5 month old truck with dead battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2013TacoLTD, Feb 27, 2014.
  1. Feb 27, 2014 at 8:38 AM
    2013TacoLTD
    2013TacoLTD [OP] Well-Known Member
    Dennis
    Mckinney, TX
    13 Tacoma Limited V6 4X2
    Radio On Mod, Complete new stereo with 10" subs, Truxedo bed cover, GT-MAT through doors and rear cab.
    Drove my truck last night and it started no issues. This morning when I opened the door, the built in alarm started going off. I turned off the alarm and went ot start the truck and only got the click click click. I put a charger on it (wife's car is a Camry hybrid and I have no idea and do not want to risk getting a jump from that) and had to wait 20 minutes before it would turn over. The truck is garage kept and was about 45 degrees in there this morning. Nothing was left on that I could see in the truck.
    I am going out over lunch to see if it starts and to take it to Autozone to have the alternater tested.
    Is there any warranty on a battery from the factory??
  2. Feb 27, 2014 at 8:43 AM
    spencer44306
    spencer44306 Well-Known Member
    Spencer
    Upstate Ny
    13 TRD Sport 4x4
    Take it to the dealer...
  3. Feb 27, 2014 at 8:45 AM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    If the truck is brand new from the dealer, it has to still be under warranty. They should solve the problem for you. Moght be the alternator. Might be the wiring from the battery to alternator. I have had the wiring the wiring be the issue on a previous truck of mine.
  4. Feb 27, 2014 at 8:56 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Warranty
  5. Feb 27, 2014 at 11:52 AM
    2013TacoLTD
    Dennis
    Mckinney, TX
    Went to Autozone (the truck started as normal in the parking lot at work) and they tested the battery alternator/battery. Battery was great, alternator was pushing 13.6v at idle (that is a little low??). Both battery terminals are secure with no corrosion.
    Guess I will keep an eye on it, but I cannot think of another problem it could be :/
  6. Feb 27, 2014 at 12:20 PM
    MJR
    MJR Well-Known Member
    Mickey
    Salado, TX & Santa Rosa Beach, FL
    ‘23 LIMITED 4wd NIGHTSHADE & ‘23 T4R TRD ORP
    Removed factory bed cover and installed UnderCover Elite. Added LOCKERDOWN console safe.
    We get that ever so often in the dealership. That is the reason they put a warranty on them. It happens. Have had it happen the day after it comes off the delivery truck.
  7. Feb 27, 2014 at 12:31 PM
    NvrSumR
    NvrSumR Well-Known Member
    Jeff
    Colorado
    Didn't you just install a premium sound system? Might have something to do with it?
  8. Feb 27, 2014 at 1:31 PM
    2013TacoLTD
    Dennis
    Mckinney, TX
    Installed a few months ago. No issues before this morning or since.
  9. Feb 27, 2014 at 2:01 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Not saying that it definitely is, but it is possible that it is taking a toll on it. Is the amp run off a capacitor or directly off the battery?
  10. Feb 27, 2014 at 3:19 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The dome light well drag the battery down over night the doors close hard.
  11. Feb 27, 2014 at 3:23 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    ^ that
  12. Feb 27, 2014 at 3:33 PM
    Faryota
    Faryota Well-Known Member
    Mic
    Ridgefield, WA.
    13, 4x4, long bed, Sport, Debad
    6" BDS lift in front, warn winch, AFE cold air intake & exhaust, Body Armor Rear bumper, Tuffy in bed storage box, DZ bed mat, ARB front bumper & Warn winch w/light kit, Husky floor mats, dash mat,
    My 2013 was less then 3 months old when the battery started giving me trouble...dealer gave me the gears because I had installed a winch!? Wasn't worth my time...went and got a new battery installed from Les Schwab tires!!! They tested it and said two cells were out!!!!
  13. Feb 28, 2014 at 4:53 AM
    2013TacoLTD
    Dennis
    Mckinney, TX
    Power is directly off the battery. I tested the line from the HU that tells the amp when to turn on and that is functioning correctly.
  14. Feb 28, 2014 at 5:05 AM
    moondeath
    Pa, Gardners
    The reason for the capacitor is to take most of the work load off the alternator. The capacitor provides the brunt of the power to the amp helping to reduce fatigue on the vehicles power system.
  15. Feb 28, 2014 at 7:14 AM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    2010 Sport w/ 61,000 just replaced the original OEM battery Tuesday :)
    I would raise hell it only being 5 months old
  16. Mar 24, 2014 at 10:07 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Depends on the temperature and the battery's State-of-Charge. You need good and clean power and ground connections between your healthy charged battery and starter before the engine will crank.
