5 year old battery - Time to replace?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sbates, Nov 10, 2015.
  1. Nov 10, 2015 at 7:05 PM
    sbates
    sbates [OP] Well-Known Member
    NJ
    2011 Tacoma TRD Sport Double Cab
    Extang Tonneau Cover, aFe Pro Dry S air filter, Weathertech Floormats, De-badged, Plasti dipped Toyota emblem black, Plasti dipped a/c control panel black, 48-led Dome Light, Tailgate Damper,
    My 2011 is 1 month shy of its 5th birthday. Occasionally I notice a slight hesitation when starting her up. Is it time to replace the stock battery? If so, any good recs for a replacement? 80% highway driving, 20% off-road (soft sand, beach). I dont think I'll need a heavy duty Optima etc., Thanks guys.
  2. Nov 10, 2015 at 7:34 PM
    kn61408
    kn61408 Retired old fart
    western washington
    09 PreRunner DCLB sport pyrite mica
    12v always on power point mod, tailgate anti-theft, Addl bed tiedowns, flyzeye dash lights, map lites with dome lite mod, bed stiffeners, air bags, brake controller, always on fog lights,
    If you're unsure of the battery, take it to O'Reilly or some other auto parts store. Some will do a battery load test at no charge. That will tell you the condition and some idea of life span. Good luck!
  3. Nov 10, 2015 at 7:36 PM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    Hey Steve. When my 2011 Taco needed a battery in 2013 it didn't have the courtesy to give me any warning at all. Cranked fine one day and next morning, not even a click, click, click. Better get it tested, don't you think? I know I would.:thumbsup:
  4. Nov 10, 2015 at 7:36 PM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    my battery lasted for 8 years before it quit all of a sudden lol.
  5. Nov 10, 2015 at 8:37 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Just curious - why do batteries just die - one minute they're good the next completely dead - a million years ago when dinosaurs roamed the earth and I was young and handsome a battery would slow crank B 4 it died. Thanks for any answer. Curious George.
    Alfred likes this.
  6. Nov 10, 2015 at 8:41 PM
    CVOTRDSPORT
    CVOTRDSPORT Well-Known Member
    2016 White Tacoma TRD Sport 4X4 Longbed
    A good indication of a battery nearing the end of its life is when starting engine you notice the sound has changed and its turning slower, especially if the a/c compressor is engaged. Cold weather is when you might see this, which may explain the battery was good and one day its not. Thats just food for thought.
  7. Nov 10, 2015 at 8:42 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Bad cell(s) from usage.
  8. Nov 10, 2015 at 8:57 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    5 years? Shit with Florida heat we are lucky to get 2 years from a battery. They roast in the engine bay.
  9. Nov 10, 2015 at 9:13 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I wouldn't even bother testing that 5 year old battery. Replace it and turn the carcass in for recycling.
    ilovich likes this.
  10. Nov 10, 2015 at 9:24 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    I replace mine typically every 5 years... I believe that's the recommended interval.
  11. Nov 10, 2015 at 9:32 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Another vote for replacement.
    I'm in a similar situation with my 2011. I'm going to replace mine at the 5yr. ownership mark. My truck sits at the airport while I travel for work. I'd like to avoid coming home and having a dead battery if possible. I'll look up the cold cranking amps and purchase a battery with those specs or higher.
    Good luck.
  12. Nov 10, 2015 at 9:47 PM
    ZachPrerunner
    Southeast TN
    Interstate batteries have been suggested to me several times throughout the years. All the audio heads use them considering they can get up to seven years out of a battery while bumping a system.
    Hardscrabble[QUOTED] likes this.
  13. Nov 10, 2015 at 9:54 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Threads like these always make me extremely nervous as I think I will jinx myself. But I seem to get long life from batteries, 2 different cars I had the original batteries for 11 years, my 2000 Tacoma was 8 years old when I traded it with original battery, my 08 that I just traded still had the original battery, and I can honestly only recall me needing to replace a dead battery only one time on a car I owned back in the 1980s. We get crazy temperature extremes here to boot, it was 104 degrees a couple Summers ago and -20 in the Winter.
  14. Nov 10, 2015 at 10:00 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    A vehicle battery can typically last from 5-7 years. The climate (extreme hot and extreme cold) are the major determining factor in reducing battery life.
    Given the high price of a good battery it seems silly to just replace it for no reason. I agree with everyone else here and say you should get it load tested. And if it tests good keep using it. But you could get 2-4 more years from your battery.
    Yes, a car battery can last 9 years (not typical). Usually the "cold cranking" power degrades first. That is the battery ability to deliver a sufficient amount of amps in cold weather. All batteries perform much worse in cold weather. So, if you don't live in an area where it freezes you could get many more years of serviceable life out of your battery.
  15. Nov 11, 2015 at 4:00 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Man, I have a 2010 and have already replaced the battery twice. First replacement time it would hesitate on startup, so as prevention, I replaced the battery. Second time everything was fine one day and the next morning I tried to crank her up and nothing.( tested at autozone and it was a bad cell).
    My truck has been housed in a garage too.
    I would just replace the battery if you were already lucky enough to get 5 years out of her. Batteries are only like $120, and it'll give you piece of mind.
  16. Nov 11, 2015 at 5:14 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    The first cold morning or leave your lights on for 15 mins. and if it cranks slower, change the battery. I would change it after 5 years any way its cheap insurance.........
    Bluegrass Taco likes this.
  17. Nov 11, 2015 at 5:16 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    If you are in doubt, and you can afford to change batteries right now, I'd be all over that! It's a huge inconvenience when a battery dies in the parking lot at work......It's a whole 'nuther ballgame when it decides to go belly up when you're out back in the woods somewhere.
    ilovich likes this.
  18. Nov 11, 2015 at 5:20 AM
    TacomaArto
    TacomaArto Well-Known Member
    Wisconsin
    2015 White DCSB SR5
    Def load test it to be safe. I live WI and had nearly 9yrs on my last battery that was in the vehicle I traded for my Tacoma. The first 2yrs of that was before we owned a home with a garage. Test it for peace of mind....
  19. Nov 11, 2015 at 5:22 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Ill see if I eat my words now that winter is approaching, but Im still running what came with the truck Sept. 2006. *knock on wood*
    Maybe Ill ask wifey for one for Xmas. Im sad to have to get rid of the amazing Japanese Panasonic...cant get the same ones here.
    shakerhood likes this.
  20. Nov 11, 2015 at 5:28 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    I did 9 years on the OEM battery in a Dodge 2500 QC 4wd I recently parted ways with. Then one rainy, cold, windy morning, I pulled in to a gas station to grab a bottle of water, and cl....cl....click... Dead battery. That morning, I would have joyfully said farewell to the old battery about 6 or 7 years earlier......No one wants to jump start you when it's 39 degrees, raining sideways, and you're late for work...
    iwashmycar[QUOTED] likes this.
