5 speed transmission problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by matissedog, Jun 17, 2012.
  1. Jun 17, 2012 at 4:10 AM
    matissedog
    matissedog [OP] New Member
    Tacoma 4x4
    My 2002 4 cyclinder Tacoma has problem of not staying in fourth gear-the shifter willl move to neutral. Truck has 106000 easy miles and has been absolutely bullet proof. No one in my area has had this problem. Anyone having this problem?
  2. Jun 17, 2012 at 4:36 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Sounds like tranny rebuild time. If you do alot of highway driving and leave it in one gear for long periods the heat can kill the gear (ask me how I know)
  3. Jun 17, 2012 at 6:38 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    That sounds like typical highway driving?
    Had a Ram-50 slipping out of 5th and took a complete teardown. Can't remember exactly but recall something about a worn detent in the internal shifting mechanism? That sounds more like frequent shifting wearing it out.
  4. Jun 17, 2012 at 2:21 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Not if the trans oil had never been replaced and another GOOD reason to change the fluids. You might want to change the rear end oil, too. Happy hunting!
  5. Jun 17, 2012 at 2:34 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    I would check the shift linkage before tearing it apart. Just check everything and make sure it is tight.
  6. Jun 17, 2012 at 2:37 PM
    TherealScuba
    TherealScuba Well-Known Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
  7. Jun 20, 2012 at 5:09 AM
    matissedog
    Tacoma 4x4
    I found the 4wd shift handle to be not fully in the forward position. Moved it forward maybe 1/16" and problem has not occurred again. Does this make sense?
