5100 all around vs. toytec ultimate lift?
Discussion in 'Suspension' started by KingRama4, Feb 4, 2010.
  1. Feb 4, 2010 at 11:41 PM
    KingRama4
    KingRama4 [OP] Well-Known Member
    planning on lifting but deciding which route to take. what advantages would i have going w/ the ultimate lift kit? i don't do any serious off-roading. i do make snowboarding trips up the mountain and that's pretty much it. can anyone make suggestions as to which direction i should go? thanks!
  2. Feb 5, 2010 at 12:18 AM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    06 Prerunner 4.0 a/c beast
    k&n cai 63 series intake, blacked out headlights, blacked out tailights, magnaflow pro offroad 17115 dumped, URD competetion y-pipe, total chaos 3.5" long travel, fox 2.5x8" remote resevoir shocks, allied 4" spindles, toytec 2" AAL, 20% tint up front and 5% rear, satoshi grille, ddm 50w 6000k hid's. wet okole custom trd seat covers with heaters. 4:56 nitro gears with arb rd129 air locker, arb ckmta12 dual air compressor.
    i have bilstein 5100s all around. the rear has the toytec aal and the front coils set at .85 almost level.
  3. Feb 5, 2010 at 12:22 AM
    KingRama4
    cool but what advantages would i have if i go w/ the ultimate lift kit?
  4. Feb 5, 2010 at 4:03 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    None IMO! Save yourself the $$$ and just get the billies. If you decide the ride is to stiff. Then you can always get some eibach coils to go with your bill's.
  5. Feb 5, 2010 at 9:04 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    Here are some advantages.
    If you go with just the bilsteins all the way around, in the front, you will maintain your stock coil. There is reason one. The stock front spring is not a very solid or long lasting spring. Especially when you going to pre-load that spring with your bilstein shock. Where as with the Ultimate kit, you get a new coil to replace yours, which will pretty much last the life of the truck. With the Ultimate kit you then have the freedom to have ANY EXACT lift height you want. You pick. Unlike the notch's on the shock alone. The Ultimate kit does come with a life time warranty also. With just the bilstein shocks in the rear, you won't get any lift. So this might be your determining factor. Do you want to lift the rear? If you do, then the bilstein shocks aren't going to do it. With the kit, you get a 2 inch lift in the rear. We do offer a 1.5 inch rear lift spring.
    I think there are advantages with going with the Ultimate Kit vs. just the Bilstein shocks.
  6. Feb 5, 2010 at 9:15 AM
    Toytec Lifts
    Rocky Mountains
  7. Feb 5, 2010 at 9:16 AM
    Toytec Lifts
    Rocky Mountains
    That adjustable collar sits on that c-clip on the shaft of the shock.
  8. Feb 5, 2010 at 10:00 AM
    Toytec Lifts
    Rocky Mountains
    right on the clip, just like the stock spring perch does.
  9. Feb 5, 2010 at 12:02 PM
    KingRama4
    can you define/describe "stiff ride?" good or bad?
  10. Feb 5, 2010 at 12:09 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    the way a truck should be.....
