5 yr ownership report
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Demoncleaner, Dec 21, 2009.
  1. Dec 21, 2009 at 5:43 AM
    Demoncleaner
    Demoncleaner [OP] Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Picked up my 2005 5 yrs ago today. Almost 50,000 miles, still only been to dealer once (leaf springs TSB).
    Updates/changes:
    -Running Pennzoil Platinum in the motor, Full syn oil for 6-spd tranny, transfer and front diff.
    -2 changes of 80w-90 Syn blend w/ no fiction modifier in LSD rear diff. Lays two tracks, no chatter.
    -TRD exhaust, sounds good, 5 winters, and only slight rust on welds in/out of the muffler. Well worth it.
    -6th winter on Blizzaks tires on 16x7 steelies for Dec- Apr. Prolly last season for this set.
    -Stock H/T's were awful in winter, ok for summer. They lasted 30K, replaced w/ a better H/T, Kumho APT KPL51's
    -Cut a heavy 5/8" thick horse stall mat for the bed
    -Homemade bed extender, makes 5ft to 6.6ft
    -Short clutch pedal travel mod
    -Added front bed D-rings
    -Undercoated the frame Oct 08, helped some. Just sanded and repainted the Tow bar/bumper.
    4x4 system: Got about couple thousand mi in 4hi and use 4lo a few times a month. No issues. Despite other posts, minimal loss in MPG using.
    Tranny & motor: No problems, 6spd only gets smoother over the years.
    Body: Paint is doing fine, wax every 3-4 months. Have a few scratches from brush on the trail and dents around the bed/tailgate.
    Interior: Zero electronic issues, seats holding up well.
    Composite bed: Other than hundreds of scrathes, holding up great.
    MPG: lost .5- 1 mpg this year now that we have 10% Ethanol like everyone else.
    Mostly Rural driving,
    Avg 19.5-20 summer
    drops to 17 in winter
    Best 23, long summer trip
    Worst 14, Week of below zero and towing
    Octane: At least 89. Did use 87 in last summer when was $4.50+, lost only.3-.4 mpg, but at low rpms 1500-2000 (where you get your best mpg), accelerating or hitting any grade is where I really noticed the motor lug and ping more. Heavy loads/ towing even more noticeble.
    Concerns:
    -The bottoming out with a load and leaf spring squeak, but fixed w/ TSB.
    -Frame rust, I'll stay busy undercoating every couple years.
    -Weak tailgate, we all know. I use a plywood plank for weight dist when hauling my enduro moto.
    -The TRD sport 17 rims are bubbling on the edges. These wheels get to sit in a comfy 40 degree garage all winter.
    -Very sensitive ABS, not setup well for winter.
    Still want to run it another 10 years. As long as the frame is taken care of should be no problem.
  2. Dec 21, 2009 at 6:18 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Thanks for the report. What do you use on the frame?
  3. Dec 21, 2009 at 7:10 AM
    MGH-PA
    MGH-PA Well-Known Member
    Northcentral, PA
    05 Tacoma TRD AC 4x4
    265/75/16 Nitto Terra Grapplers, Bestop
    Good report. Sounds like our trucks are on par as far as the environment they're driven in, and the mpg is about right.
    I also agree on the ABS system. I absolutely hate it.
  4. Dec 21, 2009 at 7:14 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    good post. Nice to know that it has been a good truck for you.
  5. Dec 21, 2009 at 7:32 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    +1. The ABS is WAAAAYYYY too sensitive on these trucks. However, it has saved my ass a few times this winter. I need better tires. The Dunflop AT20s are not very good in slick conditions.
  6. Dec 21, 2009 at 7:49 AM
    Demoncleaner
    Upstate NY
    Washed down and brushed the rusted, or chipped off paint areas. Some areas sanded. Sprayed rubberized undercoating on the transfer case back. To the front used Hammer finish paint, about $12 a qt.
    Both helped, but some areas have broken down after year and a half. 2 coats areas have done better. Should note I spray all the frame holes and inside C channels w/ WD40 too.
    Por 15 or Eastman's Chassis black would do much better, but its also expensive and toxic shit... A lift would be nice w/ proper breathing mask and thick rubber gloves.
  7. Dec 21, 2009 at 10:25 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    I bought my truck from a guy in Boston who put 14K miles on it. The truck is now in Maryland. When I got the truck I washed the undercarriage down with a high pressure sprayer. It had no frame rust but there were some steel brackets and stuff that had some rust. My routine is now to spray the entire undercarriage down with WD40 twice a year. Each spring, I wash the undercarriage with a pressure sprayer. None of the rust that was apparent has gotten worse. With casual observation, I would say there isn't a much rust as there was. Still no frame rust. Overall this approach seems to be working.
    Demoncleaner, what do you think the result would be if you wire brushed the rust and then soaked it a few times a year with WD40 and did not use undercoating?
