50+ thread
  1. May 3, 2019 at 4:52 PM
    Tacoma Mike
    Southern Maine
    Well.
    Got rid of a couple of my repair list.
    One 180,000 mile tundra.
    Abs self activation.
    Wiring was cut and spliced in system.
    Had to probe and ohm 40 friggin wires.
    Flow chart said abs actuator to the cost of $2000.
    Road tested with my computer and saw right rear speed signal dropping out.
    Wiring good. Another place replaced sensor.
    Yea not actuator.
    Replaced the friggin pita rr axle bearing. These things suck.
    Abs system is fixed. Lots of diag, lots of bearing labor. But one part to fix.
    Can you see the problem?
    Pibbles99, Kolunatic and US Marine like this.
  2. May 3, 2019 at 4:54 PM
    Tacoma Mike
    Southern Maine
    And crap,,,,,, I get more added to my list..
    US Marine and Kolunatic like this.
  3. May 3, 2019 at 4:55 PM
    Tacoma Mike
    Southern Maine
    No that stuff gets under the fingernails...
    US Marine likes this.
  4. May 3, 2019 at 4:56 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
  5. May 3, 2019 at 4:57 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    YOU DON'T USE GLOVES! By God, hygiene, my friend, hygiene!
    dewayne likes this.
  6. May 3, 2019 at 5:00 PM
    Tacoma Mike
    Southern Maine
    Another dr told me grease is actually clean. When I almost lost my finger it was Full of grease and said the grease protected it from infection until it was stitched up.
    Kolunatic likes this.
  7. May 3, 2019 at 5:01 PM
    TownvilleTim
    TownvilleTim Well-Known Member
    Tim
    Townville, SC
    07 ACLB SR5 2.7L 2015 DCSB SR5 V6 4x4
    TRD Pro Suspension, SOS sliders, SR8 Wheels, Duratracs, ARE shell
    Other than the split?
  8. May 3, 2019 at 5:03 PM
    Tacoma Mike
    Southern Maine
    Split?
    Explain
  9. May 3, 2019 at 5:04 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    What’s the crack?
    The axle housing?
  10. May 3, 2019 at 5:04 PM
    TownvilleTim
    Tim
    Townville, SC
    Murica!
    My preference too but slim pickings in 16".
    dewayne[QUOTED] likes this.
  11. May 3, 2019 at 5:05 PM
    Tacoma Mike
    Southern Maine
    Housing cracks are the result of me cutting the outer retainer off the axle.
    This whole piece seen is replaced
    Kolunatic[QUOTED] likes this.
  12. May 3, 2019 at 5:07 PM
    TownvilleTim
    Tim
    Townville, SC
    That split. Thought maybe so.
  13. May 3, 2019 at 5:12 PM
    TownvilleTim
    Tim
    Townville, SC
    I'm not seeing what would cause wss signal to drop.
  14. May 3, 2019 at 5:14 PM
    Tacoma Mike
    Southern Maine
    The ring inside the housing is the tone wheel for the abs system.
    It has a specific number of slits in it. As the wheel turns the sensor picks up these slits in specific time. Like the beat of a drum.
    The top part of the tone wheel has a piece missing. So the computer thinks the wheel has slowed down,aka slipping, so it starts to pulse that brake to equal the braking.
    robssol likes this.
  15. May 3, 2019 at 5:22 PM
    TownvilleTim
    Tim
    Townville, SC
    An, I didn't realize the tone wheel was on the bearing. Does it have active sensors or the older, inductive style?
  16. May 3, 2019 at 5:29 PM
    Tacoma Mike
    Southern Maine
    Tone wheel changes the magnetic field in the sensor creating a pulse the ecu reads.
    So I guess it’s still a inductive sensor
    robssol and TownvilleTim[QUOTED] like this.
  17. May 3, 2019 at 6:02 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    dont forget the zip ties and blue shop towels!
    Taco Buggy likes this.
  18. May 3, 2019 at 6:08 PM
    Tacoma Mike
    Southern Maine
    Oh yea.
    Lint free towels for sanitation.
    Zip ties for holding all the slimy , gooey parts together
    MTgirl[QUOTED] likes this.
  19. May 3, 2019 at 6:31 PM
    TownvilleTim
    Tim
    Townville, SC
    Bad choice of words. Should have said passive. I've been out of it so long. Never dealt with the wheel and brake hardware much. We simulated our wss signals with generator cards we built for ECU testing. I think those are active sensors. Makes sense. Active are a hall-effect type sensor and the magnets are physical on the tone wheel. I just didn't know they had Incorporated them in the bearing.
  20. May 3, 2019 at 6:42 PM
    Tacoma Mike
    Southern Maine
    They have them in the bearings, alone on an axle, cv joint ends.
    Forever changing..
    TownvilleTim[QUOTED] likes this.
