50+ thread
  1. Apr 30, 2017 at 4:50 AM
    Tacoma Mike
    Southern Maine
    You need to go with what's in your area.
    I don't know about other ones but JD around here is horrible for cust service. Relative has a JD and lost his headgasket less than two years after he bought it. They wouldn't do anything for him since he never brought it back for "Service". He changed his own oil etc. So I ended up doing it for him.
    I didn't want a hydro drive but that's all I could get for what I wanted. I prefer belt drive.
    jwctaco and Cypherian[QUOTED] like this.
  2. Apr 30, 2017 at 4:54 AM
    Tacoma Mike
    Southern Maine
    Is that the most stupid shit you've ever seen?
    I back up mow about 20% of the time. It would take me about an extra 30 min to flip around d etc. I would use more fuel. I better get the epa involved as their safety crap is polluting the environment more.
  3. Apr 30, 2017 at 4:55 AM
    Tacoma Mike
    Southern Maine
    I changed my push button to a switch. So I don't have to worry about it and PAY ATTENTIONS to driving instead of looking down and pushing and turning shit.
  4. Apr 30, 2017 at 4:57 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Thanks Jim...I'm just trying to avoid getting into trouble!
  5. Apr 30, 2017 at 4:58 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Morning all. Late to the party this morning and you boys have been busy! I have a mid 90s Cub, ear check that, really MTD. Nanny reverse switch disconnected. One issue I've been having is the battery only lasts two years. I need a new one again this year. It won't hold a charge. Charging system is working fine so I'm tossing it up to cheap autozone batteries. I'm going to try an AGM motorcycle battery that I got on line...
    BTW for scars, I have 3 belly buttons from multiple tubes with lines looking like connect the dots. No need for photographs...
  6. Apr 30, 2017 at 5:00 AM
    1Shifter
    Jeff
    09 PreRunner
    You too Kevin, enjoy your day bud
    Kolunatic[QUOTED] likes this.
  7. Apr 30, 2017 at 5:02 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    I'm glad there is a factory workaround, hope it does not brake. I don't like making changes to factory specs, unintended consequences. Stuff is so complicated these days, safety/ nanny/EPA bullshit
  8. Apr 30, 2017 at 5:02 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Front blew thru with rain earlier. K Ike 45 degrees lower than yesterday evening brr.
    US Marine and ImpulseRed008 like this.
  9. Apr 30, 2017 at 5:03 AM
    Tacoma Mike
    Southern Maine
    Well drive work is out. Of course she stepped in the deepest part of my repair. So it's still soft.
    Dam. So maybe I'll pull out the pressure washer and wash the shed and back of the garage.
  10. Apr 30, 2017 at 5:03 AM
    Cypherian
    Cypherian Well-Known Member
    Mid Atlantic Region
    I just have to turn the key back to that position once it is started so no touching anything . I still think it is a snowflake thing but as I recall there was some one who back over his kids with his mower but it was smallish tractor as I recall. I just googled it yeah it happens fairly regularly it appears :{
    Cypher
  11. Apr 30, 2017 at 5:04 AM
    Cypherian
    Mid Atlantic Region
    You finish up the boat you said you were working on it when it happened .
    Cypher
  12. Apr 30, 2017 at 5:04 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    That line of storms is heading yalls way.
    Nascar sucks nowadays but it's the only racin I can view. Missed Bristol and today is Richmond .
    US Marine likes this.
  13. Apr 30, 2017 at 5:05 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Sadly they still don't stock common sense at supply house.
    Cold Iron and Cypherian[QUOTED] like this.
  14. Apr 30, 2017 at 5:05 AM
    Cypherian
    Mid Atlantic Region
    I am going to guess the yellow triangle pictograph lites and stays lit the entire time the key is in that position ?
    Cypher
    jwctaco[QUOTED] likes this.
  15. Apr 30, 2017 at 5:07 AM
    Tacoma Mike
    Southern Maine
    Boat was ready to go. I put it back in the garage. I Had to clean my stairs she walked up with repair material on her shoes. Was not in the mood to go after.
  16. Apr 30, 2017 at 5:07 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    What did ya use?
    Here after I tamp asphalt quickrete in bag I use dry mortar mix and drive on it to pack and harden.
  17. Apr 30, 2017 at 5:08 AM
    Cypherian
    Mid Atlantic Region
    My craftsman did that I put the same in and a battery tender on it good to go for the last 3 years now.
    Cypher
  18. Apr 30, 2017 at 5:09 AM
    Tacoma Mike
    Southern Maine
    The first thing you do, which has not changed since they made mowers, is
    IS SECURE THE AREA.
  19. Apr 30, 2017 at 5:13 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    I'm sure the light stays lit, maybe flashing.Pouring rain now, I want to try my new found option.
  20. Apr 30, 2017 at 5:14 AM
    Tacoma Mike
    Southern Maine
    I use trowel patch..
    I can use a 2x4 and pull the material through the low area and level as I go.
    Then after it's dry I use a cement block and sand/scrape the edges etc and blend them in. Then I seal it. I do it every 2 or 3 years. The ground moves a lot here so I have 2 cracks that come back all the time but my repairs keep water and such for undermining the rest of the drive
