5 quarts in rear diff of '23 TRD OR?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rybern, Apr 30, 2024.
  1. Apr 30, 2024 at 3:17 PM
    rybern
    rybern [OP] Well-Known Member
    N Alabama
    2025 TRD OR & 2000 SR5
    I just changed fuild in the rear diff of my '23 TRD OR and was expecting to add 4.2qts to fill it to the bottom of the fill plug. It took nearly 5 qts and I didn't spill any. Is it supposed to be 4.2 qts or filled to the bottom of the fill plug?
  2. Apr 30, 2024 at 3:27 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Inspection standard is within 5mm of the fill port level. Since the oil is in the whole length of the axle housing, 5mm tolerance in level accounts for a lot of volume.
    Stevie17 and RustyGreen like this.
  3. Apr 30, 2024 at 3:34 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Whoa. Quarts?
  4. Apr 30, 2024 at 3:37 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I got in about 4.75L. Part of it is because, as explained above, the spec is actually to 5mm below the hole. Although filling to the hole won’t hurt anything.
    Stevie17 likes this.
  5. Apr 30, 2024 at 3:40 PM
    rybern
    N Alabama
    Yep, five 1 qt bottle are empty. I can drain out and catch half a qt or so which would get it closer to the 4.2qts. I've read where overfilling isn't good.
  6. Apr 30, 2024 at 3:45 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Not needed. The inspection standard is by level, as volume can vary with axle mfg tolerances. Overfilling (which you aren't doing) doesn't hurt anything either, as lubrication depends on an oil slinger in the diff whipping up oil as the diff turns. There's no pump to cavitate.
    joba27n likes this.
  7. Apr 30, 2024 at 3:51 PM
    BLtheP
    Plano, TX
    Truly overfilling isn’t good, but you’re not doing that by going to the hole. It won’t matter.
    Stevie17 and joba27n like this.
  8. Apr 30, 2024 at 4:02 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    5 quarts sounds right, my buddy (a tech) was surprised how much it took, he had to rob some from his neighbor to finish filling.
  9. Apr 30, 2024 at 4:03 PM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    It doesn't surprise me... I did both diff's and the TC about a month ago. First time since I bought it new. I remember thinking 'Wow. is the rear diff ever going to fill up?'... Mine took a bit over 4.5... But I didn't worry about it, I just slept better knowing it was filled up to the fill plug.
    willtill and OZ TRD like this.
  10. Apr 30, 2024 at 4:39 PM
    rybern
    N Alabama
    Thanks guys. I appreciate the numerous responses.
    RustyGreen likes this.
  11. May 1, 2024 at 6:53 PM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Mine took 4.0 qt
    CrashZone likes this.
  12. May 2, 2024 at 3:20 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    My exact sentiments when I did mine recently.
  13. May 2, 2024 at 3:21 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    are you sure your truck was level when you filled this or was the rear higher than the front?
  14. May 2, 2024 at 9:20 AM
    gen2eng
    gen2eng Well-Known Member
    Indiana
    2022 TRD Offroad DC 4x4
    Same thing here. Did a change at 31K miles and it took just under 5 of the squeeze bags of Valvoline on a level surface. Had to make another run to get enough for the front diff.
    I changed at 15K as well because I tow, had the same issue, but thought it was because I spilled a bit.
    rybern[OP] likes this.
  15. May 2, 2024 at 9:21 AM
    gen2eng
    Indiana
    Also, I thought I saw somewhere that the OR / E-Locker diff takes more oil than a diff without the locker.
  16. May 2, 2024 at 4:20 PM
    rybern
    N Alabama
    Ah, I forgot about that. I actually did have the rear jacked up some to make it easier to fill. But the wheels were on level ground.
  17. May 2, 2024 at 4:50 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    That could have thrown it off a bit
    CrashZone and mquibble like this.
  18. May 2, 2024 at 7:11 PM
    rybern
    N Alabama
    I'll pull the fill plug tomorrow and see if anything comes out. I'm doing the front diff tomorrow.
  19. May 3, 2024 at 1:52 AM
    Pungo1
    Pungo1 Well-Known Member
    Mark
    Not to turn this into another lube thread, but it sounds like a lot of folks use the Valvoline squeeze packs (75W-90). The Toyota shit is ludicrous expensive and V seems rated fairly highly. Also cheaper, so looking at doing my front/rear in a few months at 15K. I know that's early, but I've had crazy experiences on other trucks with lumpy/crazy looking diff juice on regular interval drains.
    My 2012 GMC Sierra 5.3 CC 4WD with 115K on it has had it flushed a few times now, since the first time I did the front at around 30K it just about freaked me out (DARK...almost lumpy). Found out the wife had been driving the thing in AUTO 4WD quite a bit and that's not good....in good weather. Big piece of tape over the knob now with "LEAVE IN 2WD unless you're knee deep in snow".
    By the way, that Sierra is the best vehicle I've ever owned. 5K mile oil changes, tires and brake pads. Plugs and dropped the pan at 100K (CLEAN) A rear wheel speed sensor went out a few years ago, that's it. $20 part from Amazon and 15 minutes....fixed. Looks and runs like new. I've had a "RANGE" device plugged into the ODB port and have had it there since the truck had around 10K miles on it so it never runs in 4 cyl mode. I think that might have something to do with why I'm not seeing rod problems.
  20. May 3, 2024 at 3:19 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I agree, and here’s a thought to ponder. If you go to a driveline shop and you get a new set of gears installed; they will tell you to change the diff fluid after a break in period of about 350-500 miles.
    With that being said , there quite a few threads and some dealer information about whining rear differential gears. I changed my differential at 450 miles. I have just over 18,000 and there’s zero noise coming from the rear diff.
    just something to think about…..
