5100’s to Help Ride Quality
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JimT805, May 4, 2018.
  1. May 4, 2018 at 4:10 PM
    JimT805
    JimT805 [OP] Dazed and Confused
    Jim
    Goleta, CA
    2014 Prerunner SR5 DCSB 2.7L
    Baja Alloy Wheels Toyo AT2 C-Load Avid Bumper Guard Oval Step Bar
    My 2014 Prerunner 2WD 2.7L 4CLY DCSB is just shy of 35K miles. I feel that it should be preforming better off-road over dirt roads then it does (lots of shaking). I am pretty sure my ’99 2WD Ford Ranger actually performed better in the dirt.
    How helpful would it be to replace struts and shocks with Bilstein 5100’s? From what I’ve read (for better ride quality) it would be best to reuse OEM coils and leave the front set at .00.
    I was hoping to hear from Prerunner 2WD 2.7L 4CLY DCSB owners who have done this. If you could share your experience that would be great.
  2. May 13, 2018 at 9:32 PM
    Narutaki
    Narutaki Well-Known Member
    Brian
    2007 Blue Toyota Tacoma
    None
  3. May 13, 2018 at 10:22 PM
    Benloveless1
    Benloveless1 Well-Known Member
    Ben
    2010 Tacoma DCSB TRD
    No experience with a pre-runner but I feel as if the 5100’s improved my ride no doubt.
  4. May 14, 2018 at 1:10 AM
    Spencer4x42006
    Spencer4x42006 Whoisthatguy
    Spencer
    Bend, OR
    2006 TRD OR
    5100s Wildpeaks Light bar Other shit
    The stock struts that come on those Arnt all that good, I run 5100s. They work well
  5. May 14, 2018 at 1:12 AM
    Stemmy
    Stemmy Certified Wombat Rancher
    Rob
    Pennsylvania
    2013 Pyrite Mica DCLB
    love my 5100's
  6. May 14, 2018 at 7:01 AM
    Pigpen
    Dan
    Northwest Montana
    The stock shocks are valved for highway use. If you drive a lot of washboard and potholed dirt roads (like I do), the oil in the stock shocks foams and they become temporarily worthless. This does not happen to the 5100s. I rally over miles and miles of rough road regularly and the 5100s perform great - for a low price shock.
  7. May 14, 2018 at 7:43 AM
    hseng001
    hseng001 Member
    Whittier, CA
    I just installed the 5100s on the front and set them at 1.75”. It rides much better than stock and eliminated the nose dive when braking.
