5100 Bilstein @ 1.75" Alignment Specs??
Discussion in 'Suspension' started by patwrik, Jul 19, 2011.
  1. Jul 19, 2011 at 10:30 PM
    patwrik
    patwrik [OP] Well-Known Member
    San Diego, CA
    05 DBL CAB
    Hello all,
    I've searched and searched, but was not able to find anything regarding this.
    I bought the 5100 billys at DSM, front and rears. I installed them myself, set the fronts to 1.75" and then brought it over to The Truck Shop in San Diego to get aligned.
    While driving down to The Truck Shop, I noticed that my steering wheel is all cockeyed and its pulling to the left.
    James @ The Truck Shop said he would take care of it. It took around 2 hours for them to complete the work. I paid and took it around. Steering wheel is still facked up and its still pulling to the left. I took it back to James and he said it was because I recently rotated my tires. Told me to drive it around for a week and then bring it back.
    My question is this BS regarding the tires, or are my numbers off? What should I do?
    Here are my numbers before:
    Caster LEFT `1.3" RIGHT 1.4"
    Camber LEFT 0.7" RIGHT 0.9"
    Toe LEFT 7/32" RIGHT 7/32" TOTAL 7/16"
    My numbers after:
    Caster LEFT `1.2" RIGHT 1.5"
    Camber LEFT 0.6" RIGHT 1.0"
    Toe LEFT 1/32" RIGHT 1/32" TOTAL 1/16"
    What would you guys recommend to be in "spec?" Anything else you guys can recommend to get it driving back to what im use too?
    BTW, I'm not trying to bash on The Truck Shop. James did tell me that I can bring the truck back, after a week or two to allow the tires to wear down. Hopefully, he'll keeps he word.
    Thanks for all your help regarding this issue.
    -Patrick
  2. Jul 20, 2011 at 7:50 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2006 Tacoma double-cab TRD Sport
    Homertaco grill, Light Racing UCA's, 2.8" front lift (5100's at 0.85 setting and Eibach springs) 2" AAL with rear 5100's, Wet Okole seat covers fr/ bk. 17 x 9 Incubus Crusher wheels w/ 4.5" backspacing. 30% tinted front windows.
    Camber should be 0.3 or lower, and caster should be higher...1.8 or higher at least, but 2.3-2.5 would be ideal. At 1.75 you should be able to get those numbers
  3. Jul 20, 2011 at 10:21 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    0 camber
    0 toe
    2.4 caster
  4. Jul 20, 2011 at 7:10 PM
    patwrik
    San Diego, CA
    05 DBL CAB
    Thanks for the replies. Hope James @ the truck shop keeps his word.
  5. Jul 20, 2011 at 7:14 PM
    bolson
    bolson Well-Known Member
    San Diego
    2011 SR5 4x4 2.7L Access Cab
    Interested in the outcome of this, I plan on doing 5100s at 1.75" very soon
  6. Jul 20, 2011 at 8:21 PM
    patwrik
    San Diego, CA
    05 DBL CAB
    I'll keep this post updated....
    @Bolson, you planning to install yourself?
  7. Jul 21, 2011 at 2:10 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    See if they can get your camber closer to zero and your caster a little higher.
    Also please note that they're alignment machine could be out of calibration. So those numbers might not even be accurate.
  8. Jul 22, 2011 at 8:12 AM
    WaGood24
    WaGood24 Well-Known Member
    Michael
    Dayton, OH
    2010 Double Cab PreRunner TRD Sport
    Extang Full Tilt tonneau, VX Series Exhaust, Nitto Terra Grapplers, Stainless Nerf Bars, Bilstein 5100s all 4 corners, rear-leaf TSB
    I'm putting my 5100s on in next weekend and I was wondering how big of an issue is getting an allignment afterwards? Of course I'm planning on getting my allignment done, at the dealer actually. But what I'm wondering is whether or not it's ok to drive on for a few days? Or do I need to just keep it in the driveway until I get the allignment done? Thanks.
  9. Jul 27, 2011 at 6:48 PM
    patwrik
    San Diego, CA
    05 DBL CAB
    Thx Zombie Runner... Specs definitely helped.
    Although they did not get them exactly to the numbers, they were +/- .02.
  10. Jun 17, 2013 at 12:46 AM
    StreetTaco4Me
    StreetTaco4Me Taco Shot
    Bryan
    Ventura County, So. Cal.
    2001 4runner SR5
    looking to replace shocks and add spacer lift...I do not off road at all just like the height of a lift
    just the info i needed...I have billys set at 1.75, do I just walk in the alignment shop and say I want to see these numbers please:
    0/0/2.4
