50+ thread
  1. May 7, 2018 at 4:23 PM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    Always good.
    Even 2 day old "Camp Coffee".
    Cold Iron and Kolunatic[QUOTED] like this.
  2. May 7, 2018 at 4:27 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I still like my jet fuel coffee bean in espresso. I’ve learned I can cheat it with more water and a bigger cup under it :burnrubber:
    US Marine likes this.
  3. May 7, 2018 at 4:28 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I'm running LR UCAs. The good news is that they are very adjustable - The bad news is that they are very adjustable. I use that same line when folks ask me about the Weber tri-carb set up on my Falcon
  4. May 7, 2018 at 4:30 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Better than 3 holleys :crapstorm:
  5. May 7, 2018 at 4:31 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    But nothing beats the look of three glass bowl Holleys!
  6. May 7, 2018 at 4:31 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Yeah I can't imagine having to tune and sync 3 carbs, no thanks I'm too dumb for that
    robssol, Cypherian and Kolunatic like this.
  7. May 7, 2018 at 4:34 PM
    dewayne
    dewayne Simply Southern.
    Dwayne
    Shenadoah Valley,Virginia
    2015 tacoma AC mettalic grey
    265/75r16 KO2 5100 level at1,75,Icon 3 leaf addaleaf pac,amp,speakers,holster,black out badges
    Check the little flap in front of tire. when i put my scs wheels on turning in the driveway in reverse pasenger rubbed the little flap in front of tire. i cut it off and no rub even on mud flaps.just something to look at
    vssman[QUOTED] likes this.
  8. May 7, 2018 at 4:35 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    It's all about having the correct tools and understanding what each adjustment does. Mine ran like crap until I added a wideband AFR and then I tuned and balanced them in a snap.
  9. May 7, 2018 at 4:35 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Already gone - ARB bumper...
    dewayne[QUOTED] and Casper66 like this.
  10. May 7, 2018 at 4:45 PM
    Tacoma Mike
    Southern Maine
    The battery pack consists of 28 Panasonic prismatic nickel metal hydride modules—each containing six 1.2 volt cells—connected in series to produce a nominal voltage of 201.6 volts.
    Each cell is monitored by the hybrid ecu. If it determines there is a cell that is out of the norm it goes into a survival mode. Throws a warning light and puts the cooling fan on high.
    The hybrid battery actually starts the car through MG1 inside the transaxle.
    If the battery is bad enough in the ecu logic. It won’t start the car. Or if an idiot keeps restarting the car with no fuel in it it will kill the hybrid battery and a recovery charging station will be needed to recharge the battery enough to start the engine.
    This car wouldn’t start.... wouldn’t spin over because the ecu said no way. So I had to replace the battery. Then I had to diag and get the car started.
    Batteries crap out just like normal lead acid batteries. Just a lot more chances in this pack.
    I’ve seen them die at 85,000 miles and some over 300,000 miles and still going.
    With an old second gen Prius it’s a big chance on a $3,000 repair to recover the money. I will say that not much goes wrong per say except for the batteries. They just go and go... as long as you can take care of it and keep it from rusting to the ground...
    robssol and DoorDing like this.
  11. May 7, 2018 at 4:45 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    You're right, I'd actually prefer rubber flaps.
  12. May 7, 2018 at 4:53 PM
    Tacoma Mike
    Southern Maine
    About 100 pounds.
    The plug in is about 200
    robssol[QUOTED] likes this.
  13. May 7, 2018 at 4:55 PM
    Martin64
    Martin64 Well-Known Member
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    Shouldn't there be a rifle attached to that thing?
    dewayne, robssol, Cypherian and 4 others like this.
  14. May 7, 2018 at 5:03 PM
    Tacoma Mike
    Southern Maine
    Naaaa easy...
    Casper66[QUOTED] and US Marine like this.
  15. May 7, 2018 at 5:03 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    LOL !!
  16. May 7, 2018 at 5:06 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Tuning multi carb set ups is very easy !!
  17. May 7, 2018 at 5:07 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Evening Everyone !!!! :hattip:
    Soul Surfer, Cold Iron and vssman like this.
  18. May 7, 2018 at 5:12 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    If you want the fuckers welded in place I can figure that out but I'm too dumb for all the adjusting I leave that to you smartass guys
    TownvilleTim likes this.
  19. May 7, 2018 at 5:21 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Yes thank u
    Cypherian, Soul Surfer and Cold Iron like this.
  20. May 7, 2018 at 5:35 PM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    Amazing how much just one dog can shit in 6 months :anonymous: Was better under the snow but got most of it now. The rest was stuck in the lugs of my boots before they hit the deep sink.
    Even if you upgrade to a smart stat still pretty easy, you would have no problems with doing it. Just have to make sure that the replacement is the same type as what is coming out, ie: boiler, zones, heat pump, etc. And you can look up your existing model to see what the current model now is especially if it is a Honeywell. The gas company here usually has rebates on new stats especially smart ones like the Nest. Still haven't done it though.
    Just got the township newsletter last week and they talked about how many miles of gravel roads are in the township. And the 18 miles that are paved now LOL. Without flaps I chip the hell out of my rocker panels as my tires through gravel.
    I split the difference. Got a set of Huskys and cut them down and also a set of rubber ones then used plastic rivets to make one set. The rubber will give a lot especially at higher speeds, doing this they give a little more protection. So far they have held up well even under some pretty rough conditions and temperatures.
