50mph + 6th gear = herky jerky... common?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DTaco18, Oct 23, 2020.
  1. Oct 23, 2020 at 7:43 PM
    DTaco18
    DTaco18 [OP] Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    Just moved from 6MT to 6AT... The automatic seems pretty smooth, but I notice that when I set my cruise at 48-52mph it seems the automatic shifts in to 6th gear (@1200rpm ish) and the engine bogs a bit causing a herky jerky feeling until the grade is steep enough to cause a downshift. Anyone else notice this? It's not a huge deal, but I just wondered if it's "normal".
  2. Oct 23, 2020 at 7:44 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I’m guessing that speed is going to be miserable with CC for anything other than totally flat.
  3. Oct 23, 2020 at 7:45 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Don't set cruise at that low speed. Problem solved.
    zoo truck likes this.
  4. Oct 23, 2020 at 7:51 PM
    DTaco18
    Fortunately I don't drive on the highway much. Most of my time is on open roads with 45mph speed limits.
    I can use S5 for a smooth ride, but I just wondered if it's a characteristic of the 6AT, or if I should mention it during my first free service.
    Skydvrr and hiPSI[QUOTED] like this.
  5. Oct 23, 2020 at 8:06 PM
    bgio67
    bgio67 Well-Known Member
    2020 TRD OffRoad DCSB
    The combination of an engine that does not produce low end torque running at 1200 rpms = a lot of down shifting. I think using S5 and not using the second overdrive is your friend in this situation.
    TacoMike likes this.
  6. Oct 23, 2020 at 8:32 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No vehicle will work well at those speeds and cruise control on. 55 mph + for cruise.
    Chew and DTaco18[QUOTED][OP] like this.
  7. Oct 23, 2020 at 8:35 PM
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    The truck should not have that issue, many other manufactures and models can run cruise well at that speed. However, it is common on these trucks. Doesn’t mean you shouldn’t mention it to the tech when you get it serviced.
  8. Oct 23, 2020 at 8:46 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Nope. No vehicle works well at that speed with cruise on. It is not a target speed. 55+.
  9. Oct 23, 2020 at 9:04 PM
    Superhulk LB
    Josh
    Oregon
    I’ve driven plenty that do. Half my commute was in a 45mph zone.
  10. Oct 23, 2020 at 9:08 PM
    DTaco18
    I like buying new vehicles. We're on 5th in 5 years. (it's a bad habit, waste of money, yada yada, yeah i know).
    All have been fine using cruise on the 45mph roads around here.
    I can reproduce the same thing in my new truck by keeping acceleration light around that speed and letting the tranny shift into 6th, then accelerate lightly without going so hard that it downshifts. I can feel the engine stumbling. Feels like being on a rough road.
    Anyone else feel the same thing? That's my real question here.
  11. Oct 23, 2020 at 9:14 PM
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    Mine does it too. If you know you're going to be cruising at 50mph for a while, either hit the ETC button, or just throw the shifter into "S" mode. That'll keep it in the power band consistently.
    ECT button gives you a bit more RPM allowance before shifting, and "S" mode takes out the two overdrive gears and puts you into 4th.
    texbaz and davidstacoma like this.
  12. Oct 23, 2020 at 9:17 PM
    Superhulk LB
    Josh
    Oregon
    Yes my 2019 does the same thing. I mentioned it to the dealership, but they didn’t have any solution. I still think it’s their programming.
    texbaz likes this.
  13. Oct 23, 2020 at 9:20 PM
    DTaco18
    Thanks guys. Glad to hear it's not just mine.
    I'll have to experiment with the ECT button a little more and see if if I like it.
    I'm only at 500mi so far, so I haven't had too much time to mess with it.
    davidstacoma likes this.
  14. Oct 23, 2020 at 9:21 PM
    toyotahenry
    toyotahenry N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    Is your truck new? If so, the transmission will need time to learn your driving habits. That’s just one of my guesses.
    Superhulk LB likes this.
  15. Oct 23, 2020 at 9:23 PM
    kairo
    kairo >_>
    Nor Nev
    Let me just put it this way. If there was a way for me to have my truck with the ECT mode on all the time, It'd be a no brainer. It makes the truck drive like a truck. The fuel saving low rpm shifting shit that these tacos do is annoying. Motor makes good power and torque, but you have to stomp the piss out of them to get it. Transmission is a big gripe among owners of the 3rd gen.
  16. Oct 23, 2020 at 9:25 PM
    DTaco18
    Yep. Just rounded the 500mi mark.
  17. Oct 23, 2020 at 9:25 PM
    Superhulk LB
    Josh
    Oregon
    It does get a little better over time.
  18. Oct 23, 2020 at 9:27 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    https://www.tacomaworld.com/threads/ect-auto-turn-on-module.514627/#post-16228014
    fathomblue likes this.
  19. Oct 23, 2020 at 9:28 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    I drive 50 miles round trip on a 55mph county road. Usually set cruise at 60. It has some decent hills that need shifts. Mine unlocks the torque converter, and downshifts if needed. Some of the hills it will pull through in 6th and locked. I don't notice anything odd.
    My first thought was your mileage being enough for the learning to have a chance.
  20. Oct 23, 2020 at 9:30 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Why would you use cruise at that low speed. Seriously that is not a speed that most people will target to maintain. 70 mph. 65 mph. 55 mph is what cruise and gearing is designed for.
