5100, 5125, or 5150 in the Rear???
Discussion in 'Suspension' started by jmed99, Apr 13, 2010.
  1. Apr 13, 2010 at 8:34 AM
    jmed99
    jmed99 [OP] Well-Known Member
    SC
    09 DC PreRunner TRD OR
    Ok, if I go with a 3" lift in the front but I want the rear fender to sit 1" higher than the front fender should I go with a 5100, 5125, or 5150?
    If I use the 5125 or 5150, how much travel will I need? This will determine which shock to buy since those come in different lengths. I wont be doing much off roading with my 09 DC TRD OR PreRunner.
    Thanks for the help guys!:D
  2. Apr 13, 2010 at 8:41 AM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    well shocks are not going to make your ride any taller ...... thats the leafs part
  3. Apr 13, 2010 at 8:45 AM
    DaWillDaBeast
    DaWillDaBeast Well-Known Member
    Will
    Orlando FL
    05 Tacoma 4x4 with some goodies
    Things
    X2, the leafs do all the lifting and as for which shock, that would depend on which leaf pack you go with and how much travel those leafs will give you.
  4. Apr 13, 2010 at 8:53 AM
    jmed99
    SC
    Yeah, I know the rear shocks dont make it any taller. Not sure how I would get the rear fender about an inch higher. I may do toytec coilovers (including the 5100s) in the front to get the 3" there and do the toytec AAL for TSB to get 1.5" and a 1.5" block. Since the rear is 1.75" higher than the front now that should get me ~1" higher in the rear if I went with a 3" lift using coilovers in the front.
    If I did that, which shocks for the rear would you recommend? 5100, 5125, or 5150s?
    Thanks!
  5. Apr 13, 2010 at 8:55 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    5100's will be fine
  6. Apr 13, 2010 at 8:57 AM
    jmed99
    SC
    But I thought if you went more than 3" the 5100s wouldn't work?
  7. Apr 13, 2010 at 8:59 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Sorry, I missed the 1.5" block. You can still get the 5100's and an extender from Toytec. That would work also. Your main concern is going to be at full droop. Since you won't be doing much OR'ing, I wouldn't be too worried about it.
  8. Apr 13, 2010 at 12:30 PM
    jmed99
    SC
