5 speed manual
Discussion in '4 Cylinder' started by jwa1028, Feb 26, 2010.
  1. Feb 26, 2010 at 12:54 PM
    jwa1028
    jwa1028 [OP] Active Member
    '01 4 cyl Tacoma
    Sometimes it's really hard to shift into reverse in my '01 manual 5 speed. Anyone else having this problem???
  2. Feb 26, 2010 at 12:58 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    That's a normal characteristic of the W59. Next time, try shifting to first the back to reverse. Sometimes I used to shift into first, then easy the clutch out just enough to hear the motor rpm change then back to reverse.
  3. Feb 26, 2010 at 12:58 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    sounds like the synchronizers. are you pushing clutch in all the way?
  4. Feb 26, 2010 at 1:36 PM
    jwa1028
    '01 4 cyl Tacoma
    I've tried shifting to first and then reverse, didn't help much. I push the clutch pedal all the way to the floor, could it be a clutch adjustment problem?
  5. Feb 26, 2010 at 1:44 PM
    Plain Jane Taco
    Plain Jane Taco I'm not insulting you. I'm describing you.
    Bill
    USA
    2015 SW DCSB TRD Sport PreRunner
    Reverse does not have a synchronizer. Here's what to do:
    1. Push in the clutch and shift into first gear
    2. Pull shifter back into neutral and let out on the clutch
    3. Push clutch in and shift into reverse
    This will slow down the input shaft and allow for better sync'ing.
    BTW, Toyota used to print these intructions in the owner's manual way back in the day. I remember my then new '95 Tercel had these in the manual.
  6. Feb 26, 2010 at 1:50 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    I have the same prob with my '99 and my girlfriend's escort. Most of the time I just disengage the E-brake and the car will move ever so slightly, and the reverse will engage.
    Pretty annoying, though. Sometimes I even have to shift into first like these guys said and make the car inch forward before I can get it into reverse.
  7. Feb 26, 2010 at 2:06 PM
    jwa1028
    '01 4 cyl Tacoma
    'Reverse does not have a synchronizer. Here's what to do:
    BTW, Toyota used to print these intructions in the owner's manual way back in the day. I remember my then new '95 Tercel had these in the manual.'
    That sounds like the best advise yet, I'll give it a try...thanks.
  8. Feb 28, 2010 at 5:40 PM
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    2015 trd offroad
    mine does the same thing. It pisses me off. I dont make U turns if i know i cant make them quick just in case of the fact that it may take time to slap it in reverse.
  9. Feb 28, 2010 at 6:56 PM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    Every manual transmission I've ever had (many) has been this way... it's no big deal. If it doesn't go straight in, just shift to neutral, let the clutch out, push the clutch back in & try again. It'll go. The main thing to remember is don't try to FORCE it. All you're doing is tearing up your linkage, bushings, etc. if you do.
  10. Mar 4, 2010 at 11:39 AM
    z33tec
    z33tec Well-Known Member
    Rochester, NY
    09 4X4 Access Cab 4cyl
    That's what I do on the rare occasion it doesn't want to smoothly go into reverse. Just throw it into neutral and try again.
  11. Mar 4, 2010 at 1:19 PM
    copernicus
    copernicus Well-Known Member
    I usually let off the clutch while I'm manuevering, so maybe that's why I haven't had too many issues with putting it into reverse, even with the short shift kit.
    First gear for me is actually more annoying.
  12. Mar 7, 2010 at 9:37 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    i have the same issues with my 06 once a week or so, jus tlike everyone else says, i usually shift to another gear then try again and its fine.
  13. Mar 17, 2010 at 2:40 PM
    efmugen
    efmugen Well-Known Member
    Pasadena,CA
    06 4-banger
    you have to caress it in, do not force it
  14. Mar 17, 2010 at 2:47 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    iv noticed that you just have to let off the break to get it to roll ever so slightly, or jsut tap the gas slightly while putting pressure on the stick to reverse
  15. Mar 17, 2010 at 2:59 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    ive had this little problem with my truck since day 1, also had it with my old '96 civic to. It only does every now and then. i just go into 1st and move ahead a little then itll go right into reverse no problem.
  16. Mar 25, 2010 at 10:03 AM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    i usually just rev the engine slightly well depressing the clutch pedal and after the rpm goes back to idle in about a second it goes right into reverse, i always just thought it was due to a cold engine or something like that
  17. Mar 25, 2010 at 1:12 PM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    once in a blue moon i get that. i just toss into a different gear, then right back to R
  18. Mar 25, 2010 at 2:51 PM
    Wolfman
    Wolfman Well-Known Member
    Paradise, TX
    2010 PreRunner SR5
    Mine balked this afternoon. I simply moved the shifter into first, and then back to reverse. It'll move the gears around a bit like others have said. IMO, it's just part of owning a manual. I've had every manual tranny vehicle that I've owned do this on occasion.
