50+ thread
  1. Jan 11, 2024 at 10:13 AM
    Snow Doctor
    Snow Doctor What is this car wash of which you speak?
    Kalispell MT
    2014 DCSB TRD PRO
    ADS 2.75, Icon RXT, 285/75r17
    September changed all the diffs and tranny fluids
    sdk1968 likes this.
  2. Jan 11, 2024 at 10:36 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    I know my rigs have acted weird just from having old dirty diff oil - probably not the case if you did it that recently. So much so Runner was impossible to shift unless I wrenched on it with both hands - he still had a lever not a knob. Changed out the diff and smooth as butter after that.
    We will consult the experts
    @Tacoma Mike !!! :angrygirl:
    sdk1968 and Marty65 like this.
  3. Jan 11, 2024 at 11:07 AM
    MTgirl
    Weesa
  4. Jan 11, 2024 at 11:15 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Shy turtle!!
  5. Jan 11, 2024 at 11:25 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Quit peeking :D
  6. Jan 11, 2024 at 11:32 AM
    NHmachinist
    NHmachinist Member
    Jon
    New Hampshire
    2018 TRD OR access cab
    OME lift SPC uca 255/85/16 on steelies A.R.E. DCU cap 270 awning smitty built winch rock sliders 270 awning
    Thats a real mans saw
    sdk1968 and jwctaco like this.
  7. Jan 11, 2024 at 12:00 PM
    MTgirl
    Weesa
  8. Jan 11, 2024 at 12:11 PM
    Cwopinger
    Cwopinger Random guy who shows up in your threads
    Blevin
    Florida
    2019 Quicksand Tacoma OR DCLB
    ARE MX, mud flaps, radio knobs, floor mats
    Good afternoon everybody.
    Up and on the go early this morning for a retired LE firearms qualification. Was a fun morning with the rest of the old guys. Coffee and gunpowder are a great way to start the day.
  9. Jan 11, 2024 at 12:24 PM
    Tacoma Mike
    Southern Maine
    What the hell you want now?
    You must need me for something…
    Gotta go back
  10. Jan 11, 2024 at 12:31 PM
    MTgirl
    Weesa
    Snow Doc has a truck question. Thought you might be able to help.
    sdk1968 likes this.
  11. Jan 11, 2024 at 12:43 PM
    Tacoma Mike
    Southern Maine
    I guess I found the reason for my summons.
    As long as your ujoints are good and tight then we can move forward.
    All your tires must be the same circumference within 1/2”
    Moving from 2wd to 4wd requires no pressure on the drivetrain to allow the “wait springs” to engage the collars .If there is no pressure and the collars are lined up, it goes in.
    if it clunks coming out it means there was tension in the drivetrain.
    If you turned a corner and then tried to disconnect, when it did you would think the ft diff is coming out through the roof.
    I always switch while moving and in neutral while straight for a bit.
    Clunk going in means all rotating sync parts are not equal so parts have to catch up.
    For me, I run my 4wd high once a week.
    4lo once a month.
    I have no “clunks” per say..
    Myself, with 147k, I’d be working that weekly before something got real hard to move
    from now on.
    I would check the circumferences of your tires first..
    Use it or lose it cause at some point. Your gonna….
  12. Jan 11, 2024 at 12:46 PM
    Tacoma Mike
    Southern Maine
    When have you known me not to help. Even if they were pricks..
  13. Jan 11, 2024 at 1:32 PM
    Snow Doctor
    Kalispell MT
    2014 DCSB TRD PRO
    Its been in and out of 4wd many times since September and since I put the studded tires on in early December. The psi are all within 2-3 psi of each other. Never had it do this with the tire circumference but have seen the posts about that. Its a possibility since 2 tires are probably 50% and 2 are new. I'll try moving them around when it warms up and see if that helps any. Can also then get under the truck and make sure no leaks. Everything is a sheet of road muck and ice right now. On the way to -27 tonight and tomorrow. So nothing is getting done outside until Tuesday or Wednesday when we get back above 0.
    Would any of that make it feel like the front tire is flat when in 4hi only?
    Appreciate the advice.
    sdk1968 likes this.
  14. Jan 11, 2024 at 1:37 PM
    Tacoma Mike
    Southern Maine
    If you have two tires 50%
    THAT IS YOUR PROBLEM.
    YOU NEED TO REPLACE ALL 4 TIRES AT THE SAME TIME.
    It will never be right until you do..
    Bill0351 and sdk1968 like this.
  15. Jan 11, 2024 at 2:08 PM
    MTgirl
    Weesa
    You can go back under your bridge now
    sdk1968 likes this.
  16. Jan 11, 2024 at 2:15 PM
    Tacoma Mike
    Southern Maine
    Not even a fuckin treat?
    Who do you think I am anyway..
    Something you can just use and throw away?
  17. Jan 11, 2024 at 2:28 PM
    NHmachinist
    NHmachinist Member
    Jon
    New Hampshire
    Somebody needs a hug
    TomYotaNH, US Marine and sdk1968 like this.
  18. Jan 11, 2024 at 2:31 PM
    Tacoma Mike
    Southern Maine
    You are straining the 4wd system.
    Axles trying to catch up with each other.
    Lots of weird noises and feelings can happen..
    TomYotaNH and sdk1968 like this.
  19. Jan 11, 2024 at 2:31 PM
    Snow Doctor
    Kalispell MT
    2014 DCSB TRD PRO
    Crud, Was afraid you'd say that. Wanted a different winter tire but they are backordered till spring. And didn't have enough money lying around. Guess I'll be picking up some extra shifts. Wonder why it took a month to surface though.
    Thank you.
  20. Jan 11, 2024 at 2:32 PM
    MTgirl
    Weesa
