50+ thread
  1. May 10, 2017 at 8:27 PM
    Cypherian
    Cypherian Well-Known Member
    Mid Atlantic Region
    That is simple wet your hand grab the coil wire and have some one hit the ignition lol ( YOU ARE ON YOUR OWN IF YOU DO THIS ) lol My grandfather whom I loved but... thought learning through experience was the best teacher he grabbed my arm and say watch this then grabbed the coil wire on his Buick Wildcat yeah um thanks gramps learned not to touch that wire when the car was running !!
    Cypher
  2. May 10, 2017 at 8:30 PM
    RickS
    RickS New Old Stock
    Rick
    DFW'ish, Texas
    '22 Tundra Limited
    Bobbles and trinkets
    Love my .357. A S&W 686 with the 4" and the flip feels manageable. Now my 10mm, even compensated that joker takes some getting use to.
    Cypherian[QUOTED] likes this.
  3. May 10, 2017 at 8:31 PM
    Chile Verde
    Chile Verde Well-Known Member
    That isn't smoke.:anonymous:
  4. May 10, 2017 at 8:33 PM
    Cypherian
    Mid Atlantic Region
    Never shot one can you compare it to a 50 DE ? put a few rounds though a friend of mines and handed it back lol Course there may or may not be a 41m Smith somewhere near by and only one 20 round box through it was yep that is fun and ..done lol
    Cypher
  5. May 10, 2017 at 8:33 PM
    CVYota
    CVYota [OP] Damaged Goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Ok, so here is the recap.
    Water was pouring out of the water filter overflow and the basket in the non garbage disposal side was leaking underneath.
    Andy thinks, I can fix this... so on a Sunday I pull apart the pipes and clean out 20 years of sewage, nothing unexpected...so far. Got to the p trap and noticed the last handyman had joined 2 pipes together with putty. He had 2 compression ends together...sigh...I used a coupler as a temporary fix. The lock nut on the basket, won't budge at all. The filter is fine and needs..new filters, while I am looking at this, the filter going to the fridge, that I didn't touch or get near, lets go and starts spraying water all over...fine, shut off the water and spend an hour running to the store just to end up shoving hoses together and clamping it, well one side, anyway, I taped the other side because damn if I am going back to the store for another clamp.
    Day 2
    Got a call from my son that the sink exploded, he couldn't figure out to shut off the cold water valve, the neighbor shut off the main to the house and helped my kid with a wet vac.
    I came home and found just a little bit of water on the carpet, put down some towels. Went to the store and bought the stupid clamp I should have gotten the first time.
    Day 3
    Took the Sawzall to the lock nut and got the basket replaced, ran my finger around the rim to get rid of the excess putty and sliced the hell out of my finger.
    Started smelling mildew so I broke out the fan and put it on the carpet.
    Day 4
    Mildew smell getting worse, found the water ran along the wall and had puddled under the small cabinet. Carpet was black. Broke out the carpet cleaner and ended up smearing mildew all over, the sprayer pump broke. More fans.
    Day 5
    Rented a cleaner got the stains out, more fans. Received the replacement filters, that works. Looked in the sink, water isn't draining seems the coupler i used was too tall and the water wasn't draining.
    Day 6
    Drained the water out and cut down the coupler, while trying to connect the coupler, the whole pipe comes out of the wall...the thread broke on the cast iron pipe. The plumber has been called.
    I am not allowed near the plumbing anymore.
    Casper66, ImpulseRed008 and robssol like this.
  6. May 10, 2017 at 8:36 PM
    Chile Verde
    Probably should have just run down to United Rentals and rented yourself a small dozer.
  7. May 10, 2017 at 8:37 PM
    Cypherian
    Mid Atlantic Region
    If it was not so annoying and expensive for you it would be worth a laughs and a story that starts with check this shit out ... :{
    Cypher
    MrOlearhy likes this.
  8. May 10, 2017 at 8:38 PM
    Cypherian
    Mid Atlantic Region
    Can of gas and a road flare ??:}
    Cypher
  9. May 10, 2017 at 8:39 PM
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    This is why I lowered my expectations
  10. May 10, 2017 at 8:41 PM
    RickS
    RickS New Old Stock
    Rick
    DFW'ish, Texas
    '22 Tundra Limited
    Never shot a 50 DE but have the 44 DE with optics. Arms started getting tired from the weight. Really gets the attention in an indoor range. Been hoping to see one of this guys' 50s. https://guncrafterindustries.com/
  11. May 10, 2017 at 8:42 PM
    Cypherian
    Mid Atlantic Region
    @US Marine
    Look at the right side that is where you can get any letter you need. Popular Items / Your Va Letters
    US Marine likes this.
  12. May 10, 2017 at 8:43 PM
    Cypherian
    Mid Atlantic Region
    NOOPPPPE I looked at the front picture page not going any further you already cost me enough this month :} LOL... But it did look pretty sweet :}
    Cypher
    RickS[QUOTED] likes this.
  13. May 10, 2017 at 8:50 PM
    RickS
    RickS New Old Stock
    Rick
    DFW'ish, Texas
    '22 Tundra Limited
    Oh, come on. A 1911 that's been designed for a 50 cal projectile. You know you need one.
  14. May 10, 2017 at 8:52 PM
    Cypherian
    Mid Atlantic Region
    I did not have the carnage you are going through, but two months ago both my toliets first the guest bath flapper valve gave and had to remove and replace the whole thing to old and when my arm hit the fill valve it cracked off. A few days later master bath toilet is running check the float is way high ok readjust and move on later in the day it is running again.. Wtf apparently old plastic is not worth 15 years of use the whole float ball snapped off the arm sooooooo back to get another rebuild kit sigh lol
    And if you remember Kevin helping me with the sill cock in January lol
    Kolunatic likes this.
  15. May 10, 2017 at 8:52 PM
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Ah, I looked up DD214. I was never in the service. Looking back on my life I should have gone in the day after High school.
    ImpulseRed008 and US Marine like this.
  16. May 10, 2017 at 8:53 PM
    RickS
    RickS New Old Stock
    Rick
    DFW'ish, Texas
    '22 Tundra Limited
    Is it time to sell the place move to Oregon and go to work for Rogue?
    US Marine and CVYota[QUOTED][OP] like this.
  17. May 10, 2017 at 8:53 PM
    Cypherian
    Mid Atlantic Region
    You are an ASS lol :luvya:
    Cypher
  18. May 10, 2017 at 8:54 PM
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    I feel your pain
    US Marine and Cypherian[QUOTED] like this.
  19. May 10, 2017 at 8:54 PM
    Cypherian
    Mid Atlantic Region
    I thought you had. Perhaps you have the new federal license from your state as ID ? or passport ?
    Cypher
  20. May 10, 2017 at 8:56 PM
    Cypherian
    Mid Atlantic Region
    Like I said nothing compared to what you are dealing with nothing more then water to mop up no carpet etc : {
    Cypher
    CVYota[QUOTED][OP] likes this.
