5 speed and the 5 lug
Discussion in '5 Lug' started by offthewallsurfer, Jul 9, 2015.
  1. Jul 9, 2015 at 4:03 PM
    offthewallsurfer
    offthewallsurfer [OP] Well-Known Member
    Just curious to all the fellas driving their 5 speed 5 lugs.. how responsive is the motor and transmission? I see and or hear nothing but good things from the guys that drive the 6 lug 2.7L 4x4 access cab models, they talk about how (not fast) they are, but how peppy they are compared to the 4 speed Auto, just wondering if the same is to be said for the 5 lugs with the 5 speed??
  2. Jul 9, 2015 at 4:13 PM
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    My bog-stock 5sp 5-lugger AC was what i'd describe as 'peppy' .. it came down to how fast you stirred the stick, really.
    Throw a set of 225/75R16 rims/wheels on it, and it's now 'lazy' in the first three gears.
    Comes down to your rim/tire size and your gearing/re-gearing. If i go up any larger on the tires, i'll be re-gearing.
    offthewallsurfer[OP] likes this.
  3. Jul 9, 2015 at 4:50 PM
    offthewallsurfer
    So in stock it's not as bad as a 4 speed auto then?
  4. Jul 9, 2015 at 4:59 PM
    HackD
    William
    Wouldn't even consider the auto - I prefer manual, keeps me in tune with driving and paying attention.
    Pretty much all the comments that i've read, general consensus is that it's a comparative slug with an auto 2.7 litre.
    Manual for fuel efficiency when taking 'er easy, Manual for keeping it in the rev range for optimal acceleration.
  5. Jul 9, 2015 at 5:03 PM
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
    Nowhere NEAR.
    The 5 speed 2.7 is peppy, VERY responsive, and will occasionally chirp on dry pavement if you're in a big-assed hurry. Its a matter of knowing how to manage the RPMs, shift properly, and don't be afraid to wind her up a bit.
    Bigger meats make it slower....I wouldn't call mine 'lazy' with the 225/75s on it now, but there's a def noticeable lag it didn't have before.
    EDITED to add
    A lot has to do with weight as well. I have a reg cab. Access cabs slow down more...DCs are def 'lazy' even with the manual.
  6. Jul 12, 2015 at 11:26 AM
    navin
    navin Well-Known Member
    Bone stock tires and 5 speed with 4.10 is how they should be delivered. Bigger tires need bigger gears to have any real response. At 31/10.50 and 4.88 it's not fast, but it is responsive and actually moves. Stock gearing is a joke.
  7. Aug 2, 2015 at 6:21 AM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    About a year ago I went up one size to 225/70-15 and did not notice any lag until summer hit and lots of A/C use. If the A/C is on, it likes about 500 more RPM's on the first two shifts. In a few years when they wear it will back close to original circumference.
