5 lugger bs thread
Discussion in '5 Lug' started by Joels98taco, Dec 9, 2011.
  1. Jan 10, 2015 at 2:16 PM
    #961
    alexkontos17
    alexkontos17 Well-Known Member
    Alex
    Orlando
    97 tacoma
    How much are long travel kits and what do you mean by glass?
  2. Jan 10, 2015 at 2:22 PM
    #962
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    :thumbsup:
    If you have to ask...
    This^
  3. Jan 10, 2015 at 2:40 PM
    #963
    alexkontos17
    Alex
    Orlando
    97 tacoma
    could I use a Coil spring from the v6 model combined with a 3" lift spindle in the front or would that be asking for trouble with ball joints
  4. Jan 10, 2015 at 2:43 PM
    #964
    alexkontos17
    Alex
    Orlando
    97 tacoma
    haha sounds like I'm going to avoid that route...
  5. Jan 10, 2015 at 5:28 PM
    #965
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    It would probably ride badly dunno about the ball joints. I had a spindle lift on mine and I couldn't have been happier with that. It makes the stance wider which looks good imo but I destroyed one of my already cut fenders with a tire off roading. So I put glass up front, you could probably fit 33's with spindles, heavier springs, glass, bumper and a BFH
    Probably a good idea unless youll use it
  6. Jan 10, 2015 at 7:15 PM
    #966
    alexkontos17
    Alex
    Orlando
    97 tacoma
    Problem is spindle lift can only give me 3.5" max and that won't get me anywhere near 33s thats why i was wondering about the springs. I know how I'm going to do the rear the front is just the issue, i figure as long as i get enough clearance i won't have to worry about the fenders
  7. Jan 11, 2015 at 9:47 AM
    #967
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    2010 Tundra
    went from my 6lug LT 2nd gen to a 97 ext 5 lug.
    sup guys :wave: :D i love this little truck already and havent owned it for more than 12 hours
  8. Jan 11, 2015 at 4:50 PM
    #968
    Fubarjonny
    Fubarjonny Well-Known Member
    Jonathan
    Orange County, CA
    5-LUG?
    Welcome man! What made you switch over?
  9. Jan 11, 2015 at 11:39 PM
    #969
    tacokid09
    Brian aka B-Lang
    San Luis Obispo, CA
    2010 Tundra
    i was over the 12 mpg and having to get new tires every 8 months. Also i needed something more practical for when i leave the local JC and to pay future student loans with.
  10. Jan 18, 2015 at 5:18 PM
    #970
    Canadian Taco 705
    Canadian Taco 705 Well-Known Member
    Windsor Ontario Canada
    2010 Black 2.7L 2WD Debadged
    Interior: Hardwire GPS Hardwire USB x2 Extra Cig Lighter Mag Light Mod x2 Exterior: Debadged TRD hood Bull Bar Halo Headlights 6000K Lumens HID 50% Windshield Tint 5% Window Tint
    Im praying this thread is still active! but ill give it a try. Can you guys please take a look at a thread i posted regarding a potential 2nd gen 5 lug lift.
    I need input before i order parts
  11. Feb 8, 2015 at 5:13 PM
    #971
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
  12. Feb 9, 2015 at 3:10 PM
    #972
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Five (5) lug noob here. I don't see a sticky FAQ for 5 lugs.
    Can someone tell me in 20 words or less what 5 lugs is about and why some Toyotas have 5 and some have 6? Is this a total after market conversion thing or do some come from the factory that way?
    Ok and I'm counting so don't waste my time with 21 or 22 words or some long winded explanation like that ;)
  13. Feb 9, 2015 at 3:15 PM
    #973
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Different suspension from 5 lug and 6lug same axles in rear diff hubs and comp dif spindles and control arms up front. Lugs are dependent on sus and both are factory option.
  14. Feb 10, 2015 at 9:24 PM
    #974
    Joels98taco
    Joels98taco [OP] Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    be ready to spend 5000+ with lt. 33s on a 5 lug is a bad idea imo. hubs are weak and ball joint brackets are weaker. I suggest spindles and a maximum of 31" tires and plenty of clearancing. that big a tire will wear down stock components much faster and cost you more in the long run.
  15. Feb 11, 2015 at 9:44 AM
    #975
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Nice. Now I am an expert. Thank you PD ;)
  16. Feb 17, 2015 at 1:31 AM
    #976
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    5 lugs are gay. So is Phil.
  17. Feb 17, 2015 at 6:14 AM
    #977
    Phil Dammit
    Your Mom
    Tempe, Arizona
  18. Dec 10, 2015 at 1:51 PM
    #978
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    Dead Thread Revival.
    Thanks for the info on the 4.11 non-prerunner axle replacement 'gearing fix' for the 5-lug manual.
    SleazyPetey likes this.
  19. Dec 14, 2015 at 3:59 PM
    #979
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    Since this thread was already bumped up....
    If you mean coils from a v6 "prerunner" models no, they use a coilover so not compatable at all.
    I run 33 12.50's on my 99 5 lug but it has the TC LT kit and spindle in front and the rear is a whole different project.
    Regeared with 4.11's and with bunch of HP gains through everything short of boosting the truck does just fine but I always still wish I had more. Not horrible at all though, Ive done plenty of ligbt towing and everything.
  20. Jan 22, 2016 at 9:27 AM
    #980
    Mexican5Lug
    Mexican5Lug Member
    99 Tacoma 2.4 L manual
    3" Fabtech lift spindles 2" lift schackles
    I too have a 5 lug 99 that I lifted and put 30's on. I need new diff gears. The tire calc on here recommends 4.11 ratio. I've called a few places and no one has it. Where have you guys bought yours?
