5 speed shifting issues
Discussion in '4 Cylinder' started by hwork50, Feb 28, 2015.
  1. Feb 28, 2015 at 9:32 PM
    hwork50
    hwork50 [OP] Well-Known Member
    San Clemente
    06 PreRunner SR5 AC
    DTRL, Skid Plate, Bed Extender, ipod hook up in glove bo, bed mat, rubber mats, Garmin GPS, 2.5"Toyotec lift with 5100 shocks and Eibach springs.
    ok, I have a 5 speed 2.7 Prerunner. It does this weird thing if I shift with low rpm's where it like misses and seems like it is going to bog out. It only does it from 1st to second and sometimes to third. I have 100k miles on it and it has not really done this in the 70k miles that I have owned it.
    Is it the spark plugs?
    Is it a vacuum hose?
    I need some help.
  2. Mar 10, 2015 at 3:58 PM
    pengxn2003
    pengxn2003 Member
    if the noise goes away when your foot is off the gas pedal, you probably shift at too low RPM
    try land your engine RPM above 1500 when up shift into next gear, typically meaning begin upshifting at around 2500
  3. Mar 10, 2015 at 4:03 PM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    ^^What he said^^
    I usually shift about 2000 RPM and have no problem. Increasing at 2500 RPM would be sufficient, but anything above that, you're "hot rodding" it.
  4. Mar 10, 2015 at 4:05 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    What happens if you mat it in 5th?
