5 tire rotation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chaotic_taco, Apr 25, 2019.
  1. May 24, 2019 at 1:52 PM
    Ensemble88
    Ensemble88 Well-Known Member
    San Diego, CA
    2017 Black OR DCLB
    King suspension, SSO bumper w/winch, Pelfreybuilt sliders, morimoto fogs
    Plus you can fit a spare that is 275/70-17 in the stock location, so I would do that.
    hazey likes this.
  2. May 24, 2019 at 2:03 PM
    hazey
    hazey Active Member
    2019 DCOR MGM
    Yes that what I was wondering. Just got my first truck, I've always been a car dude. I bought '19 Tacoma OR and I upgraded tires to the 17" TRD rims and the KO2's, but my spare is still the stock tire which is slightly smaller. With a flat I obviously would have to switch out and not sure if 3 bigger tires and the 1 stock would cause issues underneath. Obviously I would drive straight to a place to get it changed back, but wasn't sure if I should have just bought a 5th tire of the same. Thanks for the answer.
    Ensemble88[QUOTED] likes this.
  3. May 24, 2019 at 2:19 PM
    Lanayru
    Lanayru Well-Known Member
    2016 Quicksand Tacoma OR
    This is the exact situation I’m in. That’s why I was thinking of just getting a 5th wheel and doing a 5 wheel rotation.
  4. May 24, 2019 at 3:19 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I bought 5 once. I'll never do that again.
    IF, and only If you ever need to use the spare, it won't hurt it to use it for a short trip, even though it's smaller.
  5. May 24, 2019 at 3:58 PM
    Lanayru
    Why wouldn’t you do it again?
    Rockefelluh likes this.
  6. May 26, 2019 at 7:44 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Waste of money, when there is a perfectly fine spare that came with the truck. The odds of ever needing your spare is smaaaaaaallll!
    Blockhead and inwood customs like this.
  7. May 29, 2019 at 9:34 AM
    chaotic_taco
    chaotic_taco [OP] Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    So here are a few more thoughts: car / truck tires only last for 6 years; after that time period they are dry rotted / prone to catastrophic failure. The big chain tire stores have a policy of not servicing tires more than 6 years old because of this. Additionally, the tire size difference can be an issue, (although it is correct that you can limp for a while, the differential is designed to handle different rotation speeds) and the reality is I'm unlikely to get a flat around town where I can limp with a smaller spare to a tire shop, so I want a matching size tire. A matching wheel was 80$, and if I'm going to shell out for a new tire every six years, I may as well put it in the tire rotation and get my money's worth out of it. The downside is the TPMS situation: the truck only stores 4 codes at a time, so instead of just doing a TPMS reset when you rotate, you'll have to actually relearn the tire that is coming into the rotation. There's a specific device to do this, and the feature is not available on carista afaik.
    The 255/85 R16 fits in the spare location ok, but for me it touched the exhaust heat shield. I dropped the spare tire mount, and remounted it a little farther towards the rear of the truck by putting the forward bolts in the rearward holes, and drilling new holes for the rearward bolts. Plenty of clearance now. I also for piece of mind put a piece of fabric (like carpet padding, but it was used as shipping packing material) on top of the wheel face when I reinstalled the spare.
    Realistically it depends on what situation you're preparing for whether you should keep the stock spare and change it every six years, get a matching size and change it every six years, or even do a five tire rotation.
  8. Dec 8, 2019 at 8:38 AM
    Seanb600
    Seanb600 Well-Known Member
    Sean
    Woodstock ga
    2019 TRD OR with real transmission
    Stock
    Sorry for bumping up a old thread. But I’m just wondering what you are doing for the TPMS when you add in the 5th wheel ?
    You help and time are greatly appreciated.
    Thank you
  9. Dec 8, 2019 at 9:02 AM
    xxtavixx
    xxtavixx Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    in for this. Ive read mixed answers
  10. Dec 8, 2019 at 3:44 PM
    J_dog
    J_dog Well-Known Member
    Victoria, Canada
    2016 Tacoma Black TRD Sport MT / 2018 Tundra TRD Offroad
    Interested as well, I have heard it doesn't work very well.
  11. Dec 9, 2019 at 1:15 PM
    chaotic_taco
    ATX
    2017 DCSB TRD OR MT
    Here's the deal with a 5 tire rotation, regarding the Tacoma TPMS.
    Each sensor has a unique ID. The truck can store four IDs. Unless the sensors get rescanned after a5 wheel tire rotation, the truck will be reading the pressure of the tire that's now a spare.
    Additionally, when you rotate (4 or 5 wheel), you need to do a TPMS reset. This updates the position of the sensors in the display, and sets the minimum pressure warning.
    I haven't done the procedure myself, but talked with my mechanic about it.
    J_dog[QUOTED] likes this.
  12. Dec 27, 2019 at 9:13 AM
    Lanayru
    Discount Tire where I take my truck is able to update the sensor information on the truck for me. You just have to be very specific with them when asking them to do it.
  13. Dec 27, 2019 at 11:35 AM
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    My solution is, rotate your normal 4 for their tread life, then take the one with the most tread and put that on your spare location when you buy 4 more. Here in NY I change tires in the fall if they are less than 7/32 nths.
  14. Dec 31, 2019 at 3:53 AM
    FHC
    FHC Well-Known Member
    The TPS just doesn’t work and the light on the dash stays on.
  15. Dec 31, 2019 at 4:55 AM
    #35
    ll1l2l1l2lll
    ll1l2l1l2lll Well-Known Member
    Orange County
    2019 Tacoma Pro
    Anyone running a larger 285 tire on their stock spare and run into issues hitting the control arm?
  16. Dec 31, 2019 at 11:12 AM
    #36
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    If my spare is 9 years old and still holding air, it will do in limp mode to get me the garage. Then I'd decide if it's good to go again. No worries about TPMS, no spending money on another tire, no 5th wheel rotation, nothing......
    adk_tacoma likes this.
  17. Jan 7, 2020 at 2:49 PM
    #37
    chaotic_taco
    ATX
    2017 DCSB TRD OR MT
    I hope you're not planning on going far/fast/offroad with a dry rotted tire. Have you ever experienced a blowout while driving?
    Certainly it's possible to keep a tire past the recommended date, especially if you store it correctly and maintain the air pressure. But if you're going to do all that work, why not just run it as part of the tire rotation?
  18. Jan 8, 2020 at 11:33 AM
    #38
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    You missed the part where I wrote limp mode
  19. Jan 8, 2020 at 2:52 PM
    #39
    chaotic_taco
    ATX
    2017 DCSB TRD OR MT
    Actually that's sorta my point. How far are you gonna "limp"? If you're 15 miles down PINS with no cell service, are you just gonna wait for the next car? Big Bend? Sure, if you daily it around town, NBD. But I'm not preparing for my 2 mile commute when I make these decisions.
    Hell what about if you're on the back side of the mall!?
  20. Jan 9, 2020 at 4:41 AM
    #40
    adk_tacoma
    Joe
    Waterford, NY
    That is why I always recommend running the spare on the rear axle
