500rpm idle with bad shaking?
Discussion in '4 Cylinder' started by norcal4banger, Apr 17, 2011.
  1. Apr 17, 2011 at 7:22 PM
    norcal4banger
    norcal4banger [OP] 11-98 MUD
    Jack
    Far Northern California
    2005 4 Cylinder 2WD 5 Lug RC Tacoma
    Great...now what. I know I'm already having transmission issues starting about a week ago. And just 20 minutes ago driving home, the engine idles at 500rpm and shakes really bad. Usually idles at 800-900rpm. This is while in D and in Park.
    So could this be tranny related or now do I have engine problems?
  2. Apr 17, 2011 at 7:33 PM
    1moonshine2
    1moonshine2 Well-Known Member
    Appalachian Mountains in VA
    Tacoma 4x4, 4cyl, 5spd, reg cab
    I'd say it's in the engine if it does it in park, but if there is a transmission problem that is putting an extra load on the engine, then it could be that. A bad torque converter for example, or a problem with the transmission's hydraulic pump.
  3. Apr 17, 2011 at 8:01 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    well, you have to go through the list of parts that allow your engine to idle at 800 range?
    ECM, input sensors, output sensors, Temp sensors, etc etc.....
    Sounds like it was all of a sudden which leads me to believe it's a sensor issue. Or low coolant or oil level?
    Check the common sense things first and scan for codes. My scanner allows me to drive around with it plugged in and it reads the computer and every so many seconds it updates my screen to tell me what's going on. Pretty useful in this day in age when there is no simple answer sometimes.
    Hopefully someone has experience this and can chime in.....
  4. Apr 17, 2011 at 8:17 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    maybe fuel injectors?
  5. Apr 17, 2011 at 11:51 PM
    norcal4banger
    Jack
    I rely on my truck for work and need it everyday. I lose a ton of money everyday it will be in the shop. So tomorrow in the morning I'm thinking about telling toyota all that is wrong and have them diagnose it and give an estimate. then I will either have them work on it or take it to a reputable shop for a lower cost. Would this be a good idea or would I be wasting my time taking it to the dealership?
  6. Apr 18, 2011 at 12:53 AM
    reloadedkid
    reloadedkid Member
    Silver Streak Mica
    1.5 leaf spring lift, Behind the grill hella light with hid, Billet grille painted black, Core racing Wheels. Steering wheel cover.
    did you pull any code?
  7. Apr 18, 2011 at 4:22 AM
    o5iiawah
    o5iiawah Well-Known Member
    Tim
    Philly 'burbs, PA
    '11 4x2 access cab 2.7l
    Try to pull codes if you can but take it to a foreign car shop which has good reviews. Most of my experiences with little shops has been that they are honest, will save you as much as they can and wont try to screw you over. The dealer could care less about one person's good or bad experience but a little guy needs the repeat business.
    Either find a way to read the scan codes to see what its throwing up, or take it to a shop and pay the $ for a diagnosis
  8. Apr 18, 2011 at 6:44 PM
    brelandt
    Terry
    Dublin, CA
    scan first before going anywhere and pop the hood and check every plug you see. my Civic had a sudden idle problem and all it was was the IAC plug came off some how...weird...plugged it in and all was fine.
  9. Apr 18, 2011 at 6:48 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    I know when i shift into park the rpms drop from about 800 to 600 but comes back up to 800 ish right after it shifts but thats the lowest i go
