5 lugger bs thread
Discussion in '5 Lug' started by Joels98taco, Dec 9, 2011.
  1. Oct 29, 2013 at 10:28 AM
    #721
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Those look awesome!^ Swapping bucket seats into my truck was the best thing I've done to it so far.
  2. Nov 4, 2013 at 6:58 PM
    #722
    KCDuran
    KCDuran Stormtrooper
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Icon/TC Mid Travel Kit, Kenwood Deck, Helix Audio System, BHLM (With Tinted Reflectors), Tinted Taillights, Satoshi Grill (color matched to super white), Stormtrooper sticker, Air Force sticker HUA! Re colored gauges (White numbers and ODO with Blue Needles) Magnaflow Glasspack Muffler, Stainless steel exhaust tip, 8k HIDs, LED Satoshi, Eye Lids, ARB locker (4.10 Gears), 8k FOG HIDs, LED Head Lamp, Tonneau Cover
    my build, last page. bumper is finished
  3. Nov 5, 2013 at 2:41 PM
    #723
    KCDuran
    Kyle
    South Jersey
    5 Lug'n 4 banger
    not really, I got 600lb coils when I went MT so there's really no difference, but I can't give you an exact answer because I didn't measure it xD but I know if I was stock it wouldn't have worked
    But thanks :)
  4. Nov 5, 2013 at 5:42 PM
    #724
    Nathan
    Nathan Well-Known Member
    Nathan
    Frederick County, MD
    2010 5 lug single cab
  5. Nov 12, 2013 at 8:04 AM
    #725
    Scrider424
    Scrider424 Well-Known Member
    Anthony
    San Luis Obispo, CA
    2018 DCSB 2.7l
    Question for everybody. Has anybody had any irregular tire wear issues after changing to a wheel with different back spacing? I started feeling steering wheel wobble around like 55-65 mph around the same time as having new wheels put on. So I took them to get rebalanced thinking this was the problem. This did not fix the problem so I took it back again and they examined the tires and showed me that I had cupping along the inside edge of my left front tire and a little on the back right tire. Is this just a coincidence that it happened the same tire as mounting new wheels? Or is it most likely because of the wheels. They are summit racing wheels 15x7 3.75 bs. Any input is appreciated.
  6. Nov 19, 2013 at 2:11 PM
    #726
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    when you run a different offset or a different width wheel you run the risk of changing the "scrub radius" (look it up) in a way that can adversely effect tire wear.
    This is because you're changing how the weight of the truck is supported by the tire and suspension geometry. From the factory the load is going to be concentrated on the middle of the tire, but when you start changing wheel and tires dimensions, it sometimes (not always) can screw up all of the work that the engineers did and move the load of the vehicle to the outside or inside of the tire instead of the middle.
  7. Nov 22, 2013 at 8:19 AM
    #727
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    This^
    Rear could be because of axle alignment, as for the fronts and the wobble. Did you go oversized offroad tires? If so sounds like you need to get your tires force matched and balanced staticly. As for the wear on the front, again alignment issue probably due to improper toe.
  8. Nov 22, 2013 at 8:20 AM
    #728
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Will be selling my Struts, have roughly 8 months of driving on them, the higher rate stock height springs, and the 1" alum spindle spacers and hardware for sale. Getting the adjustable coil overs, will not have use for these items now. See attached for any questions on where spacers go or condition of strut and coil.
    100+ shipping for the struts
    150+ shipping for the springs
    120+ shipped for the spacers
    Items will be coming from Tempe, Az 85281 if you want to calc your shipping cost. I am willing to part items out. PM if interested.
  9. Dec 22, 2013 at 10:28 PM
    #729
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Custom UCAs? Did you fab this up yourself?
  10. Dec 23, 2013 at 7:24 AM
    #730
    Phil Dammit
    Your Mom
    Tempe, Arizona
    No those are DJM drop arms, Granted I could have done a better job as I had to do quite a bit of grinding to get the new balljoints to fit. :(
  11. Dec 24, 2013 at 4:42 PM
    #731
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    The worn out rubber piece is my upper ball joint right? The cover for it anyway. Is there a good place to get these? Oreilly wants $13 for one brand and around $70 for moog brand I don't understand why there is such an extreme difference in price.:confused:
  12. Dec 26, 2013 at 7:17 AM
    #732
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Quality my son, quality
  13. Dec 26, 2013 at 3:07 PM
    #733
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Yup that be it. Can't help you on getting a new one, other than oem is probably your best bet
  14. Dec 27, 2013 at 5:51 AM
    #734
    Phil Dammit
    Your Mom
    Tempe, Arizona
    The moogs should be greasable
  15. Dec 27, 2013 at 1:51 PM
    #735
    Joels98taco
    Joels98taco [OP] Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    moogs are very nice and have the lifetime warranty. and yes they are greasable. seem much better made than the oem imho
  16. Dec 27, 2013 at 2:14 PM
    #736
    Phil Dammit
    Your Mom
    Tempe, Arizona
    GTFO of the dubs, your kind aint welcome here
  17. Dec 27, 2013 at 2:16 PM
    #737
    Phil Dammit
    Your Mom
    Tempe, Arizona
    GET THE FUCK OUT of tacoma world, your kind, as in you, are not welcome in/on/or around here.
  18. Dec 27, 2013 at 2:17 PM
    #738
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    damn 5 luggers are hostile :popcorn:
  19. Dec 27, 2013 at 2:20 PM
    #739
    Phil Dammit
    Your Mom
    Tempe, Arizona
    listen here sugartits, I run these parts now.
  20. Dec 27, 2013 at 2:24 PM
    #740
    richardbui23
    Richard
    Arlington Texas
    Stacy
    HAHAHAHAHAHAHA HE SAID SPOONDICK
