50mph+ vibration help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bamahoyt, Jul 27, 2014.
  1. Jul 27, 2014 at 11:59 AM
    Bamahoyt
    Bamahoyt [OP] Well-Known Member
    Ted
    Knoxville, TN
    2014 TRD Sport DC LB 4x4
    Within the last 5k miles I have started to notice a vibration at 50+mph but goes away under 45ish mph and it is only intermittent. Sometimes I feel it and sometimes I don't. It gets REALLY harsh when I brake from 50mph+ and again doesn't do it always when I am braking. I am wondering what this could be because it is not always vibrating. I am feeling it more in the rear and in the steering wheel. I had a problem with my e-brake sticking and I drove on it once or twice not fully knowing that it had stuck after releasing the brake so maybe that has a affect? I have read almost all the vibration threads but haven't found one that had it only happening intermittently. thanks for the help!
  2. Jul 27, 2014 at 12:31 PM
    Indy
    Indy Master of all I survey.
    Warped brakes will often be 'intermittent' but only because you dont always brake the same. But usually if i get a shake that only shows up at 1 speed and then goes away at a higher speed its usually a tire out of ballance. And if both tires are out they will sometimes be out of sync and be 'fixed' when they align in a certain way, then be shaking again once they fall out of sync.
  3. Jul 27, 2014 at 8:32 PM
    Bamahoyt
    Ted
    Knoxville, TN
    Ok, will check on that thanks
  4. Aug 1, 2014 at 8:34 AM
    Bamahoyt
    Ted
    Knoxville, TN
    With the wheels being out of balance, how would that explain the vibration getting much more severe when braking?
  5. Aug 2, 2014 at 1:53 PM
    Yotaman98
    Yotaman98 Member
    Colby
    North Carolina
    1998 Toyota Tacoma, 4x4, SR5, TRD
    3 inch lift, k&n intake, flow master dual flow exhaust, and Mickey Thompson wheels with Goodyear tires.
    Try checking the carrier bearing, mine did the same thing and I discovered the rubber in the bearing was cracked and was total junk, after replacing it it was fine.
  6. Aug 3, 2014 at 5:22 AM
    Bamahoyt
    Ted
    Knoxville, TN
    Perfect
  7. Aug 3, 2014 at 5:33 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    other things to check, rotors and all steering components, ie, inner and outer tie rods, ball joints, A-arm bushings. rotors as mentioned already...alignment....
    rotors are a constant when braking, the other components can be intermittent depending on the severity of the wear....
    I had the same problem with my 2000, once I replaced all of the above, and a sillyconed center support bearing, all is good....
  8. Aug 20, 2014 at 12:18 PM
    Bamahoyt
    Ted
    Knoxville, TN
    I replaced the front rotors, rear shoes, drums and brake springs, greased the drive shaft at each zirk, and now replaced the carrier bearing today and now.... Just a little vibration and a very subtle drone at 70+mph. Thanks for the help guys and I will keep trying to get no vibe
  9. Aug 28, 2014 at 7:14 PM
    Bamahoyt
    Ted
    Knoxville, TN
    Well I noticed my vibration is back again so I am back to the drawing board. It vibes pretty good from 50-75mph and gets very harsh pulsing and shaking when I brake. I also had my tires balanced yesterday and he said one was pretty bad.
  10. Jun 17, 2015 at 6:27 AM
    912 Well-Known Member
    Brian
    Cape Coral, FL
    2000 SR5 4x4 TRD
    APEX bumper, Toytec/5100s, Pro Comp 7069s, Toytec AAL, Toytec 2" greasable shackles, 10" 5125s, Energy poly bushings, snorkel, Monstaliner
