50mph + 6th gear = herky jerky... common?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DTaco18, Oct 23, 2020.
  1. Oct 23, 2020 at 9:35 PM
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    StayinStock[QUOTED] likes this.
  2. Oct 23, 2020 at 9:37 PM
    DTaco18
    DTaco18 [OP] Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    I use it mainly to prevent speeding tickets. Heck, I use it going through small towns with 25mph limits for the same reason.
  3. Oct 23, 2020 at 9:51 PM
    toyotahenry
    toyotahenry N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    There’s an aftermarket upgrade for all time ECT mode. I forgot who manufactures it.
  4. Oct 23, 2020 at 10:03 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If you use it at that speed then expect anomalies.
    Prayn4surf likes this.
  5. Oct 23, 2020 at 10:09 PM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    The stumble you’re feeling is common... and annoying. It’s definitely a programming issue. I havn’t felt it since I OVtune’d. It’s an expensive fix, but worth it IMHO.
    MOC221_ and DTaco18[OP] like this.
  6. Oct 23, 2020 at 11:48 PM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    I regularly use mine at 35 MPH for this, without problems.
  7. Oct 24, 2020 at 6:46 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Yeah, i never drive with the cruise set at 50 or so when driving the windy back roads here...just doesn't make sense to. Never noticed an issue with the truck bucking when running around 1200 rpm shortly after i switched to premium fuel, and its still not getting better losing exactly 1 mpg to after 2 fillips now. Decided on the next tank, back to the E87 sold here. Truck runs stronger on the lower grade fuel.
    Tullie D likes this.
  8. Oct 24, 2020 at 6:54 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I beg to differ. I use cruise control pretty religiously, especially with these drive-by-wire style systems. I've even set it as low as 25-30 in town when needed. This didn't start with my Tacoma either.
    Junkhead, MOC221_ and hiPSI[QUOTED] like this.
  9. Oct 24, 2020 at 6:56 AM
    RedWings44
    Michigan
    Some say common. Personally, I've not heard this issue before and mine definitely doesn't seem to have that issue.
    DTaco18[QUOTED][OP] likes this.
  10. Oct 24, 2020 at 6:56 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    If u wanted it to drive it self should of bought a Tesla
  11. Oct 24, 2020 at 7:02 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Do me a favor and google minimum speed for cruise control.
  12. Oct 24, 2020 at 7:05 AM
    RedWings44
    Michigan
    25-30 is what I get. Minimum speed is whatever speed it will no longer allow me to set. I also don't have the radar or TSS so, my understanding is that I've also got the ability to go lower than those people.
    hiPSI[QUOTED] likes this.
  13. Oct 24, 2020 at 7:09 AM
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    My 2020 at 60mph will downshift every time on a even a slight hill at 60mph while in Cruise Control.
    From my experience, the gearing is too high for the truck, and rehearing is on my bucket list to fix this issue.
  14. Oct 24, 2020 at 7:17 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I have such a great time reading some of these 3rd gen items. You guys do some stupid shit , cruise control to go 25mph. Apparently no brain to muscle connection. Funny stuff,:D. Toyota should have just left the 5 speed in the 3rd gen honestly the 6 speed has no advantage.
  15. Oct 24, 2020 at 7:18 AM
    #35
    Interbeing
    Austin, TX
    Toyota does not recommend running the higher ethanol fuel with the Tacoma. It is much more corrosive than the standard regular 87 octane, and can cause engine damage with engines not specifically designed to run it (i.e. EFlex). I run no ethanol 90 octane, the truck runs much smoother, makes a noticeable difference in performance, and gives me 1-1 1/2 mpg more in mileage.
    davidstacoma likes this.
  16. Oct 24, 2020 at 7:25 AM
    #36
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    My point is the gear ratios are not designed to maintain an rpm at those low speeds. That's all.
  17. Oct 24, 2020 at 7:27 AM
    #37
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    If you get the MESO Pro knob, you can rub it with your thumb and turn it on.
    wiljayhi likes this.
  18. Oct 24, 2020 at 7:28 AM
    #38
    RedWings44
    Michigan
    Mine seems to do it alright. That's my point. I use it all the time.
  19. Oct 24, 2020 at 7:30 AM
    #39
    RedWings44
    Michigan
    It's very nice when you frequently find yourself wanting to do 32 in a 20, or more. I usually go about 5 over regardless, but it's one less variable.
  20. Oct 24, 2020 at 7:34 AM
    #40
    Patriotgrunt
    Patriotgrunt Well-Known Member
    David
    Germany
    2020 Tacoma TRD Off-Road MT
    Curious why OP left a MT for AT? MT solves this problem by leaving the truck in 5th gear at those speeds.
