5 speed manual 1st to 2nd notchy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JimmyRiddle, Jul 30, 2013.
  1. Jul 30, 2013 at 8:14 PM
    JimmyRiddle
    JimmyRiddle [OP] Member
    NorCal
    Tacoma regular cab Maual
    I have a 2013 regular cab 5 speed manual 4 cylinder. The shift from 1st to 2nd seems pretty notchy. Right now it has only 800 miles and was wondering if this is pretty normal and if it gets better?
  2. Jul 30, 2013 at 9:51 PM
    mr2mki
    mr2mki Well-Known Member
    My tranny has been getting smoother as I put miles on it. I've also found that either double clutching or matching the revs before trying to drop into 2nd helps. Since 1st to 2nd is an upshift, just gently press the shift lever against 2nd as the revs fall, and at the right RPM the lever should just fall in, practically of its own accord.
  3. Jul 30, 2013 at 10:00 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    I had the same issue. It got better when the transmission would warm up, but it continues to get better as i put more miles on the truck.
  4. Jul 30, 2013 at 10:04 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    On my 1st gen i rarely shift from 1st-2nd smoothly, when i do it's because i rev matched.
