510 resistor missing alltogether
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mkzad, Mar 6, 2011.
  1. Mar 6, 2011 at 1:41 PM
    mkzad
    mkzad [OP] New Member
    Vermont
    Tacoma
    My compass stopped working and I found the fix to it on this forum. I removed the console and found the circuit board only to find one of my 510 resistors is completely missing. I did a search for a new resistor and they are rated for different wattages. How do I know which one is the right one? Does anyone have the answer to that? Thanks
  2. Mar 6, 2011 at 1:59 PM
    Geode
    Geode Well-Known Member
    Illinois
    09 4WD TRD
    No doubt others will chime in here. If there is 12 vdc running through the resistor, the current would be 12/510 = ~0.024 amps...(current = volts/resistance).
    Then watts can be figured as....watts = voltage x current
    In your case 12vdc x 0.024 amps = 0.288 watts
    half watt would be good starting point
  3. Mar 14, 2011 at 4:54 AM
    mkzad
    Vermont
    Tacoma
    Thanks for your help. I have a 1/2 watt resistor on order; that appears to be what I need.
  4. Mar 16, 2011 at 7:07 PM
    Geode
    Illinois
    09 4WD TRD
    No problem, let me know if it works out.
  5. Apr 2, 2011 at 7:32 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    this happened to me too, did you fix it?
  6. Apr 4, 2011 at 9:22 AM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Actually it is not a 510 ohm resistor.
    SMD (surface mount) resistors are noted in the first 2 digits as a value, and the last one is
    x10^(last digit)
    So 510 would be 51x(10^0) or 51 ohms.
    Assuming there is 12 volts running thru that resistor for current calculation would be a big mistake as well as, depending on the circuit, there could be a ton of different voltages running thru it. Maybe even diff voltages at different temps or compass directions.
    It is not a very high power resistor though. which you can tell from looking at it.
    If you ordered a 51 ohm half watt resistor you'd be safe enough.
    Actually that is almost certainly what is causing his issue. The 510 resistor there is well known here to cause the display not to work. Usually its just badly soldered, but in my case it was totally desoldered on one side, and barely holding on to the other, so I can see how it would be missing.
    I'm sure if you put a 51 ohm resistor in there, it will work just fine.
  7. Apr 4, 2011 at 9:24 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    ^^ correct 51 ohms.
    mine was almost missing. it was turned up 90 degrees, pointed straight up. did you look around in the console? couldnt have gone far.
    i had my friend really solder it in. he had to turn it the other way to get a good weld. 510# facing down.
  8. Apr 14, 2011 at 1:40 AM
    mkzad
    Vermont
    Tacoma
    Local electrionic repair shop replaced 1/2 watt resistor and re-soldered companion resistor - $18.00 fix. Compass is working great.
  9. Jul 20, 2011 at 3:51 PM
    txtuffluck
    txtuffluck Well-Known Member
    Johnny
    Central Texas
    07 TRD OR, V6 4X4
    I'm in the same boat, my 510 is missing also. Where did you order yours from? Part#?
    I've googled the description of the resistor, but I get a couple of different results, and I'm not sure which one is correct.
    For instance...part of the "description" 1210 or 2010 SMD..."special features"=anti-surge or field is left blank..."temp coefficient"= ±200ppm/°C or -400/ +150ppm/°C.
  10. Jul 20, 2011 at 4:04 PM
    beaver_scott
    beaver_scott Well-Known Member
    scott
    renton, wa
    2015 inferno trd pro
    vent shades, tinted windows, clear bra, pop n lock tail gate lock, anytime fog light mod.
    i took out my 510 resistors(one fell off) and put in 2 51 ohm resistors. bent the wires at the resistor and soldered each end of the metal wires to the spots where the 510's were soldered to the board. works great. i got a whole pack of the 510 resistors at fry's for a couple bucks. if you live in the seattle area i can do the fix for you....i got a bunch of extra resistors.
  11. Jul 20, 2011 at 4:09 PM
    beaver_scott
    scott
    renton, wa
    by the way, the resistors are 1/4 watt 51ohm. the color in order are green stripe, red stripe, black stripe, and on the opposite end is a red stripe. shoot, i could even mail a couple extras in the mail if you are not in the seattle area........im never gonna use the others. ive got 23 of em.
  12. Jul 20, 2011 at 4:13 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The watt value is the rating of how much current it can carry. As long as you get the Ohm rating right, you won't kill anything. Too small a watt rating and the resistor won't last long, too high is overkill, but won't effect anything. Too high will probably be too large, though.
  13. Jul 20, 2011 at 4:15 PM
    txtuffluck
    Johnny
    Central Texas
    07 TRD OR, V6 4X4
    lol...already did "the shake and look for". I'm thinking it fell out of the console someplace when I pulled the headliner for the deadening project. It's probably in the yard or in the dump(where the contents of my shop vac are).
    Wish I was in the Seattle area...I hear the weather is a lot cooler than it is here in Texas...:D
  14. Nov 6, 2011 at 4:00 PM
    Dorbs2457
    Dorbs2457 New Member
    Sean
    Colorado
    4 inch lift
    Do you have any more? I am in Colorado and could use one!! Or any idea where I could get one? Not even sure how to search for that. Tried "510 resistor" but doesn't really bring anything up that looks correct.
    Thanks
  15. Jan 23, 2012 at 6:48 PM
    callahansd
    callahansd Active Member
    3in Tuff Country...
    Can anyone tell me where I can get an extra 510, I also somehow lost one and really don't feel like getting suckered by toyota anymore...
  16. Jan 23, 2012 at 10:21 PM
    anethema
    J
    Dawson Creek,BC
    Tons of places sell resistors. Maybe a local radio shack, that guy said frys, etc.
    They cost almost nothing, so ordering them online will cost way more in shipping than what the resistors cost.
    If you're totally stuck here is digikey.
    http://search.digikey.com/us/en/products/CFR-25JB-51R/51QBK-ND/2406
    41 cents for 5!
    Shipping will probably be like ten bucks, but its either next day or day after, and digikey is a fantastic company.
    These are not like the originals, they are through-hole resistors you will just need to solder to the pads where the missing one was, like the guy above did.
    Good luck!
  17. Feb 26, 2017 at 4:47 PM
    stevespens
    stevespens Tacoma Addict
    Fort Mohave, Arizona
    06 Pre-Runner Quad Cab Rad Red
    2014 nose conversion in Radiant Red, Raceline Raptor wheels w/ 265/75R16's, Go Rhino chrome nerf bars, Pioneer AVH-X3600BHS stereo, leveling kit 2 1/2" and 1", tinted windows, color matched grill, Dynomax Syst-Ultra flow cat-back,
