50+ thread
  1. Jul 12, 2025 at 10:38 PM
    Pigpen
    Dan
    Northwest Montana
    I have a second battery on the floor between the back seats (built a center console around it) and have a 25 amp DC to DC charger with dual input. It charges off the starter battery when I'm driving and solar when I put the 100 watt cell out. Planning 200 for the future. Also have a 500 watt inverter hooked up.
    US Marine, jwctaco, Marty65 and 2 others like this.
  2. Jul 13, 2025 at 1:34 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    :hattip:Good morning everyone
    Cwopinger, vssman, US Marine and 4 others like this.
  3. Jul 13, 2025 at 3:24 AM
    TomYotaNH
    TomYotaNH Well-Known Member
    Tom
    Seacoast NH
    '16 Barcelona Red DoubleCab Limited
    Almost Stock - BedRug, Power Tailgate Lock, ….
  4. Jul 13, 2025 at 3:28 AM
    Metalskool
    Metalskool Adversity Builds Character
    Michael
    2020 TRD 4WD
  5. Jul 13, 2025 at 4:01 AM
    Marty65
    Marty65 Gopher
    Marty
    Lancaster SC
    4Runner trail
    Dog hair and river quiver
    Good morning everybody!
  6. Jul 13, 2025 at 4:04 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Good morning 50 plus ers:hattip:
  7. Jul 13, 2025 at 4:10 AM
    Marty65
    Marty65 Gopher
    Marty
    Lancaster SC
    4Runner trail
    In 20 minutes it’s already dropped from 67* to 38* and dropping. I’m going to pack it with drinks let it run for a few hours and put it on eco and let it run till it quits. IMG_4869.jpg IMG_4870.jpg image.jpgI’m guessing it should run about a day with no input whatsoever. I just looked at all the numbers 768wh 36watts on eco 21.3 hrs. I’m not sure if the draw is going to be a continuous 36 with cold items inside or will it cycle. And it’s not in a hot truck 68/70* inside my house so that would be a factor.
  8. Jul 13, 2025 at 5:08 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Morning everyone :hattip:
    There was a few young yearling Bucks grazing in the field behind my house . Gunny was being very talkative while staring at them , it was funny listening to him !!!!
    More Hot and humid weather here today along with moderate to strong t storms
  9. Jul 13, 2025 at 5:20 AM
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    The draw on my Dometic goes to zero but temps will range from 39-37 then kick on again. Hopefully yours will cycle off saving battery life
  10. Jul 13, 2025 at 5:51 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Good morning
  11. Jul 13, 2025 at 5:53 AM
    Marty65
    Marty65 Gopher
    Marty
    Lancaster SC
    4Runner trail
    That being the case it’s probably going to continue into the second day. I’m curious to see how it turns out my 10 quart will still be going into the second day sitting in the 4Runner in the heat. But I’m not sure what it draws I’ve never done an actual test this time I’m going to plug it in write down the time and let it go.
  12. Jul 13, 2025 at 7:35 AM
    CVYota
    CVYota [OP] Damaged Goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Morning all
    The solar is the way to go, I think a permanent mount is nice but doesn't allow for shade or sun angle, a portable that you can move around would be better but safe storage is a challenge
  13. Jul 13, 2025 at 7:56 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    I have a little Goal Zero setup, keeps phone, 2 lanterns, Bluetooth speaker. I love to upgrade and have a fridge and larger panels, I like the portable option, I moved my setup to follow the sun.IMG_1510.jpg
    Hardscrabble, Metalskool and Marty65 like this.
  14. Jul 13, 2025 at 8:01 AM
    Marty65
    Marty65 Gopher
    Marty
    Lancaster SC
    4Runner trail
    I have a 200w solar suitcase but it’s pretty bulky I would consider mounting one on a rack alongside my river quiver. I have two new 100w panels in the shop. The 100w I mounted on the enclosed not long ago is working great. The lights are bright and the tung jack works every time I was having to charge it occasionally not anymore.
  15. Jul 13, 2025 at 9:16 AM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    I installed this a couple of years ago now, and find that even with shading and sun angle, I can charge my 2nd battery system well enough to run a fridge and whatever else I need running or charging.
  16. Jul 13, 2025 at 9:24 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    That’s slick
    OldSchlPunk[QUOTED] likes this.
  17. Jul 13, 2025 at 10:21 AM
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Is that the stick on one for RVs? I was looking at that, wondered if it would work, sounds like it does
    I see it is on you shell, wondered if it would work on the roof
  18. Jul 13, 2025 at 10:28 AM
    Marty65
    Marty65 Gopher
    Marty
    Lancaster SC
    4Runner trail
    What watt is it?
  19. Jul 13, 2025 at 10:29 AM
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    And a bonus feature
    jwctaco likes this.
  20. Jul 13, 2025 at 10:30 AM
    OldSchlPunk
    Rich
    East Central Wisco
    Yes, it's the stick on, flexible panel. This is the one I bought: https://www.amazon.com/dp/B0BJJYZJ5X?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
    Marty65 and CVYota[QUOTED][OP] like this.
