5100’s - 1.75 vs. 2.5 with AAL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Richscott1985, Dec 26, 2017.
  1. Dec 26, 2017 at 6:06 PM
    Richscott1985
    Richscott1985 [OP] Member
    2014 Tacoma
    Looking for some opinions and thoughts out there. I have a 2014 extended cab extended bed and am looking to lift slightly. I will be installing 265/70R17 and debating setting the 5100’s at 1.75 to level it or set at 2.5 and get a AAL. I do not want any rake either. Thoughts??? Experiences??
    I’m not looking to make a wheeling machine, 2 kids is expensive enough as it is! Just something with a good stance that will hit a minor trail a couple times a year. It’s just time for tires which means time for an upgrade too!
  2. Dec 26, 2017 at 6:28 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I don't think the 5100s at 1.75 would even be noticeable on a DCLB. I'd be thinking at least 2 to 2.5 as a starting place in the front
  3. Dec 26, 2017 at 6:48 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Are you saying you have a double cab long bed? I have 1.75
    “ in the front and 1” in the rear. Just a slight rear rake at that stance.
  4. Dec 26, 2017 at 6:51 PM
    Richscott1985
    2014 Tacoma
    Yes, double cab. Apologies there.
  5. Dec 26, 2017 at 6:55 PM
    Richscott1985
    2014 Tacoma
    Also I’m good with rear rake, just nothing putting my nose in the air
  6. Dec 26, 2017 at 7:24 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Step 1. Acquire tape measure.
    Step 2. Measure hub to fender on the front
    Step 3. Write down measurement from step 2
    Step 4. Measure hub to fender on the rear
    Step 5. Write down measurement from step 4
    Step 6. Take measurement from step 5 and subtract measurement from step 3
    Use value from step 6 to determine how much you want to lift the front.... because guess what.... the 5100 settings with stock springs on a DCSB / DCLB are pretty much spot on.
    If anything error on the side with forward rake... none of the bro lean shit.
    JoefromPTC likes this.
  7. Dec 26, 2017 at 7:31 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Read the suspension forum, there is some real info down there.
  8. Dec 27, 2017 at 5:57 AM
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    For my taste I like my truck at the 1.75 height. My experience was I didn't like the way the truck drove after an alignment at 2.5 with stock UCA. At 1.75 to me it still drives like a stock truck but has a nicer stance. Also its easier to get in and out of. Just my 2 cents.
  9. Dec 27, 2017 at 10:42 AM
    Richscott1985
    2014 Tacoma
    Coolerman, did you have OEM rear suspension? If so does the 1.75 give you any front end rake?
  10. Dec 27, 2017 at 11:27 AM
    Coolerman
    Dan
    Rochester, NY
    I have the updated OEM four leaf pack. My truck is pretty close to being level. If you want to have some rake you will need something lifting the rear. I have air bags that I can adjust depending on what im doing/towing or hauling.
    I should add that I normally run the air bags with little to no pressure in them. I only air them up when I am towing something or have a heavy load because it does stiffen up the rear end when you air them up.
  11. Dec 27, 2017 at 11:39 AM
    Richscott1985
    2014 Tacoma
    Gotcha, thank you!
