
    disc0monkey
    Yes blown away because if someone's carrying a load and hits a bump and breaks their shock leaving them stranded that is unacceptable and im just tryng to document this fact.
  4. Nov 18, 2012 at 3:37 PM
    #424
    disc0monkey
    So you're saying using your shocks as bumpstops is acceptable?
  5. Nov 18, 2012 at 3:42 PM
    #425
    disc0monkey
    I'm on my phone, but ill clear it up for you with a period.
    People are recommending half fast horse shit. It's the furthest away from even the standard we get from a stock truck.
  6. Nov 18, 2012 at 3:44 PM
    #426
    disc0monkey
    Obviously we have different levels of standards, so we'll just have to agree to disagree. Thanks for your comments
  7. Nov 18, 2012 at 3:52 PM
    #427
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
  8. Nov 18, 2012 at 3:59 PM
    #428
    Joels98taco
    Joels98taco [OP] Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    whoa whoa chillax dudes lol yes prerunner shocks will probably need to modify the bumpstops or shockmounts to avoid damaging the shocks
  9. Nov 18, 2012 at 4:07 PM
    #429
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    :D
    just like anyone that wants to mod a truck we always know what were talking about :)
  10. Nov 18, 2012 at 4:22 PM
    #430
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    but if your rjb who needs shocks or bumpstops right? and a frame notch ftw haha
  11. Nov 18, 2012 at 4:44 PM
    #431
    disc0monkey
    I meant different stds as I use the truck as a dependable DD and have toys for other shit. I'm just trying to beef this thing up.
    I have all the experience I need. Plus I spend the day putting on these shocks. Then welding a solution to drop my bumps then realized I didn't want to lose my up travel. I spent time putting the truck back to the way it was. I've researched my options and am not ready hack err up just yet and do a shackle flip / shock relocation.
    I found the fox resi have a tad less compressed length which would let me drop the bumps .25" and all will be fine except shipping back to the vendor and a 20% restocking fee
  12. Nov 18, 2012 at 4:58 PM
    #432
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    haha not giving you shit man. good for you for doing your research. the way i see it when modding bumps for a lifted truck its not bad because toyotas configuration of mounting their springs they go into a negative arc at full compression. the lower the bumps are the less negative arc they will sit at :thumbsup:
  13. Nov 20, 2012 at 10:40 AM
    #433
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    Time for new tires....
    I plan on lowering my truck about 3" -ish in the front and 3.5"-ish in the back.
    How tall and wide of a tire can I run on my stock wheels? and what would be the best way to lower it without spending real heavily?
    I'm thinking QA1s in front and maybe just blocks in the back?
  14. Nov 20, 2012 at 5:55 PM
    #434
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    bj flip and cut coils would be your cheapest
  15. Nov 20, 2012 at 7:45 PM
    #435
    DanglingFury
    Keith
    2006 4Runner 4x4
    What about the bell tech shocks or lowering springs for the front? I'm not crazy about the bj flip
  16. Nov 20, 2012 at 8:03 PM
    #436
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    check out some of the old threads on ct youll find what you need. theres so many options
  17. Nov 20, 2012 at 9:53 PM
    #437
    DanglingFury
    Keith
    2006 4Runner 4x4
    Yea that's what I've been doing. Too many options!
  18. Nov 21, 2012 at 9:28 PM
    #438
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    :eek:
  19. Nov 26, 2012 at 9:47 PM
    #439
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    anyone running a fabtech spindle with a mid travel front (ie. tc uca and icon coilovers)?
  20. Nov 26, 2012 at 10:04 PM
    #440
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    I had a fabtech spindle on my taco with the downey mid travel kit. It worked fine for medium duty off roading. I definitely pushed it to its limits and never broke anything (pure luck), my buddy that i bought the tacoma off of broke several lower ball joints with the fagtech spindle, but he had the ball joints mounted on the wrong side of the spindle.
    I'm also running a fagtech lift spingle on my 91 yota prerunner with total chaos ball joint kit and fOA coilovers and i've broken 3 steering knuckle studs. I ended up drilling through the entire spindle and putting a bolt all the way through the spindle in lieu of the bolt threading into it. MUCH stronger set up and haven't had an issue yet with a decent amount of jumping and high speed dirt use. Still all around a shitty spindle to offroad with as it mounts the uca too high and puts too much leverage on the uca pivot point. If you gusset the spindle, and gusset/weld the steering knuckle to spindle and drill through it for the knuckle bolts it'll hold up fine.
