5100 Bills settings & springs questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sportsguy, May 21, 2013.
  1. May 21, 2013 at 9:13 PM
    sportsguy
    sportsguy [OP] searchgeek
    OK, so following all my suspension lift option research, I'm thinking I'm getting close now. Looks like my desire to skip the 5100s might have been misplaced, as after considering everything, they might be just what I'm after.
    Crow having been consumed, I'm left with the following...
    I have a red cab 4wd.
    Assuming the 884 OME springs for the lighter weight of my truck, should I bump to 885s if I plan to add an ARB bumper up front? No plans for a winch at this time.
    ...and it's the 1.75 setting to level these trucks, correct?
    ...with a 5mm spacer on the driver's side to counter bro lean, right?
  2. May 22, 2013 at 9:33 AM
    sportsguy
    Hmmm...strangely quiet. Have I stumped the chumps? ;)
  3. May 22, 2013 at 9:40 AM
    Stockmonester
    Stockmonester Well-Known Member
    Nick
    Rome, Ny
    2010 reb reb black trim
    Satoshi chrome grill deep lip, 5100 set at .85, 2 hella 500 fog/2 hella 500 driving on n-fab light bar, k&n drop in
    I put 884 coil on my 10 rc, I got 3 inches of lift. MInd you I measured right after i dropped the truck and took it for a spin. I took the coils off to put 5100 in at .85 im about 1 lower in the front than the back but from a distance it looks just about level.
  4. May 22, 2013 at 10:02 AM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    not sure on the 884's but Im thinking the Billies at .85 will put you almost level without new springs. And 885's I am pretty sure will lift you 2-3" so with this all said you will need something in the rear AAL or Leaf pack if you go the new spring route which might also mean UCA's needed in the front if you are over 2.5" of lift
  5. May 22, 2013 at 10:24 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    885's will put you at about 2.5" of lift on a V6 Tacoma, you'll get more than that if you put them on a 4 cylinder regular cab.
    OP, you've got a lot of types of lifts being thrown around in your original post. If you use just 5100's and stock springs, you can set the 5100's to whatever you wish. Generally 1.75 will level a truck but being that you have a lighter truck, .85 might just get you there. If you use OME springs, keep the 5100's at 0 and let the springs do the lifting. If you go with 884's for now and add an ARB later, you can always kick the 5100's up to .85 or swap out to 885's to counter act the sag from the weight of the bumper. 884's and 885's have the same spring rate (made from the same coil), the 885's are just 1/2" taller.
    How much lift are you looking to gain in the end?
  6. May 22, 2013 at 11:27 AM
    sportsguy
    Good point Pugga - I might be combining things I don't need here. ;)
    ideally, I'd like to stay around 2" max, so somewhere between 1" and 2" is fine. Ideally, I'd level the front and simply upgrade the rear shocks while using the factory leaf springs in back. I think this combo will allow for:
    1 - ride comfort I want
    2 - load capacity I want
    3 - slight benefits offroad
    4 - better ride control with upgraded dampers
    5 - manage the weight of the ARB front bumper that'll come
    Though I am concerned about the stock springs being able to manage the added weight of an ARB bumper effectively when offroad. I'm a conservative driver, but a mass of steel flapping around on weak springs affects a bunch of other stuff the physics gods get a kick out of. ;)
    My fall back is to say f*ck it, grab a 2" OME kit with Dakars (maybe) and swap the front diff bearing to help with vibes (should they appear) and grab a Tom Woods one piece driveshaft to help out back (again, if needed).
    Front bushing swap in the diff is likely to happen in any event as preventative, but the rest (the full-on OME kit) would be overkill for my actual use of the truck (my desired use would make it all just right, but in reality, I'm trying to keep it real...)
  7. May 24, 2013 at 6:34 AM
    sportsguy
    Any more feedback gang?
