5 Luggers, After Market Rims?
Discussion in 'Wheels & Tires' started by gsm, Mar 22, 2008.
  1. Mar 22, 2008 at 10:38 PM
    gsm
    gsm [OP] Well-Known Member
    Raleigh, NC
    08 Tacoma Regular Cab, 2.7L, Impulse Red Pearl
    DIY OEM Fog Lights on anytime, DIY OEM Cruise Control, Removed 2ndary Air Filter, Rear Speakers Mod, Traction Bar/Helper Spring Mod, Red Brake Drums and Rotors, Stainless Steel Exhaust Tip, Door Sill Protectors, Taco Bed Mat, Custom Front Mud Flaps (Mudguards), TRD Bucket Seats (pending)
    What rims do you other 5 Luggers have? Where did you get 'em? Pics if you have them handy plz.
    With the limited selection available out there it's hard to choose, or find one I really like. I don't plan to lift and don't want to kill the mpg. Hoping to find nice 16" rims, possibly for some Goodyear Fortera 215/70-16s or 225/70-16s I've been looking at. Even factory sized 15s would be better than the std steel rims that come factory.
  2. Mar 23, 2008 at 8:29 AM
    gsm
    Raleigh, NC
    Correct me if I'm wrong, but from my research I believe prerunners and xrunners are 6 luggers.
  3. Mar 23, 2008 at 3:38 PM
    spp
    spp OC, Kalifornia
    OC California
    OK you're wrong.;)
    Pre-Runner is 6 lug 2WD version of the 4x4 AND x-RUNNER isV-6 version of the 5 lug with flares and stuff.
  4. Mar 23, 2008 at 8:51 PM
    gsm
    Raleigh, NC
    Thanks.
    That could be true, I'll have to look :eek: . I based my info off the toyota web site and the 16" wheel picture that is displayed for the x-runner showed 6 lugs. Guess it's probably just a generic picture of the rim.
    Anyone else out there have 16" wheels on their 5 lugger?
  5. Mar 25, 2008 at 9:03 AM
    spp
    spp OC, Kalifornia
    OC California
    X-runner comes with 18" wheels. It IS true. Look at the last picture here.
    http://www.toyota.com/tacoma/photo-gallery.html
    That is a speedway blue X-runner. 5 lugs very visible.
  6. Mar 25, 2008 at 9:29 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    not to beat a dead horse...here's homer j's x-runner
  7. Mar 25, 2008 at 9:57 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    :deadhorse:
    Nice job guys! I would have put money on the X-runners having 6 lugs. :eek:
  8. Mar 25, 2008 at 4:13 PM
    spp
    spp OC, Kalifornia
    OC California
    Damn! If I'd known that I would have bet you first.;)
  9. Mar 25, 2008 at 5:05 PM
    gsm
    Raleigh, NC
    OK, the horse is dead :D. Thanks for your inputs.
    Anyone else have ideas for aftermarket wheels? Myself I'm still in search for a set of good 16" rims.
  10. Mar 26, 2008 at 3:28 PM
    spp
    spp OC, Kalifornia
    OC California
    Rims from a Camry or Sienna should fit. I think there are16 and 17's out there.
    For those who might say put CAR wheels on a TRUCK?:eek:
    Check the weights on the Camry and Sienna.;)
    Camry V-6 is almost as heavy as a 5-lug and the Sienna IS heavier.
  11. Jul 30, 2009 at 12:41 PM
    grizzlytravis
    grizzlytravis Well-Known Member
    tampa florida
    08 taco 5 lug
    3inch ready lift, tint, foglights,BHLM,dumped exh,rims,tires, and a dent in the bumper
    i have 15x8 cragar soft 8's i dont know what style you want but here it is [​IMG]
  12. Jul 30, 2009 at 12:49 PM
    TacoTycoon
    TacoTycoon Well-Known Member
    Justin
    Hayes, VA
    07 TRD Sport 4WD Indigo Ink
    Bilstein 5100 Coilovers, Diff Drop Kit, TSB AAL, 285/70/17 BFG A/T Tires, 17X8 Helo HE835 Wheels, Rear Bilstein 5100s, Dual Flowmaster 50 series, TRD CAI, TRD Front Seat Covers, Rear Suspension TSB, 35% Tint, Redline Hood Struts, MagLite Mod
    holy thread revival batman!
  13. Aug 5, 2009 at 12:50 PM
    otter
    otter Well-Known Member
    Rob
    MI
    09 4 cyl Reg Cab
    I'm finding that the wheel size I'd want for my 5 lug Taco simply does not exist, and it's really frustrating. The whole problem is with the offset/backspacing. The style of wheel I like is similar to Crager Soft 8s posted above, however, rims like that are only made with an offset of +6 or lower. Based on my measuring, anything lower than a +20 or so will stick out from the fender, risk rubbing, and not be street legal. Most aftermarket wheels with a positive offset are designed for sport/compact cars and don't look right on a truck. :p
  14. Aug 5, 2009 at 2:58 PM
    grizzlytravis
    tampa florida
    08 taco 5 lug
    i have the cragar soft 8's and they stick out of the fender maybe an inch or so the only rubbing i had was very minimal on the caliper but you can either A- grind the OUTSIDE of the caliper about a hair, or B- ( which is what i did ) drive it around the block and the rim will grind the caliper down which isnt going to hurt a thing.[​IMG]
  15. Aug 12, 2009 at 7:36 PM
    otter
    Rob
    MI
    09 4 cyl Reg Cab
    Thanks a bunch for posting that view. I assume those are the +6 offset Cragars? Chances are that these are the wheels I'm going to go with next year, along with a 235/70/15 tire.
  16. Aug 13, 2009 at 9:37 AM
    grizzlytravis
    tampa florida
    08 taco 5 lug
    i think the backspace was 4.5 or somethin and those are the 235's so that should work without a lift
  17. Aug 13, 2009 at 11:34 AM
    otter
    Rob
    MI
    09 4 cyl Reg Cab
    Last question, 7" wide?
  18. Aug 13, 2009 at 11:46 AM
    grizzlytravis
    tampa florida
    08 taco 5 lug
