5100 Billies @ 0", OME 884, 1.5" AAL, 1/4" driver side spacer, TRD Access Cab, OR Rim
Discussion in 'Suspension' started by EmoSlayer, Jun 20, 2012.
  1. Jun 20, 2012 at 8:07 PM
    EmoSlayer
    EmoSlayer [OP] METAL!
    Scott
    PA
    TRD Off-Road
    Bilstein 5100s all 4 corners, front set at 0.85 w/ eibach coils metalcast red, driver's side lean spacer, rear tsb leaf pack with tsb aal from toytec, 265/75/16 goodyear wrangler authority, MT Classic III 16x8 4.5bs, LR UCAs
    Hi all, after a 2 year sabaticle from being a tacoma owner I'm back and ready to mod my new truck again. My previous setup was the OME full 3" lift with 2" AAl and 285s and LR UCA's on a 2009 DC, can see in my pics...
    Anyways I had a few issues with it, 285s rubbed badly, after major trimming, alignment wasn't close to perfect, rear sagged after jumping, cause it to be nose high.
    So even after all that I still want to mod my new 2011, but I am going to be a little smarter about it... nothing as drastic
    I have decided to put this kit together:
    OME 884 coils w/ (1/4") spacer drivers side
    1.5" AAL in rear
    5100s all four corners (0" in front)
    265/75/16 duratracs "C" load
    stock TRD offroad rims
    stock UCA's
    Anybody running this exact setup??
    Pics would be greatly appreciated, I have done a ton of searches on here and google images and have found a couple with the exact setup.
    Feedback from experience would also be appreciated...
    such as were you able to get within Toyota specs for front end alignment
  2. Jun 20, 2012 at 8:13 PM
    EmoSlayer
    Scott
    PA
    TRD Off-Road
    TSB in rear, this gives about 0.5" lift in rear i've found on here
    front Eibach springs 1.6"
    How bad would it be to run this on stock TRD billies?
  3. Jun 21, 2012 at 6:15 AM
    Large
    Large Red
    You'll be fine, although a lot of people will tell you to fork over the extra dough for bilsteins.
  4. Jun 21, 2012 at 6:15 AM
    Large
    Large Red
    5100s that is.
  5. Jun 21, 2012 at 6:28 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    People have run the Eibachs on stock Bilsteins but they're a strong coil and will wear the shocks out quickly (also might be rather bouncy). I'm sure you'd be fine for a while with that setup if you wanted to put off buying 5100's for a while. I haven't ridden in a truck with stock shocks and Eibachs, just my opinion.
  6. Jun 21, 2012 at 6:40 AM
    EmoSlayer
    Scott
    PA
    TRD Off-Road
    Thanks for the replies, i'm thinking i should just wait a little and get the billies along with it, i know my 2" aal sagged really bad over time, anyone have this problem with the 1.5"?
  7. Jun 23, 2012 at 6:20 PM
    dhdan
    dhdan Member
    I'm getting 5100's front and back, OME 884 coils with no spacer, and 1.5" wheelers AAL with overload all installed this Tuesday. I will try to post pictures after it's done.
  8. Jun 23, 2012 at 6:50 PM
    Pugga
    Massachusetts
    F-150 Mod
    Welcome to TW!
    Sounds like a nice setup :thumbsup:
  9. Jun 25, 2012 at 6:35 PM
    2005Taco4X4
    2005Taco4X4 Well-Known Member
    North Carolina
    05 Silver Tacoma 4x4 W/ 6 Speed
    All blacked out, Mbrp Off Road Exhaust, K&N intake Fog Lights Mod, Kenwood Headunit, Rockford Fosgate Speakers, 10 inch Kicker Comp Subwoofer, Bilstein 5100's, OME 884's with toytec spacers -3.5" 2 inch aal and 2 inch block 255/85r16 BFG KM2's Brush Guard with 100W lights, Blue LEDs inside
    I have an access cab 4x4 Tacoma and i'm curious, if i get Bilstein 5100's with OME 885 coils and set them at 0 then get a 2 inch AAL in the rear, would i need new UCA's and a front differential drop kit? Also how much lift would i be getting from this setup. Thanks in advance.
  10. Jun 26, 2012 at 5:54 AM
    Pugga
    Massachusetts
    F-150 Mod
    It'd be a good idea to plan on getting UCA's. You might be able to get away without them but you'll have a hard time getting aligned. The differential drop is a waste of money on a 2nd gen and I wouldn't install one unless you're chasing vibrations and that's the last thing to try. The 2nd Gen differential drop doesn't drop the diff, it rotates it instead which doesn't really do anything to improve your CV angles and lifts the rear bearings out of the oil.
    You'll gain about 2.5" of lift from that setup on your 4x4 V6 access cab.
  11. Jun 26, 2012 at 6:58 AM
    2005Taco4X4
    North Carolina
    Thanks man. One more thing, would i be able to fit 255-85R16 tires without having to trim anything? If not, what would be the largest size tire i could run without rubbing at all.
  12. Jun 28, 2012 at 6:59 PM
    2005Taco4X4
    North Carolina
    How did your lift turn out?
  13. Jun 29, 2012 at 11:06 AM
    dhdan
    dhdan Member
    I love the lift. The only issue I have is that my vsc light came on after lift and alignment. Have to get that worked out now.
    Edit: Add picture - VSC Light was tripped prior to alignment. Dealership cleared at no charge even though they didn't do the work.
  14. Jun 30, 2012 at 2:16 PM
    dhdan
    dhdan Member
    The one thing I would consider is that there is a little bit of front end dive with the 884 coils when hard braking. I don't mind it and don't know what the difference would be going to the 885 coils.
    I got exactly 2 inches of lift in the rear with the overload. I got about 1 1/2" on the passenger side front and about 2" on the drivers side front.
    I had 1/2" droop on the drivers side of the truck prior to the install. I measured the coils and they were the same height but had a bit wider separation between the coils on one of them. I had that one placed on the drivers side and it gave that side slightly more lift (at least the measurements are the same for height on the front now.)
    The truck rides great now and doesn't have as much issue going over washboard roads. The rear end follows them much better.
    Next on my list are the duratracs so I don't have any input on those. Fortunately there are other threads dedicated to those. :)
    My alignment seems good to me.
    Alignment on my truck is:
    caster: left-2.0 right-2.4 spec 1.4 to 2.9
    camber: left-0.5 right-0.4 spec -0.4 to 1.1
    toe: left-1/16th right-0 spec -1/32nd to 1/32 or -1/16th to 1/16th for both
  15. Jun 30, 2012 at 5:19 PM
    2005Taco4X4
    North Carolina
    Looks great! I think that's the same setup i'm going to use on my truck now
  16. Jun 1, 2013 at 1:27 PM
    Pythagoras32
    Pythagoras32 Member
    Tony
    South Carolina
    Tacoma TRD 4x4
    Super Charger, Leveling Kit, Avid off-road Light Bar, Marathon Seat Covers
    I am doing the same setup, planning to install this coming Friday.
    I am however curious as to where you have the 5100s in the front adjusted.
    0 or .85?
  17. Jun 2, 2013 at 7:40 AM
    dhdan
    dhdan Member
    Mine are set to 0. Unless I was doing upper control arms at the same time, I wouldn't go higher than that personally. Too much of a possibility of not being able to get it aligned where it would drive well. I still have the factory rake with my setup and assume my rears will sag a bit over time to where it will be closer to even.
  18. Nov 10, 2015 at 8:50 AM
    NewfoundlandTaco
    NewfoundlandTaco Well-Known Member
    Newfoundland, Canada
    06 TRD Offroad Indigo Ink
    Billy 5100 at 2.5", 1.5" blocks, tailgate theft mod, extra bed D-rings. General Grabber AT2's.
    Are these alignment numbers with stock uca's?
  19. Nov 18, 2015 at 6:22 AM
    dhdan
    dhdan Member
    The numbers I stated were with stock upper control arms.
    NewfoundlandTaco likes this.
  20. Nov 18, 2015 at 10:36 AM
    NewfoundlandTaco
    Thanks for the reply! Planning on doing this setup when I get my chassis replaced. If you had any pictures I'd love to see them.
