50k service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by woody6047, Jul 16, 2010.
  1. Jul 16, 2010 at 8:32 AM
    woody6047
    woody6047 [OP] McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    So i just hit 50k on my 05 4x4 doublecab, Im going to get the tranny and dif fluid changed, and one of my friends told me to ask about running synthetic.
    Is this a common change and is it good for either one? I know that if i started running synthetic then i would always have to run it.
    Also, im going to change out the plugs. At what point does it benefit to upgrade your plugs from the stock ones you get from toyota? I have intake, headers, and a full exhaust... should i just stick with stock?
    Thanks for any of the help.
  2. Jul 16, 2010 at 8:41 AM
    woody6047
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Yea ive seen where a majority say stick to factory plugs, what really are the benefits of running synthetic oil?
  3. Jul 16, 2010 at 8:45 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    I messed up. I thought you were talking about running synthetic in your engine. As far as your diffs go, synthetic is also a good choice. It dissipates heat faster and can absorb more moisture than conventional oil. It also lasts a lot longer under normal operating conditions. Some people with the TRD Sport models with the mechanical limited slip have had issues running synthetic oils in the rear diff, but you have a TRD Off Road, so you will have no issues. I would run 75w90 synthetic in your front diff, rear diff, and tcase.
  4. Jul 16, 2010 at 9:10 AM
    woody6047
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Thanks man, thats good information to know. I appreciate the help.
  5. Jul 16, 2010 at 9:12 AM
    NAAC3TACO
    Sparks, NV
    2014 SR5 DCLB 4x4
    No problem.:cheers:
  6. Jul 16, 2010 at 9:18 AM
    P-Dub
    P-Dub Well-Known Member
    Paul
    SF Bay Area
    06 Blue 4x4 TRD Sport DC LB
    TRD skid plate, OEM roof rack, OEM running boards, TruckCovers USA rolling tonneau cover, 3000K HID Foglights
    Stealership told me most of the major lubricant changes and tune up stuff was at 60K.
  7. Jul 16, 2010 at 9:30 AM
    woody6047
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    What tune ups are they supposed to do? I figured id do it now, I have had the truck since it was new and i obviously dont drive it very much because i work in the middle east. So figured id do the lubs after 5 years.
  8. Jul 16, 2010 at 9:47 AM
    NAAC3TACO
    Sparks, NV
    2014 SR5 DCLB 4x4
  9. Jul 16, 2010 at 10:08 AM
    woody6047
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Whoops haha, i guess i need to do that then.
  10. Jul 16, 2010 at 4:19 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    If you have an LSD diffy use search and check out the problems people have had using synthetic even when using the special LSD additive. Even though some have had luck I've read-in a more than just Tacoma forums-where a lot more had problems than not.
    There is no real 'upgrade' from stock plugs, they are pretty good just don't last long. You should change sometime before 30k...if you wanna upgrade get iridium or platinum plugs and go 60-100K before needing another change.
  11. Jul 16, 2010 at 6:11 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Running synthetic fluids (for most applications) is a good thing. I run redline synthetic fluids in the diffs and t-case. I also switched to denso iridium plugs with no problems.
