50+ thread
  1. May 7, 2018 at 3:34 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    And?
    dewayne likes this.
  2. May 7, 2018 at 3:35 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    just another survey... Can't complain other than I was starving...
  3. May 7, 2018 at 3:35 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    :popcorn:
  4. May 7, 2018 at 3:35 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    :notsure:
  5. May 7, 2018 at 3:36 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    When do you get any test results?
    US Marine likes this.
  6. May 7, 2018 at 3:39 PM
    ImpulseRed008
    Susan
    SC
    Just a typical survey... Never, sometimes, usually, always. how was the wait time to get a room, blah, blah, blah
    Kolunatic[QUOTED] likes this.
  7. May 7, 2018 at 3:45 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Nope, can't do with all of the liquid rust they through on the roads in the winter.
  8. May 7, 2018 at 3:45 PM
    ImpulseRed008
    Susan
    SC
    Everything done in the hospital, got before I left... Monitor - not sure. See the doc on Thursday, but wear this thing until the 25th. Speaking of the monitor, night unit will not connect. Told them it NEVER connected Saturday night and had already been on for 2 hours (Sunday night) and hadn't connected. Day unit is fine - connects within a minute or two. Called last night @ 11:30 and they said, shouldn't take so long to connect. I'd already turned the phone off and on, unit off and on, (which the guy the other night said to do) and she finally agreed it's toast and is sending another one.... Should get that tomorrow
  9. May 7, 2018 at 3:51 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I've seen a couple of posts where folks heated them with a heat gun and reshaped them for clearance.
  10. May 7, 2018 at 3:59 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I already had done that. The 'alignment' brought the wheel toward the rear of the opening. I've read I should max out caster on the LCAs and adjust to +3* via the UCAs, then adjust camber via the UCAs to 0, then toe to 0. If I had alignment plates, I'd do it myself. I don't have access to an alignment rack anymore. I've seen the DIY plates but they only rotate and I'd prefer the ones that slide sideways too so that I wouldn't have to roll the truck off of the plates and back on each time I had to raise it for an adjustment. The good ones are too expensive for my garage.
  11. May 7, 2018 at 4:02 PM
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    Wasn’t too bad today. Spent it beachcombing at Fort Stevens Stare Park.
  12. May 7, 2018 at 4:09 PM
    Martin64
    Martin64 Well-Known Member
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    We just recently had one of our GIS interns get on full time job in that area. I think it is with the state park(s).
  13. May 7, 2018 at 4:12 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    You can leve the LCA's in the normal position, although I don't guess it would hurt to move them, but yes try to get the UCA castor number up around +3. If you only have stock UCA's you'll be doing good to get much of anything over +2 but that should really help. If you have aftermarket UCA's they should have some castor built in and +3 will be easy to achieve. You don't really want to go much past that as it will actually move the tire back on the lower end, A member on here had a really good write up showing the numbers it was emlightening.
  14. May 7, 2018 at 4:13 PM
    CVYota
    CVYota [OP] Damaged goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    The vote was 3 to 1, Chuck. You are out numbered in your house.
    Those are the numbers I go with. I found a shop with a large alignment machine, used for trucks.
  15. May 7, 2018 at 4:15 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Problem is finding a tech smarter than what they’re working on
    robssol, Cold Iron, US Marine and 4 others like this.
  16. May 7, 2018 at 4:17 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    :censored: I’m hungry
  17. May 7, 2018 at 4:19 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Just looked up a slow cooker recipe
    US Marine and Ret CB like this.
  18. May 7, 2018 at 4:20 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    image.jpg Evening sun has just been reduced :thumbsup:
    dewayne, Cold Iron, US Marine and 2 others like this.
  19. May 7, 2018 at 4:21 PM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    Hungry too.
    And tired.
    I thought I got up at 3:30 this morning when in fact it was 2:30.
    That was a major WTF moment as I was getting ready to leave the house.
  20. May 7, 2018 at 4:23 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Yea well when I got up coffee was made. Made at 10pm last nighto_O
    ‘‘Twas good though :anonymous:
    Cold Iron likes this.
