5 lugger bs thread
Discussion in '5 Lug' started by Joels98taco, Dec 9, 2011.
  1. Oct 7, 2013 at 9:47 AM
    #661
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Got an answer from rocktoys, its a no go. Super sad cuz it was going to be dirt cheap. The stock xrunner LSD is retardedly expensive.
  2. Oct 7, 2013 at 10:12 AM
    #662
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    My '09 5 lug is now 5 years old. Can't remember a vehicle that has required so little maintenance in 110,000 miles. Still runs like a top.
    Love my truck.
  3. Oct 7, 2013 at 10:13 AM
    #663
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Nice, I have 170k on my 05. Only parts replaced have been the radiator and the waterpump.
  4. Oct 7, 2013 at 1:28 PM
    #664
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Sheesh, mine is double your age and same miles.
    Still equally reliable though, it had a new water pump put in before I bought it but that's the only failure of anything so far.
  5. Oct 7, 2013 at 4:41 PM
    #665
    Joels98taco
    Joels98taco [OP] Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    best bang for your buck:
    spindles up front, if your coils are shot replace them with stock replacement coils. v6 coils have a higher spring rate and are slightly bigger on the aftermarket(OD Is bigger) which will rub on the uca
    for the rear any aftermarket lift leaf pack will work as long as its made for 2"+ lift on a prerunner or 4x4.
    with spindles up front the front shocks can be a stock replacement as for the rear wit any significant lift all factory shock will be too short(only and inch or 2 of droop which will ride terrible. your best bet for rear shocks would be an aftermarket offroad shock valved for a 5 lug and custom mounted. with 2" or less lift stock length shocks will work but with the aal the ride will be slightly stiffter. aal on your current pack will help a bit but it will cause damage to the leafs eventually if they are too worn out
  6. Oct 7, 2013 at 4:49 PM
    #666
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    6 lug rear shocks wont work too long at full compression and are valved stiffer on rebound. and the eyelet on the 6 lug is bigger
  7. Oct 8, 2013 at 5:48 AM
    #667
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    Awesome info! Thanks for your input! :thumbsup:
  8. Oct 9, 2013 at 7:17 AM
    #668
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Girlfriends 2013 with 20k miles on it. She has already put that many miles on it since January of this year :eek: She calls it her grocery getter LOL
  9. Oct 9, 2013 at 7:57 AM
    #669
    MowTaco
    Kansas
    How's she like the 5 lug d-cab? Is it an absolute dog or can it get out of its own way?
  10. Oct 9, 2013 at 9:23 AM
    #670
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    I usually end up driving it when we go on a trip somewhere and it doesn't do hills well at all, it would probably pull hills OK in 3rd gear. Merging onto the freeway and stuff isn't a problem if it's flat. I haven't really gotten on it to see how it really does though. I'm used to my 1st gen double cab with the 3.4 :D
  11. Oct 9, 2013 at 10:40 AM
    #671
    KCDuran
    KCDuran Stormtrooper
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Icon/TC Mid Travel Kit, Kenwood Deck, Helix Audio System, BHLM (With Tinted Reflectors), Tinted Taillights, Satoshi Grill (color matched to super white), Stormtrooper sticker, Air Force sticker HUA! Re colored gauges (White numbers and ODO with Blue Needles) Magnaflow Glasspack Muffler, Stainless steel exhaust tip, 8k HIDs, LED Satoshi, Eye Lids, ARB locker (4.10 Gears), 8k FOG HIDs, LED Head Lamp, Tonneau Cover
    its all about tire size and what gears you're running for a 4banger lol I had 32s and stock gears for almost a year and it was a bit sluggish... but after I re geared to 4.10 it ran like normal... My next tacoma will be a DCSB TRD Sport super charged :devil:
  12. Oct 9, 2013 at 1:24 PM
    #672
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Yeah she has stock sized tires. It's not bad :)
  13. Oct 9, 2013 at 1:52 PM
    #673
    MowTaco
    Kansas
    True to a point, for get up and go around town that's fine but mine bugs the hell out of me out on the road, it just needs more power from the engine. I don't wanna re gear and have it spinning 4k RPMs at 75 (it's already screaming at those speeds).
    I still might regear sometime in the future, but for now 30's and 3.58 will have to do
  14. Oct 11, 2013 at 8:31 PM
    #674
    AeroKen
    AeroKen Well-Known Member
    Kendrick
    Littlefun, CO
    2wd Tacoma, 2.7L 5spd
    None so far
    Really thankful for this forum. Just discovered the woes of the 5-lug difference and how we have those dang-nibbiting black boxes in our stock front wells. Well, I am most likely just going to do the simple black box mod and slap on the biggest tires (30x9.5r15) it will take. See how much the 1.57" extra clearance does for me over time. Probably is plenty. Was also considering the fat-bob mod, but after watching the installation video on readylift (for spacers and aal), I decided, I'll go ahead and just wait until it's time to replace the above tires before seriously considering more lift, which I'm not even getting until it's time to replace the 215/70s I'm currently rocking.
    Who gets paid to come up with these dead-weight parts for our vehicles anyway?
  15. Oct 11, 2013 at 8:36 PM
    #675
    KCDuran
    Kyle
    South Jersey
    5 Lug'n 4 banger
    super charger... lol problem solved
    yeah that stupid black box made no sense... all that was in mine were leaves and other debris haha
  16. Oct 13, 2013 at 10:06 PM
    #676
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Looking to bring the rear lift up a bit on the truck. Still looks a little bro'd out. Still confused and pissed about the ICON 3 leaf AAL. Not looking to go the LT route like I see on Stupid and Nakeds truck, but I need to do something.
    I can get the AAL for one of the fatbobs/readylift kits or I can get a whole new leaf pack. Bout it, right? Which 5 lug is running the custom Alcan pack...???
    On shackles....a longer one on the current 05+ SUA design would actually lower the truck. The reverse of that...shorter shackles, in theory, would lift it?
    Stupid wheeling meets, got the mod/redoing my truck so it looks less retarded blood flowing again.
  17. Oct 14, 2013 at 7:45 AM
    #677
    MowTaco
    Kansas
    Your idea on shackes isn't fundamentally wrong, but in reality it would be pretty tough to make shackles any shorter. Plus I think you'd lose a lot of your flex by shortening the shackles.
  18. Oct 14, 2013 at 3:46 PM
    #678
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Yeah, not gonna mess with em. I gotta do something however. Which 5 lug is running the custom Alcan pack, you know?
  19. Oct 14, 2013 at 4:23 PM
    #679
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    The 2nd gen 5 lugs are still SUA correct?
    i'm not sure that the 3 leaf AAl will lift you.
    I think the most effective way to get lift would be to make the truck SOA, then if you need more lift get a AAL.
    Or do a shackle flip.
  20. Oct 14, 2013 at 7:41 PM
    #680
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Yeah, found that out after installing the ICON aal. Had the pack reached 2", wasn't enough. Gained about an inch in the rear.
    Think I'm gonna pull the pack back off and take it to the spring shop again, tell them to arch em to provide 1.5-2" of lift.
