5 lugger bs thread
Discussion in '5 Lug' started by Joels98taco, Dec 9, 2011.
  1. Dec 23, 2011 at 9:47 AM
    #81
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    thanks for posting the pic Joel. Time to throw your sway bar in the scrap steel pile man...
  2. Dec 23, 2011 at 6:48 PM
    #82
    Joels98taco
    Joels98taco [OP] Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    i know but my brother uses my truck too and he likes turning corners fast so ill take it of when my brother gets his truck lol. how does yours handle without the sway bar?
  3. Dec 26, 2011 at 7:55 AM
    #83
    87xjmike
    Folsom
    98 5lug 2rz
    I honestly think its kinda hard to notice with a-armed/steering rack equiped trucks. But i baught this truck without the sway bar so i can't comment on the difference. It handles good though.
  4. Dec 26, 2011 at 2:29 PM
    #84
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    oh thats right huh lol. and im sure you have higher spring rate and stiffer shocks than me
  5. Dec 26, 2011 at 3:08 PM
    #85
    87xjmike
    Folsom
    98 5lug 2rz
    My front bilstein shocks that slide into the coil-over threaded sleave thingy are for a stock f-250. The stiffer valving for the bigger chasis really works well for handling without a sway bar and higher speed offroading.
  6. Dec 26, 2011 at 4:45 PM
    #86
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    WTF? 5 Lug/4 Cyl gets moved to the bottom?
    Haters. :p
  7. Dec 26, 2011 at 6:35 PM
    #87
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    i thought those were the downey coilovers? :confused:
  8. Dec 26, 2011 at 6:36 PM
    #88
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    i know wtf?? haha they see we are getting famous around here so they moved us down :cool:
  9. Dec 26, 2011 at 7:38 PM
    #89
    87xjmike
    Folsom
    98 5lug 2rz
    everything i have is from downey yes, they used a f250 shock for the taquito kit, slid a coil and threaded plastic sleeve over the shock and called it a coilover kit...
  10. Dec 26, 2011 at 10:16 PM
    #90
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    thats pretty sick haha :D have you cycled the front end to figure out travel numbers?
  11. Dec 27, 2011 at 12:11 AM
    #91
    87xjmike
    Folsom
    98 5lug 2rz
    no i haven't. Just tried to flip my bj on the driver side back to the top of the spindle and it royaly fucked my camber to / \. I can't bring my upper a-arm back in toward the bucket as i re-located and re-welded my upper a arm support shaft to close to the bucket. I just put the bj back under the spindle as i need to drive it to work in the morning... Fuck. i put a lot of work into dialing this suspension in becasue the ball joint was on the wrong side of the spindle and now i have to reverse everything i've done.
    At least i Got my starter re-built tonight.
    Hasn't hesitated with starting yet...although it would only seem to hesitate to start when i was driving some chick around to properly kill a wee bit of pride.
  12. Dec 27, 2011 at 12:46 AM
    #92
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    It's got me all off. I keep clicking on "Wheels and Tires". I was trying to get in this thread and post, clicked on 3 different threads by accident before I finally got over here.
  13. Dec 27, 2011 at 10:30 AM
    #93
    Steve J
    Steve J Steve J
    Canyon Country Ca
    12 Access Cab 4x2
    Avid front light bar, Avid bolt on sliders, Avid rear bumper protector, T-Rex grill & bumper insert. Still lots to do though.
    Real quick 5 lug question if anyone knows. I have a deal for some 5 lug wheels right now bu need to know what the lug spacing is for the Tacos. I have a 2012 5 lug. I am at work right now & can't get out to the truck to measure it up. ANYONE?????Help quick. Please
  14. Dec 27, 2011 at 10:42 AM
    #94
    HypnoTaco
    HypnoTaco Well-Known Member
    Bay Area, CA
    2011 Tundra DC 4x4 4.6L
    Bolt pattern is 5 x 4.5
  15. Dec 27, 2011 at 10:46 AM
    #95
    Steve J
    Steve J Steve J
    Canyon Country Ca
    12 Access Cab 4x2
    Thanks Hypno
  16. Dec 27, 2011 at 5:53 PM
    #96
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    did you double shear the uca??
  17. Dec 28, 2011 at 11:08 AM
    #97
    Poot Klopp
    Poot Klopp Well-Known Member
    Ben
    New Jersey
    2024 Bronze Oxide TRD OR
    anyone got a good DIY for rotor and pad change for 2nd gen 5 lug.
  18. Dec 28, 2011 at 3:07 PM
    #98
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    I don't think there is one around. It's pretty simple though, I'll try to give a little synopsis.
    -Raise/Support Truck.
    -Remove Front Wheels.
    -Remove the 2 bolts holding the caliper body to the bracket. More than likely be 14mm bolts.
    -Remove the caliper body. Might use a screwdriver to wiggle it loose.
    -Remove old brake pads from caliper bracket. Pay attention to any special way they may be placed.
    -On the backside of the rotor, there are 2 bolts that hold the caliper bracket to the knuckle. Remove them, probably 17mm bolts.
    -Remove caliper bracket.
    -Rotor may or may not be free. Smack it with a hammer. Worst case, there are 2 little threaded holes around the lug holes, find a bolt that fits those and tighten bolts. Creates a jacking force to free the rotor from the hub.
    -Get a Silicone based brake lube, NAPA, Sil-Glyde I think it's called.
    -New Rotor: Completely clean new rotor, brake cleaner or soap and water.
    -Install rotor
    ---**Tip: Use a lug nut threaded on the stud to hold the new rotor on the hub while assembling the rest of the system.
    -Lube brake hardware and slide pins.
    -Install caliper bracket, 2 bolts, probably 17mm.
    -Install new brake pads.
    -Use an actual brake piston tool, or a large pair of channel-locks and squeeze the piston back into it's bore until it's flush.
    -Lubricate brake pads.
    -Install caliper body to bracket with 2 14mm bolts (probably)
    -Repeat for other side.
    -Install wheels and tighten to 80-85 Ft Lbs.
    -PUMP UP THE BRAKE PEDAL UNTIL IT'S HARD BEFORE YOU EVEN PUT THE KEY IN THE IGNITION.
    -Test drive. Maybe 5-6 full stops from 30-35 MPH. Bed the brakes in.
    I do no know torque value for the caliper bolts, either tighten at your own risk or look up specs.
    Hope it helps!
    Railwayrog likes this.
  19. Dec 29, 2011 at 11:47 AM
    #99
    Poot Klopp
    Ben
    New Jersey
    Thank you
  20. Dec 30, 2011 at 6:48 AM
    #100
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Tires, hmm.
    Like my current tires, destination A/T's. But when it comes time to get new ones or I got enough money saved up, I want something a little more aggressive, but not into the M/T range.
    I like the design and aggressiveness of the DuraTrac, plus the better winter/wet handling. I've also ridden in a Tacoma with them and they performed well. That said, I am really anti-goodyear tires. Sidewall issues, balance and roundness issues.
    Been a little hard to find a tire that compares to it. I did find a Cooper tire. Coooper Discoverer S/T Maxx. The sizes at this point are very limited and there is NOTHING in a 15" tire and what is made is E rated.
    Any suggestions?
