5 speed remote start?
Discussion in '4 Cylinder' started by cicada83, Jan 14, 2010.
  1. Jan 14, 2010 at 5:50 PM
    cicada83
    cicada83 [OP] Well-Known Member
    Midland, MI
    Retro white SR5 4x4
    Volant ram air, Bestop soft topper
    I have a 2008 2.7L 5 speed. I was wondering if there was anyway to install a remote start that is ok for the clutch and everything. Anyone have experience with this? Thanks
  2. Jan 15, 2010 at 9:05 AM
    Cappy Cap
    Cappy Cap Well-Known Member
    Boston
    08 Reg. Cab
    K & N Intake, Alpine S-10 Shallow Mount Sub, Alpine CDA-9884 H/U, Alpine Type-R Components, Alpine Amp, 3.73 rear end, Welded on Muffler, Bug Deflector, Rain Guards, LCE Short Shifter,
    there is a way to do this, a shop told me in order for this to work you need to keep your car in neutral and the ebrake on it will have like a sensor or something. I always do that so it wouldnt be something new to me. Call up a shop and ask them they will give you more details but it can def be done
  3. Jan 15, 2010 at 9:08 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    You would have to keep it in neutral and have it wired into the "Clutch Start Cancel" button somehow. I'm sure if you call the shop that's gunna install they've done it before.
  4. Jan 15, 2010 at 11:47 PM
    Maats
    Maats Well-Known Member
    Belleville, On
    16 Tacoma Double Cab TRD Sport 4x4 Blazing Blue Pearl
    Stay far away from the remote starter. Even if you never put your truck in gear when parked and only use the emergency brake, dont install the remote starter. The first time a relative of mine used his, he forgot he left his honda civic in reverse. He started his honda civic and it went into the snow bank on the other side of the road. The second incident was when he hit his garage door. Luckily this time he had the emergency brake on and it was in first gear. It lunged forward and stalled. He had it removed shortly thereafter. I wouldnt install one on a manual, unless the newer remote starter models have it so the vehicle wouldnt start if it was in gear. Just my opinion.
  5. Feb 18, 2010 at 2:53 PM
    Guamo24
    Guamo24 Member
    Charlotte, NC
    2009 TRD 4x4
    Bull Bar Thule Sportster Rack Centerforce MaxPerf Stage 3 Clutch BFG's
    I have a 2010 I4 4x4 manual......asked a guy at Advanced AP and he said its possible, but not "recommended". I do have the "Clutch Start Cancel", but I am not sure it works when vehicle is in neutral. (i'll check on that and get back to ya'll) I'm thinkin if the truck is left in CSC mode and in neutral (w/ e-brake) - that a remote start is not a terrible idea and safe.....especially when you're from the northeast! (I'm from Upstate NY and would have loved to have a remote start in ALL of my vehicles)
  6. Feb 18, 2010 at 3:55 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    you can do it no problem, just remember to keep it out of gear. there are some remote starters for manuals that require you to put the truck in neutral and pull the emergency break before you cut the truck off, then the brain will allow it to remote start when your ready, if you don't do the sequence when you hit the remote start button nothing will happen.
  7. Feb 19, 2010 at 6:25 PM
    Reaper22
    Reaper22 Well-Known Member
    Palmyra Missouri
    SR5 Tacoma
    Radient Red, Red Grille, Debadge'd, Blacken'd Headlights, DTRL's, Cruise Control, Fog Lights, 2 1\2" suspension lift, 285\75\16 Nitto Dune Grapplers, Pioneer Premier DEH-P510UB stereo, Pioneer 3 way fronts with factory tweeters & Kenwood tweeters, Kenwood truck boxes behide seats with 8" subs in each, Wet suit like tacoma seat covers
    I beleive viper makes one and it works off of your engine running, clutch switch and
    e-brake switch and door switch, you have so much time once you have the e-brake set and clutch is not engaged to shut it off and get out of your truck and close the door, if the door gets messed with or e-brake after it gets closed and times out it will not start ,. But if all conditions are true then it will start. Sounds pretty safe to me but remote start is something I don't need..
