50+ thread
  1. Sep 17, 2017 at 5:40 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Good morning everyone, slow start this morning. More COFFEE.
    MQQSE, vssman, Cold Iron and 5 others like this.
  2. Sep 17, 2017 at 5:46 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    scottalot likes this.
  3. Sep 17, 2017 at 5:48 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I researched years ago for a hand pump kit. Came with rods a piston. Goes on well head. They only went to 100' with extensions but won't do mine at 480'
    US Marine, Martin64 and scottalot like this.
  4. Sep 17, 2017 at 5:52 AM
    Cypherian
    Cypherian Well-Known Member
    Mid Atlantic Region
    https://www.bisonpumps.com/ No idea on them but them and two others supposedly have a pump that can go 350 -400 foot
    Cypher
    Kolunatic[QUOTED] likes this.
  5. Sep 17, 2017 at 5:58 AM
    Cypherian
    Mid Atlantic Region
    @Kolunatic Doesn't someone make a vertical tank stores like 200 gallons that you tie into your current water line ? I have seen it on TV or some where before installed in a garage in the corner . They tie into it so the house feeds off it to keep the water fresh.
    Cypher
    Kolunatic likes this.
  6. Sep 17, 2017 at 6:01 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    ?? How long of run time can you get with a 100 lb. tank. Thinking about a conversion kit for my generator. Good morning to all.
  7. Sep 17, 2017 at 6:10 AM
    Cypherian
    Mid Atlantic Region
    There is a huge variable IE how much draw most gennie makers make claims of can run for X hours per tank of fuel if you read the small print it is at half load etc. So you would have to do an audit on what you want to run add all the wattage up and then size the generator to that . Perhaps your generator manufacturer can give you the numbers after conversion propane usage rate vs wattage drawn?
    Cypher
    TownvilleTim likes this.
  8. Sep 17, 2017 at 6:19 AM
    Chile Verde
    Chile Verde Well-Known Member
    Another day babysitting psycho puppy.
    :pccoffee:
  9. Sep 17, 2017 at 6:23 AM
    Cypherian
    Mid Atlantic Region
    Well time to get the house cleaning done and with luck cut the grass , it can't decide to be cloudy or sunny this am . After that some odds and ends and kill the day .
    Cypher
  10. Sep 17, 2017 at 6:55 AM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    :pccoffee: Good morning. It is 49* right now was 87 yesterday. Mother Nature had to make a big show about such a wide temperature swing and put on quite the show last night. And rain. Feels good now though. Nap sometime today to make up for the lack of sleep. And because I can.
    I ended up an hour at 250* then another hour at 220*. Some said you can go as long as 3 hours but I think about an hour and a half would be perfect. Or whenever the bacon is done :D
    My favorite way to eat corn on the cob is how I grew up eating it. Soak it husk and all for half a day or so and throw it directly in hot coals for about half an hour turning it 2 or 3 times. Some kernels will be burnt but even those are tasty. My youngest son and I would do that camping at the end of trout season I miss that. Fresh caught trout and fresh corn, hard to beat. I have 4 ears left and will throw them directly on coals later today. Time to go soak some corn.
  11. Sep 17, 2017 at 7:44 AM
    CVYota
    CVYota [OP] Damaged goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Morning all, got up at 4 and went back to bed, woke up at 7.
    Don't forget, if you have a water heater, that is another large water storage device. Turn off the supply line and I have 50 gallons in an emergency.
  12. Sep 17, 2017 at 8:04 AM
    Cypherian
    Mid Atlantic Region
  13. Sep 17, 2017 at 8:33 AM
    Martin64
    Martin64 Well-Known Member
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
  14. Sep 17, 2017 at 8:57 AM
    Martin64
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    Underground poly tanks. If you can't build up, build down.
    You can also get creative and use smaller tanks in garage/shed/barn rafters. You would have to add strength somewhere as well as overcome any freezing issues, but it's a thought outside the box.
    Another option to pumps is solar and or a dc pump (as mentioned) with a small solar panel kit and a battery.
  15. Sep 17, 2017 at 9:06 AM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    HAPPY SUNDAY :cool:
    Finally back at the Riva' full time :)
    Powa back on, cable on was a pleasant surprise and life is slowly back to "normal" , Con's welcome sign is repaired and reinstalled on the house :thumbsup: Small things quickly add up :p
    We were very lucky as I walk through our little development , neighbors houses are torn apart , one power line is still down and one complete street still no powa :(... Now the task at hand is the Florida Room and the exterior repairs....... and this will done in small steps..:hattip:
    Hopefully everyone is putting their lives back together...:bowdown:
    Y'all get out and enjoy your Sunday :wave:
  16. Sep 17, 2017 at 9:13 AM
    Martin64
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
  17. Sep 17, 2017 at 9:17 AM
    Cypherian
    Mid Atlantic Region
    :fistbump:
  18. Sep 17, 2017 at 9:18 AM
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Glad to hear they are working hard to get you back up and running. How much damage from the flooding in the Florida room? Is it screened in or is there drywall?
  19. Sep 17, 2017 at 9:20 AM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
    You too enjoy the Day snoope!!
  20. Sep 17, 2017 at 10:11 AM
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    scottalot and Cypherian[QUOTED] like this.
