5 Speed Tranny Trouble
Discussion in '1st Gen. Tacomas (1995-2004)' started by 81CountryGirl, May 3, 2010.
  1. May 3, 2010 at 5:32 PM
    81CountryGirl
    81CountryGirl [OP] Member
    Kate
    New Brunswick, Canada
    '01 Tacoma 3.4L 5Gear 4x4
    2.5" lift
    Hi all, I searched this topic and didn't come close to getting anything useful so please forgive me if this has been posted before.
    I'm having tranny trouble with my '01 Tacoma. It's always had a touchy 3rd gear and if you don't hit it just right you get a little bit of resistance (sometimes a slight grind) but it's been this way since I got it in March of last year. Guy I bought it from claims it had a new clutch in December of '08. Didn't ever get the "why" out of him but it seems he thought an ACT clutch was a performance upgrade.
    I'm not sure when my real problems began but I noticed them a week ago when I blew a rear axle seal (plugged vent tube, since fixed). I had the rear of the truck up on jack stands and was putting brakes back together while another buddy of mine was under the hood cleaning the throttle body out for me. When my brake girl started the truck for the guy under the hood, the rear hub started turning and I hollered at her to take the truck out of gear. Turns out, the truck WAS in neutral already. Apparently the power isn't enough to make the truck move in neutral when it's on the ground but it IS enough to turn a 285/75/R16 when it's off the ground. I'm no transmission expert but I've got to assume this is a problem. When I push the clutch (in neutral), it stops so it seems like the transmission is making contact with one gear or another (it's a forward gear) while in neutral. Two days later the truck started grinding while shifting to reverse, and as of today it will not take reverse at all and the forward gears are showing some resistance. If I put the transfer case in neutral the transmission seems to shift into any gear just fine, no grinding anywhere.
    Like I said, I know next to nothing about transmissions but does anyone have any idea what's causing this? I assume the transmission needs to come out and I'll have to take it somewhere to have this done but I'd like an idea of what I'm in for as far as repair and cost. If someone has ever had a similar problem (or these transmissions are known for issues?) I'd be interested in hearing about it. Thanks for any help anyone can offer!
  2. May 4, 2010 at 4:29 PM
    81CountryGirl
    Kate
    2.5" lift
    No one? Lol. Well, it was worth a shot. Guess either none of you have ever had this problem or nobody knows what it is. :)
  3. May 4, 2010 at 4:42 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    All the trucks I've worked on will still turn a rear end while in neutral with no resistance. There is always a bit of friction in a clutch even when fully disengaged.
  4. May 4, 2010 at 4:45 PM
    81CountryGirl
    Kate
    2.5" lift
    This one never did until recently. Although I'm not sure how recently... It didn't do that last October, I'm positive.
  5. May 4, 2010 at 5:27 PM
    DaCapt
    DaCapt Mad Fisherman
    Phil
    Reno, Nevada
    2013 Tacoma 4X4 SR5 DC
    It could be a worn clutch, and not disengaging fully.. Just a thought :)
  6. May 4, 2010 at 5:39 PM
    81CountryGirl
    Kate
    2.5" lift
    That's actually what I HOPED it might be cause it'd be a heck of a lot easier on the pocketbook.
    A friend and I are going to try and get at it this weekend, see if we can figure something out. Here's hopin' he knows more about transmissions than I do! Lol. Without a garage, in NB Canada, could be a tricky long process. Driveway could flood any minute. Ha ha.
  7. May 4, 2010 at 5:54 PM
    mclapperton
    mclapperton Active Member
    Rocklin, CA
    2008 prerunner sr5
    5100s
    Could be the hydraulic clutch actuator. Either a bad master or slave cylinder. Could be low fluid. Replaced a lot of these on Saturns. When they start to go, they don't fully disengage the clutch causing: hard shifts, grinds, creeping with clutch pedal in. Good luck.
  8. May 4, 2010 at 5:58 PM
    81CountryGirl
    Kate
    2.5" lift
    This is actually lovely boys. You all sound like it might be the clutch when I thought for sure it was the transmission. However, I do have a good source for parts should I need a tranny (or motor, or rear end, etc.)... all the frame recall trucks from eastern Canada were hauled to the same junkyard, which is only about an hour and a half from me. 600 Tacomas and they only thing I'm NOT allowed to scavenge are frames :).
  9. May 4, 2010 at 5:59 PM
    shitroc
    shitroc Master of War
    Ant
    2002 Tacoma TRD 4X4
    Listed in sig.......
    Where in NB are you?
  10. May 4, 2010 at 6:03 PM
    81CountryGirl
    Kate
    2.5" lift
    Near Moncton. The recalls are in Fredericton.
  11. May 4, 2010 at 6:08 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    oh right on, whats the name of the junkyard in freddy. just in case i ever need somethin lol. im right in between freddy and SJ
  12. May 4, 2010 at 6:11 PM
    81CountryGirl
    Kate
    2.5" lift
    Capital City Auto. And one of the boys there has a pretty sweet 4 Runner too. Unfortunately he scavenged all the 16" wheels before I found the place! Lol.
  13. May 4, 2010 at 6:17 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    +1, thanks
  14. May 5, 2010 at 2:42 PM
    abbaschild
    abbaschild Member
    Orange Co., CA
    1998 Tacoma 4WD
    Shell, carpet kit, rear suspension, wheels
    This really sounds like the clutch isn't disengaging. Transmission failures don't do what you're describing. Since the problem is progressing, it's probably one of the hydraulic cylinders. Also check if the lock nut on the pedal adjustment is locked -- up under the dash.
    You're lucky to have all those Taco parts close by. But then, I've never needed anything bigger than an injector.
  15. May 5, 2010 at 5:29 PM
    81CountryGirl
    Kate
    2.5" lift
    This may sound like a stupid question, but would the clutch not disengaging cause the creep in neutral? Cause that's what made me think it WASN'T the clutch...
  16. May 6, 2010 at 7:42 AM
    abbaschild
    abbaschild Member
    Orange Co., CA
    1998 Tacoma 4WD
    Yes. It's just like when you're easing into a tight parking spot.
  17. May 6, 2010 at 8:35 AM
    81CountryGirl
    Kate
    2.5" lift
    Going to take a look at the clutch right now. Thanks for all the help everyone! I'll post what I find.
