50+ thread
  1. Mar 21, 2021 at 7:03 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    https://www.truckcampermagazine.com...ltimate-truck-camper-payload-match-challenge/
    TLDR....
    fill up gas tank, take truck to scales and weigh. take the GVWR shown on the door panel minus the dead weight of the truck to get your max payload.
    go home, load up camper (preferably fully loaded with all food, water, LP, etc) and head back to scales for a re-weigh. then pray the that difference between the two scale readings is within your payload
  2. Mar 21, 2021 at 7:05 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Ow ow ow OOOOWEEE... the space between my ears hurts. :(
    MTgirl[QUOTED] likes this.
  3. Mar 21, 2021 at 7:10 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    can pick you up, but you got to get across the line, might need to hoof it thru the bush; otherwise the proper procedures are still closed, both directions (though exceptions are made for a few local communities that rely on cross border between AK & Canada, for access to shared schools and food runs).
    Considering your logistical connections Rob, is there not an option for a C-5 / C-17/ or even C-130 delivery from Bangor to Malmstrom? Essential civilian support? National Guard exercise? just throwing ideas out there.
    Hardscrabble likes this.
  4. Mar 21, 2021 at 7:11 PM
    MTgirl
    Weesa
    its complicated....
    while i was still shopping and trying to figure out what i wanted i made a spreadsheet with all sorts of specs on campers. thought my head was going to explode if I had to crunch one more number. so i bought a truck i liked and hoped for the best :notsure:
  5. Mar 21, 2021 at 7:11 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Hmmm ... some books may need to be cooked. thanks Brother
  6. Mar 21, 2021 at 7:12 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Apparently so...o_O
    my load plans seem simpler. :boink: ;)
    LoL ❤️
    Hardscrabble and MTgirl[QUOTED] like this.
  7. Mar 21, 2021 at 7:12 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    You may need to personally supervise the transfer with an escort for the critical infrastructure.
    MQQSE[QUOTED] likes this.
  8. Mar 21, 2021 at 7:13 PM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Well, the "Chuck Box" almost got chucked into the garbage, but I think I saved it. I'm a welder/fabricator, not "The new Yankee Workshop".....ahahahahahaha.
    More tomorrow.....maybe.
    Zim
  9. Mar 21, 2021 at 7:13 PM
    MTgirl
    Weesa
    in the past i have asked for a random airplane box filled with salmons and halibuts to be "accidentally" dropped over my neighborhood but no luck
    VE7OSR[QUOTED] likes this.
  10. Mar 21, 2021 at 7:14 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    :pout:!:(
  11. Mar 21, 2021 at 7:17 PM
    MTgirl
    Weesa
    you remember my plan to help you with early retirement right? black market fish sales...
    'but is still going for $14/lb
    not sure where salmons are at this year
  12. Mar 21, 2021 at 7:18 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Hafta check market
  13. Mar 21, 2021 at 7:19 PM
    MTgirl
    Weesa
    nothing saying you couldn't make it out of metal :notsure:
    but its looking good to me! your campstove, etc all fit in there?
    MQQSE likes this.
  14. Mar 21, 2021 at 7:29 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    He's still over the Pacific and should be landing around 2230hrs then a 45 min drive to my house . It's a 5.50 hrs flight from Oahu Hi to the Mainland
    You don't need a CDL until you're over 25,995lbs GVWR
  15. Mar 21, 2021 at 7:31 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    He does seem a little intimidated by the Camaro
  16. Mar 21, 2021 at 7:33 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Looks good :thumbsup:
    Tacman19[QUOTED] likes this.
  17. Mar 21, 2021 at 7:35 PM
    MTgirl
    Weesa
    not talking about license restrictions... just about overloading the truck with more dead weight than it can safely carry.
    MQQSE and US Marine[QUOTED] like this.
  18. Mar 21, 2021 at 7:35 PM
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    If I had a finger brake, I'd do it in metal. This would be a lot of small bends. Yeah the top is for the stove, middle for plates and cups and bowls and the bottom will hold the gas, coffee pot and other cooking stuff. I just don't have the gear to work with wood. I have to cut with is a 25 year old crapsman circular saw. LOL
    Thank you tho. I appreciate it.
    Zim
    US Marine likes this.
  19. Mar 21, 2021 at 7:40 PM
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    My take on the whole deal is he left the Cleetus operation to improve on his insecurity issues. He was getting eaten alive in the comments on cleetus's videos. He was just trying too hard to fit in. I think this was a horrible decision. He and the girl friend don't have a clue what they're doing and someone is going to get hurt. If you watch the before and after of his girl, she's scared shitless. I don't think they are going to last too long.
    Zim
    US Marine[QUOTED] likes this.
  20. Mar 21, 2021 at 7:41 PM
    MTgirl
    Weesa
    as long as it does what it needs to do.... that's the most important part of camping gear.
    you should post in the what have you made today thread. as another member pointed out, you are the only one who will notice any of the "mistakes" made.
