5 speed hard to go into reverse
Discussion in '4 Cylinder' started by Quick_1911, Nov 2, 2010.
  1. Nov 2, 2010 at 12:25 PM
    Quick_1911
    Quick_1911 [OP] Well-Known Member
    Brad
    Georgia
    08 Prerunner
    Any of yall ever have problems going into reverse with your 4 cyl 5 speed trucks? Mine does it every once and a while and seems like it will go about haflway into the reverse slot but not all the way and it goes in once I row thru the gears once it goes in fine. This a common thing or should I be worried? Thanks
  2. Nov 2, 2010 at 12:27 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Normal. It's because reverse does not have a syncro and are straight cut so the gears can sometimes not be lined up right. When mine does it I just put it in neutral, release the clutch for a sec and try again, it always goes in after that. FYI mine doesn't grind, just seems like its hitting a wall.
  3. Nov 2, 2010 at 12:29 PM
    Quick_1911
    Brad
    Georgia
    08 Prerunner
    Ok good to know, Thanks man. On mine its like it gets halfway in and it'll catch like it hits a wall.
  4. Nov 2, 2010 at 12:32 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Yup, exactly what mine does.
  5. Nov 2, 2010 at 12:32 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Mine goes into reverse much easier once I take it into first then go directly to reverse.
  6. Nov 2, 2010 at 12:36 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    My URD ss cleaned that up a little bit.
  7. Nov 2, 2010 at 12:38 PM
    Quick_1911
    Brad
    Georgia
    08 Prerunner
    How hard was the install with the ss? Did you have to do any cutting/grinding?
  8. Nov 2, 2010 at 12:43 PM
    numbah57
    kahai
    Maui, Hawaii
    No cutting or grinding but I did have to bend up the ahem metal around the shifter a little, nothing to bad, the rest of the install is super easy.
  9. Nov 2, 2010 at 12:44 PM
    numbah57
    kahai
    Maui, Hawaii
    Sorry about the miss spell (damn touch screen) it's the sheet metal I had to bend.
  10. Nov 2, 2010 at 11:18 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Shift to first then to reverse, helps line up the gears better...
  11. Nov 2, 2010 at 11:45 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    Yeah, what they said. Line up the gears. Most likely you're parked on just enough of a slope to move the truck the 1mm it needs to line up gears. Sometimes you'll have to go into first and inch the truck forward to get it to line up.
    Hell, most of the time, I kind of just like kind of sit down violently/rock the vehicle back/forth. That's usually enough movement to get it into reverse.
  12. Nov 3, 2010 at 12:10 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    ^^^^This. It is common practice thing to shift into first then into reverse on manual transmissions. It lines up the gears since the reverse does not have a syncrod.
  13. Nov 3, 2010 at 8:36 PM
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    i do this. btw... never be rolling when you put it in reverse. it grinds... trust me :cool:
  14. Nov 3, 2010 at 8:52 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    It's called 'double clutching' Years ago you had to do it on most of the stick trans to make them go into reverse.
  15. Nov 3, 2010 at 9:21 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Mine does it too... I just "double clutch" it.
    Now that we have that resolved... why does reverse grind if you're moving slightly? I can shift into 1st while rolling forward or backward and it's fine, but if I'm not at a dead stop to go into R then its clunkgrrgrrrrgrrgrrrgrrrr
  16. Nov 3, 2010 at 9:41 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    No syncro on the reverse gear.
  17. Nov 3, 2010 at 10:03 PM
    schiz94
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Hahahahahaha
  18. Nov 3, 2010 at 10:23 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    :confused:whats so funny?
  19. Nov 3, 2010 at 10:29 PM
    schiz94
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    It seems like you said reverse doesn't have a synchro like 20 times. I guess not
  20. Nov 3, 2010 at 10:34 PM
    S.B.
    Sean
    San Diego
    15 Taco
    ya theres no syncro for reverse.
