Discussion in '1st Gen. Tacomas (1995-2004)' started by surfwax, Jul 20, 2017.
  1. Jul 28, 2017 at 4:24 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Honestly you can do a ton of wheeling with a 3" lift, good tires, and good tires placement.
  2. Jul 28, 2017 at 8:43 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Budget SAS: Buy someone else's rig for half of what they spent on the conversion alone :) Just be patient and one will come up eventually.
    tacoma_2002, malburg114 and stumbles like this.
  3. Jul 28, 2017 at 11:59 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    There are plenty of build threads on SAS's. search through those, and do a ton more research. Someone else already said it, but a leaf sas will probably be your cheapest and "easiest" bet. But keep in mind you are COMPLETELY replacing the entire front end, steering, etc... You might keep the wheels and brakes.
    If you are a fabricator, you can do it fairly cheaply, assuming you can source a new (used) axle, but you're looking at a 30+ year old axle if you get a toyoya axle. There are several "kits" out there, but complete kits run in the arm/leg territory.
    But as others said, the best budget build is to buy someone else's build.
  4. Jul 29, 2017 at 1:02 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    If you have to ask the question.....
    Get out and wheel your truck first. Then determine what you want or need. Swapping a truck because it looks cooler is literally one of the worst ideas possible. You'll end up over your head faster than you can believe instead of wheeling your truck on the very capable IFS.
  5. Jul 29, 2017 at 2:09 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    And then he said I want SAS on a budget! :rofl:
  6. Jul 29, 2017 at 5:02 AM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    OP, the best advice I can give you is find a friendly local Off Road group that you can start wheeing with and learn more about your truck before digging in to modifications. You'll be supprised by what a completly stock 1st Gen can do. If you must, start with upgrading armor, skids, sliders etc...
    Key-Rei likes this.
  7. Jul 29, 2017 at 6:26 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    To quote @jberry813:
