50+ thread
  1. May 5, 2018 at 5:04 PM
    TownvilleTim
    TownvilleTim Well-Known Member
    Tim
    Townville, SC
    07 ACLB SR5 2.7L 2015 DCSB SR5 V6 4x4
    TRD Pro Suspension, SOS sliders, SR8 Wheels, Duratracs, ARE shell
    Thanks all! I am beat. I will never attempt that job again by myself, especially on the floor.
  2. May 5, 2018 at 5:04 PM
    Martin64
    Martin64 Well-Known Member
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    He and I are both on the low mileage list. My 98 has a bit over 50,500. But my other car is a Harley...
  3. May 5, 2018 at 5:05 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Didn't you already do that place? :anonymous:
    She didn't eat the tail, but did everything else :puke:
    Shopping - check
    Oil changed - check
    wiper blades changed - check
    u joints lubed - check
    trash run - :pout: nope, got too late
    neighbor was out while I was changing my oil.... turned around and my oil jug was gone :eek: he threw it on his burn pile - good thing I didn't need it for the old oil
  4. May 5, 2018 at 5:06 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Did you put in a single aal, or a 3 leaf progressive
    robssol and TownvilleTim[QUOTED] like this.
  5. May 5, 2018 at 5:12 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    There's quite a few 1rst gens on that list with under 90k miles or lower
  6. May 5, 2018 at 5:13 PM
    TownvilleTim
    Tim
    Townville, SC
    It's the single. I'm putting air bags on for towing.
    Just broke 40k but it had 22 when I got it. The 07 has 130k.
  7. May 5, 2018 at 5:17 PM
    CVYota
    CVYota [OP] Damaged goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    154k on an '11
  8. May 5, 2018 at 5:22 PM
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    Pfft. ‘16 and I’m at 36k. I ain’t got time to sit around. Places to see, things to explore.
    robssol, Casper66, Kolunatic and 6 others like this.
  9. May 5, 2018 at 5:23 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    146k on my 72 Camaro not bad for a 46yr old car that works out to be 3200miles per yr !!
    :thumbsup:
    I've only put 10k miles on it in 20yrs !!
    robssol, Cuffs, RickS and 1 other person like this.
  10. May 5, 2018 at 5:25 PM
    ImpulseRed008
    Susan
    SC
  11. May 5, 2018 at 5:26 PM
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
    Will be in Tappahonock in two weeks. I love Virginia.
  12. May 5, 2018 at 5:27 PM
    Martin64
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    I just lucked into this whole low mileage thing. Low miles when I got it (44,000) and I have a short commute and I really don't have anywhere to go when I'm off work. And, when I do it's usually with my wife and she doesn't like the seating position so we take her truck.
    RickS, Kolunatic, MrOlearhy and 2 others like this.
  13. May 5, 2018 at 5:32 PM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
    Good evening Peeps! Finished another Ringer(40hrs) and back home chillin. It was a good week and I earned my Peppers :) it’s been full boar with patrons enjoying our Facilities.
    It sits Nice Tim, Kudos for tackling it without a lift. It’s funny how our elbows take a beating at this age when laying on your back wrenching. 40 yrs ago it wasn’t a problem lol! I always slap on a old flannel shirt when I crawl under Taco. It helps.
    As far as the Bro lean goes, they also call it Bulldog down in these parts. Hope y’all are enjoying the evening.
    dewayne, US Marine, Kolunatic and 3 others like this.
  14. May 5, 2018 at 5:34 PM
    TownvilleTim
    Tim
    Townville, SC
    Yeah, it was rough on the floor. Double layer cardboard and knee pads helped. Hey, I never did get spacers for my driver's seat. What did you say you used?
  15. May 5, 2018 at 5:40 PM
    Soul Surfer
    Jimi
    ‘25 TRD OR
    I ended up just adding two fender washers to both rear mounting locations on the drivers seat and I’m happy with the results. I also swapped them over to the ‘17. With the washers you can add and subtract until your satisfied. Hope this helps.
  16. May 5, 2018 at 5:43 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Evening all!
    What a day. I decided to install the billies with Toyotec springs, LR UCAs, and ECGS bushing. All went well until I noticed one of my alignment tabs were flattened. Soooo, I took the cam bolt out but needed to use the impact all the way out. Yup, the threads were all galled. Looks like when I had it aligned last summer the shop flattened a tab and used the impact to tighten the crap out of the bolt. 3 auto parts stores and tractor supply, no cam bolt or M14x1.5 die. Stopped at the hardware store and picked up a high strength 10.9 M14 nut and was able to chase the threads back to shape with that. But wait, there's more! The lower shock bolt seized to the sleeve and had to be cut. Hardware store had an appropriate size replacement. Bushing went in without issue. On Monday, it will be aligned at a tire shop. I must have waisted a healthy 3-4 hours messing with the cam bolt and cutting out the shock bolt. As I figured, the back and sciatica is burning.
    Cold Iron, Ret CB, robssol and 11 others like this.
  17. May 5, 2018 at 5:48 PM
    MrOlearhy
    MrOlearhy One day at a time. Sometimes minute by minute.
    Tedd
    NW corner
    Small useful for me stuff.
    Liked for the work accomplished not for the damage, difficulties, or pain.
    Ret CB, dewayne, US Marine and 3 others like this.
  18. May 5, 2018 at 5:48 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Add to back bolts?
  19. May 5, 2018 at 5:49 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    X2
  20. May 5, 2018 at 5:51 PM
    Tacoma Mike
    Southern Maine
    You have a 3 or 4 leaf pack ?
    TownvilleTim[QUOTED] likes this.
