5 speed tranny...no magnet on drain plug?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AndrewFalk, Nov 2, 2010.
  1. Nov 2, 2010 at 7:11 AM
    AndrewFalk
    AndrewFalk [OP] Science!
    The North East
    2010 5 speed 5 lug
    I'm in the process of changing the oil in the rear diff and in the transmission. The rear diff is done, everything went well, and the drain plug had a magnet to catch any metal shavings. The transmission is halfway done, and I noticed that neither of the plugs have a magnet on them. Could this become an issue down the road? Should I head over to Toyota and get one before I fill the tranny back up?
    Thanks in advance.
    -Andrew
  2. Nov 2, 2010 at 7:16 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    08 V6 4x4 DC TRD, 6spd
    TRD Supercharger, TRD CAI, Sirius, Rear TSB, Front 5100 with Eibach coils, 1.5" AAL, URD short throw, fog light mod, weather tech liners,
    i don't recall any of my plugs on my 08 MT having magents, but I could be wrong.
    you can also just get some button magnets, like the ones on fridge ornaments, and glue them in.
  3. Nov 2, 2010 at 7:16 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    it probulary does not have one being a sealed unit... but i dont know
    mabye one of the pros will chime in
    g/l
    p.s. why are you changing the tranny fluid on a 10????
  4. Nov 2, 2010 at 7:21 AM
    AndrewFalk
    The North East
    2010 5 speed 5 lug
    I have the manual tranny, the automatic is the sealed unit if I recall correctly. I have over 11,000 miles on it so far, so I felt that the rear diff and tranny would be pretty well broken in by this point. I wanted to get the original fluid out, along with any metal, and then get some Redline fluids in there.
    Thanks for the responses guys. :)
  5. Nov 2, 2010 at 9:14 AM
    jassco
    jassco Well-Known Member
    Boston
    2010 Access Cab 2.7L SR5 5spd, 4x4
    5100 set to .85 w/ rear TSB, 2012 Rear-view Mirror, Grillecraft, Team Trails FJ Wheels, TPMS canister, Rear headrest delete, Rear console delete, Valley Hitch, Frame undercoat, $2.99 Tailgate hose clamp lock, Avid light bar, 4x4 lighted switch ala Biceman.
    My fluid was pretty dark when I changed out to MT-90 at 10,000 miles. With no magnet there is probably some reason for not having it. I wonder if the Colorados(same trans) have them. My shifting got a little smoother especially in cold, but nothing ground breaking.
  6. Nov 2, 2010 at 11:32 AM
    AndrewFalk
    The North East
    2010 5 speed 5 lug
    I noticed the same thing. The shifting is smoother and the transmission is quieter, but the difference is not night and day.
  7. Nov 2, 2010 at 10:35 PM
    pinktaco808
    pinktaco808 Hot Steppa
    urd short shifter
  8. Nov 3, 2010 at 1:06 AM
    AndrewFalk
    The North East
    2010 5 speed 5 lug
    I'll be doing that at some point.
